Page 5 of 15 FirstFirst 123456789 ... LastLast
Results 401 to 500 of 1463
  1. #401
    Pretty much describes my riding as well, and where I lack confidence in them are the surfaces you struggle with (wet, mostly.) I agree though that as long as the pressures are kept in check (below 35psi) they are awesome in loose over hardpack stuff. We have some wood chips on our trails and I find that they grip there better than the more aggressive tires on my 26er. Thanks for your response.
  2. #402
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: Post Your Modified Airborne Bikes
    I'm about 190 all geared up and ran 30 psi front, 32 rear with tubes. Seemed like that was the sweet spot for me. I haven't had a real test ride tubeless but gonna start out at 28/30
    Yeah unfortunately they're awful in the mud, but that's to be expected from a tire with knobs so closely spaced. I think I'm gonna get a set of maxxis beavers for when I HAVE to ride in the mud
    Sent from my DROID RAZR using Tapatalk 4
  3. #403
    Reputation: KrazyKreitzer's Avatar
    Is this considered a modification?
    My friend had an incident with a tree.
    All things considered he's doing pretty good.
  4. #404
    Quote Originally Posted by 8iking VIIking View Post
    Im about 245 geared and run them 32 front 35 rear... ish. I was down at 28-32 and was fine on trail but wound up pinch flatting when I misjumped onto a curb and hit the rear wheel. Figured if it can happen while I'm goofing around in the city then it can happen on trail and went up a few psi. I'm not tubeless yet but will be once I get a second wheelset.
  5. #405
    Jul 2013
    Quote Originally Posted by KrazyKreitzer View Post
    Where did your buddy get that short wheelbase guardian from? I can't find that version on the website.
  6. #406
    Quote Originally Posted by hedz0r View Post
    It's pretty much a custom job. It doesn't handle as well as one would think.
  7. #407
    Dec 2012
    Quote Originally Posted by skyphix View Post
    Well I just got back from my first "real" test ride and I gotta say....I think tubeless lives up to the hype. I was a holdout for a long time but the low pressure really does significantly take the edge off some of those square edged rocks and small roots and improves traction. I started out at 28f/30r then went to 26/28 and that seems to be perfect. There were a few times I really pushed it around corners, nearly certain I would wash out or at least break loose, but the traction was rock solid. I'm a believer!
  8. #408
    Reputation: BigDaddyFlyer's Avatar
    It's the "new" 29er geometry that's all the rage this week. Thank GOD that is the in thing right now so that people are less focused on getting 10inch long chainstays.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
  9. #409
    Nov 2012
    Do you tubeless (our even non tubeless) people use a digital pressure gauge for checking psi? What do you use?
  10. #410
    Dec 2012
    Quote Originally Posted by trevor_b View Post
    I use a dial-type gauge that I got at a bike shop a few years ago, I think its a zefal brand. Not sure if its a good brand but its been pretty consistent with other gauges I've used
  11. #411
    Reputation: TheDocTx's Avatar
    Apr 2013
    Holy Crap! That must have been a ride!!
  12. #412
    Based on the trees in the background, was that the Abracadabra Trail at JB?
    Jeremy
  13. #413
    Apr 2013
    Baby got new shoes! Maxxis Ignitor 2.1 in the rear, Ardent 2.25 up front. Really happy with this setup so far. The pine straw covered trails down here were giving the SB8's fits in the corners. The Ardent is able to find the trail under the leaves and straw, and what an improvement! I was concerned that this setup would be slow rolling....not the case. It rolls nearly as fast as the SB8's with much more cornering grip.
  14. #414
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    You must know those two trees fairly well. You are correct.
  15. #415
    Scary, huh?
    Jeremy
  16. #416
    Scary, huh?
    Jeremy
    Makes Halloween look like Valentine's Day.
  17. #417
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Murdered the wheels and tires, except for the G which received a green treatment!
  18. #418
    Oct 2012
    Finally got it right where I want it!
    -Stan's arch ex/hope pro 2 evo wheels
    -race face narrow wide chainring, set up 1x10
    -race face evolve bars
    -easton ea90 stem
    -esi chunky grips
    -wtb volt saddle
    -sram team bb
    -on my second set of aka's (the folding bead version this time), set up tubeless. Love these tires!
    Good looking bike. Very similar to what I have planned for mine. Any idea on current weight?
  19. #419
    Dec 2012
    Quote Originally Posted by jdhunt0 View Post
    Not a clue, but I must have lost at least 3 lbs from stock between the wheels, tires, stem, bars and 1x10 conversion
  20. #420
    Jul 2013
    Finally washed off 2 months of dirt and dust from my HobGoblin, forgot it was blue underneath so i decided to take some backyard pics with something better than a camera phone.
    Parts List:
    • Hope Pro 2 Evo hubs laced to Stan's Flow EX hoops
    • RaceFace Turbine Alu 725mm Bars
    • Truvativ Holzfeller 60mm Stem
    • ODI Troy Lee Designs Lock-On Grips
    • Diety Decoy Pedals
    • Easton EC70 Carbon Seatpost
    • Niner YAWYD Stem Cap
    • Selle San Marco Ponza Power ((Black) from fiancee's Goblin)
    • Maxxis Ardent 2.4 (front) Tubeless at 28psi
    • Continental Race Kings 2.2 (rear) Tubeless at 26psi
    Next up is new brakes, been having my rear brake loose pressure when sitting for a while, take me tilting the bike on the front wheel and pumping the brake to get feeling back. I think I could use a serious bleed.
  21. #421
    Reputation: Mitch1171's Avatar
    Jan 2009
    Hobgob xo
    Post Your Modified Airborne Bikes-img_5569.jpgPost Your Modified Airborne Bikes-img_5570.jpgNot any crazy upgrades just some Ergon grips and new fizik Gobi seat! Oh and front tire I won is a CST Ouster. Will probably put an Ardent on the front this one is real grippy and I tad slow. Came at a good time as I cut one of the stock ikons. With the grips and new seat I can ride all day! Very comfy!
  22. #422
    Aug 2013
    Is that a Warsteiner bottle cap?
  23. #423
    Jul 2013
    The Guardian taking a break.
  24. #424
    Reputation: strfyeing's Avatar
    Mar 2013
    Parts List:
    How's the clearance on that front wheel?
  25. #425
    Jul 2013
    Quote Originally Posted by strfyeing View Post
    Hard to tell from the pics but the ardent on the flow fits with tons of room. No issues.
  26. #426
    Dec 2012
    Quote Originally Posted by s0ul_chicken View Post
    How'd you go about doing that with the tires? Looks pretty slick!
  27. #427
    Jul 2013
    Got bored after playing golf today and snapped some photos of the Guardian.Post Your Modified Airborne Bikes-g2.0.jpgPost Your Modified Airborne Bikes-g2.0-5.jpgPost Your Modified Airborne Bikes-g2.0-6.jpg
  28. #428
    Jan 2009
    Havent had any problems! its a 2.5. real grippy!
  29. #429
    Nov 2012
    awesome looking bike!!
    what crank is that?
  30. #430
    Jul 2013
    Cranks are Race Face Evolve.
  31. #431
    Aug 2013
    Thanks 8iking VIIking! I just used a five dollar can of Plasti-Dip spray matte black. Taped off the wheel and covered the "G" with tape and gave it two light coats of the Plasti. All I did then was to wait for the cure time, then took a green highlighter and hit the "G" to make it glow. Turned out nice and holding up very well with the 20 miles on it so far. It will get a great debut at my first race this coming weekend!
  32. #432
    What a great use for Plastidip. I use it on my car/cars frequently (and other household projects) but never thought about it for a flexible application. Thanks for the idea, looks great!
  33. #433
    I feel like I can finally post a photo in this thread. Added a Raceface Turbine 3/4 725mm bar, SRAM X7 Rear der., 90mm EA30 Stem (revised version, not the recalled version), and Salsa quickrelease seatpost to my Seeker. I got the stem for under $10 and will probably go with something stiffer and move this to my road bike but it was a cheap way to find out if I like the 90mm length, and I do. Any shorter and I'd feel cramped. Next will probably be a WTB Speed V (or a Brooks) saddle and Ardent 2.4/Ignitor 2.1 tire combo. My Der. hanger is pretty wonky and sort of fragile now so I ordered a Wheels Mfg hanger and will throw it on. Its a week or two before my next trail ride so no rush there and I have the spare the Airborne sent me with the bike if something comes up.
    The bars and clamp match color perfectly.
    The Orange decal is a little bit more "faded" looking compared to the anodized orange, but close enough.
    The orange gets deeper in the sun and makes the difference a little more drastic than it normally is.
  34. #434
    Aug 2013
    Skyphix, you have a NICE ride sir! Looks great!
  35. #435
    Thanks Chicken! I'm hoping to hit some more famous semi-local trails after this weekend to test out the wider bars. It will be nice to more easily drop the seat height. I think it will help my lacking confidence to know that I can bail without getting hung up on the seat but still raise it back up for the long dirt road climbs I like to do without using tools. Not quite a dropper post (can't justify the money) but better than having to use a tool to change seat height. I'm also really liking the bars. I tend to like my bikes to be brighter colors so the Seeker was a departure from my norm but the orange bars help.
  36. #436
    Jul 2013
    Post Your Modified Airborne Bikes-2013-10-1210.16.59.jpgPost Your Modified Airborne Bikes-2013-10-1210.18.40.jpgPost Your Modified Airborne Bikes-2013-10-1210.16.06.jpg
    here's mine. its got a rock shox xc32 solo-air fork, uno +17 degree riser stem and titec el norte 1.5" riser bars. the riser makes the bars look a little funny but its damn comfy to ride for long distances.
  37. #437
    Looks great to me.
  38. #438
    Aug 2013
    "Orange" you glad you got a Seeker?!
  39. #439
    Here's a shot from this weekend of my HobGoblin build. Currently trying out some new tires and a Manitou Tower Pro fork.
    Jeremy
    Attached Thumbnails Attached Thumbnails Post Your Modified Airborne Bikes-jeremy-pod-10142013small.jpg
  40. #440
    Reputation: toddre's Avatar
    Next spring ....
  41. #441
    Nov 2012
    Jeremy, how does that fork compare to the Reba?
  42. #442
    Aug 2013
    And why do you run the fork backwards?
  43. #443
    Initial thoughts are I like it a lot. Need to get more ride time on it for a final call though. The 15mm thru-axle on it is interesting, a little easier to use than the Maxle that was on my Reba.
  44. #444
    LOL, it looks that way but the Manitou forks have the arch in the rear instead of the front. Takes a little getting used to in terms of looks.........
    Jeremy
  45. #445
    Dec 2012
    That was my initial thought too!
  46. #446
    We had Kyle's friend (Mark) bring his Guardian to us to check it over after his crash to ensure the frame was OK and not also damaged. He brought it in yesterday.
    We expected to find a wallowed out or cracked HT and a cracked/buckled DT. Surprisingly enough, the frame was in perfect shape. Even the headset bearings were OK. Guardians are TOUGH!
    Jeremy
  47. #447
    I'm surprised there wasn't any damage to the frame. Really says a lot about the quality of Airborne bikes!
    And, once again, awesome customer service from the Airborne crew! You really stepped up and helped Mark out with his rock solid (rocks are harder than trees, right) Guardian!
  48. #448
    Aug 2013
    Jeremy
    Gotcha - I had to do a double take though initially.
  49. #449
    Aug 2013
    I had to get my baby a new pair of shoes - Origin 8 Ultralight platforms at 273G. They are just under one inch narrower than the generics I am taking off the bike, but a heck of a lot lighter with larger pins. The grip is absolutely fantastic!
    And on the bike...
  50. #450
    Jul 2013
    And on the bike...
    How do you put those on the cranks? Not with a pedal wrench I presume.
  51. #451
    They take a 6mm allen from the end of the axle that sticks through the crank. I also have these on one of my bikes, they are grippy and light.
  52. #452
    Aug 2013
    Quote Originally Posted by JohnPar5 View Post
    Yep, 6mm allen wrench from the inside. Awesome pedals!
  53. #453
    Sep 2013
    Likely a huge Allen through the crank from the back.
  54. #454
    Nov 2012
    Nobby nic front and back. Raceface single speed cranks (tires and cranks installed last week). Manitou minute expert (installed last year)
  55. #455
    Oct 2012
    Anyone running 2.3 tires on a new Goblin?
  56. #456
    Nov 2012
    Which tire are you looking at? I run a 2.25 ardent in the rear with plenty of room.
  57. #457
    They fit. I've got 2.3 WTB Wolverine's on my silver Goblin.
    Jeremy
  58. #458
    Oct 2012
    I'm not real sure. Was thinking about the 2.35 Ikon.
  59. #459
    Reputation: Fuglio's Avatar
    Quote Originally Posted by jhazard View Post
    The Taka:
    Stock Taka Frame - paint stripped to raw aluminum, no clear coat.
    SHE LIVES!!!
    After me cracking my frame and JHazard getting a new one. He gifted me his old one. A really cool thing of him to do an I cant thank him enough for it.
    The frame is a Big Bad Burly Airborne Taka. This frame has seen some serious use by Mr Hazard and its still going strong. Airborne makes frames that are built to LAST!
    1. 1.5 Headtube
    2. 83mm BB
    3. 150mm rear axel
    4. 8" travel
    5. 66 HA
    6. single piviot goodness
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0d06b6a4-8d78-4fc5-80ce-c30855c226a7.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0d06b6a4-8d78-4fc5-80ce-c30855c226a7.jpg" border="0" alt=" photo 0d06b6a4-8d78-4fc5-80ce-c30855c226a7.jpg"/></a>
    I needed a new BB for the frame. The theme was Bomb proof so i went with the howitzer.
    <a href="http://s34.photobucket.com/user/mrpea9999/media/9ef8f84b-3133-4dfa-b13f-a6607d2c328b.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/9ef8f84b-3133-4dfa-b13f-a6607d2c328b.jpg" border="0" alt=" photo 9ef8f84b-3133-4dfa-b13f-a6607d2c328b.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/1101132026c.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/1101132026c.jpg" border="0" alt=" photo 1101132026c.jpg"/></a>
    So for the drive train I got a Wolf tooth narrow wide 30tooth chain ring. Out back I'm running a 11-34 cassette on a saint 9 speed derailleur. Since I have the narrow wide chain guard i decided to only use the top half of the chain guide. The DMR viral chain guide has separate pieces so if need be ill throw the bottom on
    <a href="http://s34.photobucket.com/user/mrpea9999/media/ed4333fc-7338-459e-95e9-dadd6a1e6f18.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/ed4333fc-7338-459e-95e9-dadd6a1e6f18.jpg" border="0" alt=" photo ed4333fc-7338-459e-95e9-dadd6a1e6f18.jpg"/></a>
    For brakes i got saint and zee. very happy with them. I love the mineral oil. I'm a messy dude and still learning how to bleed so the corrosive fluid normally used is a headache I'm happy to do without. Also my old pads were a "little" worn out
    <a href="http://s34.photobucket.com/user/mrpea9999/media/1102131055a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/1102131055a.jpg" border="0" alt=" photo 1102131055a.jpg"/></a>
    The fork is a rock shox totem 180mm travel 40mm stanchions. best fork ever
    <a href="http://s34.photobucket.com/user/mrpea9999/media/1103130839.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/1103130839.jpg" border="0" alt=" photo 1103130839.jpg"/></a>
    All in All the bike came out looking real good. The rear wheel is an Azonic outlaw front is a spank stiffy 40 on a hope hub both tires are continental Der Kaiser 2.5s. Handel bars Easton havoc carbons with Northshore grips and a truvative 50mm stem...
    <a href="http://s34.photobucket.com/user/mrpea9999/media/c094939f-c344-480f-a178-f3ea9fb0f9c1.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/c094939f-c344-480f-a178-f3ea9fb0f9c1.jpg" border="0" alt=" photo c094939f-c344-480f-a178-f3ea9fb0f9c1.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/44e54ad9-d7f6-4e35-b2c3-de84ab7ed9ff.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/44e54ad9-d7f6-4e35-b2c3-de84ab7ed9ff.jpg" border="0" alt=" photo 44e54ad9-d7f6-4e35-b2c3-de84ab7ed9ff.jpg"/></a>
    Action shots On the way
  60. #460
    Nov 2012
    Got the RF 30t on and love it so far. It's a little noisy abs can't figure out if its the tooth profile or the chain line (it makes noise on the the cogs).
  61. #461
    Aug 2013
    Its the chainring itself trevor - since the wide section engages the chain more, you get a bit of noise from the mesh. I did another ride today on the race course and improved my mph to 34.6 on that 30T - I think she is a keeper.
    The bike looks great trevor!!
  62. #462
    Reputation: Gibster's Avatar
    Jun 2013
    Not so much a bike mod but an attitude mod!
    Sent from my GT-N8013 using Tapatalk 4
  63. #463
    Aug 2013
    Not sure if this counts as a mod, but my taint sure does! OUCH!
    Taint_nothin_but_a_taint_thang by s0ul_chicken, on Flickr
  64. #464
    Feb 2013
    Ouch! Looks like a great excuse for your next upgrade.
    Sent from my Nexus 4 using Tapatalk
  65. #465
    Aug 2013
    Quick Silver Goblin upgrades
    So far all the upgrades to my QS Goblin:
    Race Face 30T chainring running 1x10
    Race Face 70mm stem
    Clean Sweep rotors in lime green
    FSA Headset
    Origin8 Proform UL pedals
    Crank Bros. Cobalt 3 XC riser bars
    Crank Bros. Cobalt 2 400mm
    Murdered wheels and tires - except for the Green G!!
    Seat TBD - the Titanium seat I put on there is JUNK - very uncomfortable
    Onto all of the pictures!!
    And now it is time to point her downhill and RIDE!! Have a great day everyone!
  66. #466
    Oct 2012
    What makes your seatpost uncomfortable?
  67. #467
    Looking great Chicken! Hoping to be able to post a similar recap in the next few weeks.
    Eric
  68. #468
    Feb 2013
    Bike looks great Soul man! What is the width of the bars? How do you find them?
    Saddle wise I'd recommend adding the charge spoon to your shortlist.
  69. #469
    You need some of the green FSA plastic headset spacers!
    Bike looks great~
    Jeremy
  70. #470
    Aug 2013
    Either I am too used to the San Marco (which is almost identical to the stock seat on my Giant), or there is too much padding on that Ti seat. Either way, it didn't "sit" right.
    Thanks sky! I appreciate that!
    Quote Originally Posted by coxinio View Post
    The width of the bars is 700mm, and I found them on theclymb.com - which is like an outlet for leftover stock. They don't carry a whole bunch of stuff, but it does rotate. My wife actually showed me the site, but I do search quite extensively on all the big box sites like JensonUSA and so on. I am a component sale junkie!
    I will look into that saddle you suggested - thank you!!
    Bike looks great~
    Jeremy
    Ooooh! Now that is a great idea!! I need some new bar ends as well, the stock ones for the airborne bar do not fit.
    Thanks Jeremy!
  71. #471
    The saddle I use on all of my personal bikes is the Selle Italia Flite Ti. I know everyone is different but I prefer the narrow shape and longer profile.
    Jeremy
  72. #472
    Aug 2013
    That is a nice saddle, Jeremy - I have that one on my radar now. I also found a ten pack of those FSA poly spacers, and forwarded that to the Mrs. for a nice stocking stuffer.
    For the bar ends, I think I might have to splurge a bit and go with some custom caps from PurelyCustom. I think it would be pretty friggin cool to go with the "A" Airborne logo laser etched into the bar ends. They also do custom headset caps as well! Heck, I might as well come up with some kind of logo for a cap while I am at it.
  73. #473
    Jul 2013
    Latest Mods
    Added new skewers, seatpost clamp, saddle bag, and put original seat back. Thinkong about some tires with more knobbiness, any suggetsions?
    Attached Thumbnails Attached Thumbnails Post Your Modified Airborne Bikes-bike.jpg
  74. #474
    Jan 2013
    Really like the new decals on that silver frame. I got mine over the summer but it had the same setup as my original black frame.
  75. #475
    Dec 2012
    This is my ride
  76. #476
    Dec 2012
    Mike in minn.... where you at in mn?? Assuming minn means Minnesota...
  77. #477
    Dec 2012
    Up north in the Brainerd area. The Cuyuna trail system is where I ride most often.
  78. #478
    Dec 2012
    Nice! I'm in grand rapids. I've been down to cuyuna a couple times this past summer, pretty sweet trail system ya got down there!
  79. #479
    Dec 2012
    Maybe I'll see you there sometime then. While Airborne is selling quite a few bikes, if I see another one there, it will be a first....and it will probably be you. You can just yell a 'howdy' while you're passing my sweating, gasping carcase.
  80. #480
    Aug 2013
    Great looking bike Mike! Welcome to the family!
    Quote Originally Posted by Greenkeep View Post
    I used three stickers from a sticker sheet, mine came just like yours. One on the top tube, a nice big one above the BB, and the seat tube to cover scratches where the FD was mounted.
  81. #481
    Dec 2012
    Quote Originally Posted by MikeinMinn View Post
    Will do!
    I also haven't seen any other airbornes in mn. I ride in Duluth/superior a lot and I think there's a lot of "die for their lbs" types there. I saw a guy with a specialized "s" tatt on his calf once....wow. Oh well I like being unique and not having a big 3 bike
  82. #482
    Sep 2012
    This is my ride
    Nice looking rig!
  83. #483
    Mike, is that the standard fork? Looks mighty leggy from the picture. What kind of pedals are you riding?
    This is my ride
  84. #484
    Dec 2012
    Quote Originally Posted by BodyLinksystems View Post
    Nice looking rig!
    Thanks. I've had the bike for over a year now. A few mods:
    HSX rotors + organics
    Black Flag Pro wheelset
    S-Works Renegade 1.95 tubeless in back
    S-Works Fasttrack 2.20 tubeless in front
    ODI Ruffian lock on grips
    MG-1 Pedals
    1x10 (still trialing it but I'm sure enjoying the 24.5lb bike weight)
    Plus several scratches, scrapes, and a broken axle on the bike and a big grin on me.
  85. #485
    Dec 2012
    Quote Originally Posted by akaHector View Post
    That is the stock Reba RL.
    The pedals are Wellgo MG-1
  86. #486
    Dec 2012
    Are you running a 30t ring for your 1x10? How do you like it for the cuyuna terrain?
  87. #487
    Dec 2012
    My trial "1x10" setup is the stock inner ring. By next Spring, I'm planning on a 30T narrow/wide and an X9 type 2 RD. Surprisingly, even just the stock 24T ring hasn't caused my chain to come off yet, but I haven't taken it on any crazy lumpy stuff either. I believe it when others have said that it's just a matter of time...
    This trial was mainly about weight. I wanted to see if the bike would really lose a pound by taking this route. I also wanted to verify my suspicion that I wouldn't miss the 38T. So far, I like it. But next spring's riding will provide more certainty.
  88. #488
    Nov 2013
    I was looking at the same tires, did you try them yet?
  89. #489
    Oct 2012
    Quote Originally Posted by Clever Handle View Post
    Not yet. Waiting on Santa to deliver.
  90. #490
    Dec 2012
    What rims will you be running them on? I'm running arch ex and am curious about how it would work with a 2.35 tire. Anyone else have experience with stans arch/crest and wide tires?
  91. #491
    Hi! Here's my Goblin at Glory Hole Recreation Area at New Melones Reservoir in Angels Camp, CA on April 27th, 2013.
    Mods: Mavic Crossmax ST 29er wheels w/ Continental X-King 2.2 rear and Mountain King 2.2 front set-up tubeless. I've since went Mountain King both front and rear and I love this wheel and tire setup. Other changes include a Bontrager Affinity R saddle and Thomson Elite setback post with Thomson collar. The bike's around 26-1/2 pounds.
  92. #492
    Aug 2013
    Very nice! Looks great perturbo!
  93. #493
    Oct 2012
    Finally made a chainstay protector out of an old tire tube and a few zipties....still loving my guardian!!
  94. #494
    Dec 2012
    Quote Originally Posted by Bionikbear View Post
    Ingenious idea! I use gorilla tape for mine...cheap and effective
  95. #495
    This is basically what I did for my bikes... Split an old road tube and wrapped two sections around it, then did a nice electrical tape wrap over the whole thing rather than zip ties. Works awesome.
    As a side note, I really like your handlebar setup. The gold and red works really well.
    Eric
  96. #496
    Oct 2012
    thanks its a raceface turbine bar and odi grips. ive been looking at shortening up the stem, and keeping with the red and gold theme with a red raceface atlas stem maybe 65mm
  97. #497
    Sep 2012
    I also like the Gold and Red combo , and I am certainly NOT a 49ers fan!
  98. #498
    Jul 2013
    Anyone upgrade the headset on a Guardian 2.0?
    Does Race Face have one that will fit?
  99. #499
    Oct 2012
    ha agreed most certainly not a 49ers fans at all just getting gawdy as i get older so gold goes on everything!
  100. #500
    Hey, not a 9ers fan either but my backup bike is red gold and black... It just works!
    How do you like the turbine bars? I run orange turbines with a 90mm stem on my seeker and really enjoy them. Can't go much shorter with the stem but I'm thinking the next bike will be designed for long top tube/short stem. Nice bike!
    Eric
Members who have read this thread: 19
