    New goblin issues
    I just revived my new goblin. All went together well but it doesn't shift right. In 10 in the rear and 2 up front the front chain rubs. Also the chain has fallen off the 10th sprocket and gets wedged. This is less then 10 min of riding but do I really need to readjust everything this quickly!?
    Reputation: zukrider's Avatar
    gotta remember, china put it together. plus its good to double check, even your LBS. sounds like you need some finite adjustment.
    also, you will be doing this again and again as the cables stretch and settle.
    where is the rub? likely the front derailleur.
    2012 Airborne Guardian.
    The front derailleur didin't look strait so I straitened it out and adjusted it. It appears to be better for now.. I will ride for a while and see how I fair!
    keeptrollintrollintrollin
    Reputation: codyh12345's Avatar
    YouTube is your friend. Learn how to adjust them properly.... you will do it several times in the next few weeks as everything wears in
