Results 1 to 9 of 9
    Aug 2013
    Seeker brake question
    Hey everyone,
    This winter I'm buying a new wheel set and thought while I was at it I'd upgrade to a 180mm front rotor. I'm having trouble figuring out what bracket I need. Anyone have an idea what I'll need?
    Thanks.
    EDIT: Just listen to Jeremy.
    Eric
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by skyphix View Post
    I believe you can either run the Shimano post mount 180mm adapter like this one
    Shimano F180P/P2 Disc Brake Adaptor > Components > Brakes > Brake Adapters | Jenson USA Online Bike Shop
    or you can shave down the Avid 185mm adapter to work.
    I've never done it, just spoken with my mechanic about it, so someone please correct me if I'm wrong.
    Avid/SRAM has moved to a 180mm rotor standard, the 185 really isn't being utilized anymore. To put a 180mm rotor on a Seeker, the 20mm post-mount adapter (with longer bolts that come with it) is needed. I recommend the SRAM part if possible.
    Attached Thumbnails Attached Thumbnails Seeker brake question-avid_acc_cpsmntbracket_postmnt_20mm_lrg.jpg
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Awesome Jeremy! I didn't find the 20mm adapter, all I could find was the old 185, but that explians why it was discounted to sub $5
    Eric
    Reputation: KrazyKreitzer's Avatar
    I run that same adapter and a 180 mm rotor on my first gen Goblin. Nice inexpensive upgrade and I think it made the brakes feel more even front to rear of that makes sense.
    Aug 2013
    Awesome, that's exactly what I was looking for. I kept coming across 20mm spacers but they looked like they were for the rear caliper. Thanks for all your help guys!
    OP, do you mind if I ask where you found the right adapter and hardware?
    Sep 2012
    Thanks! I really did look, but wasn't sure I was finding the right part.
    What size screws/bolts do I need for this adapter?
  1. Seeker tubeless conversion question
    By PaveLow in forum Airborne
    Last Post: 11-21-2013, 12:26 PM
  2. Seeker Gearing Question
    By perky p in forum Airborne
    Last Post: 11-09-2013, 07:06 PM
  3. One more Seeker!
    By sickSeeker in forum Airborne
    Last Post: 09-05-2013, 04:42 AM
  4. Seeker is HERE!!!!
    By OrangeBlood in forum Airborne
    Last Post: 08-25-2013, 06:30 PM
  5. Replies: 6
    Last Post: 01-06-2012, 09:34 AM
