Page 13 of 13 FirstFirst ... 3910111213
Results 601 to 618 of 618
  1. #601
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by PWRstroke_smoke View Post
    had my wifey assist with a re measure this morning it's 34
    Based on height and inseam......definitely a 22inch frame.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
  2. #602
    Oct 2012
    Any chance of a 1x10 setup? I've been loving my Niner with 1x10 gear setup and was hoping to get something for my wife. She really likes the simplicity of only one shifter to deal with. I really like the Goblins. (My buddy has one and loves it.) So I was hoping to get a Goblin or Seeker for my wife sometime in the near future. But if I want a 1x10 gear setup then its gets expensive to start pulling things off to replace them.
    So I thought a 1x10 Seeker or Goblin might be kind of nice. Especially if it can be had for under $1000.
  3. #603
    Oct 2012
    It cost me less about $30 to convert my Goblin to 1x10. Not where the impression of it being expensive to do comes from.
  4. #604
    Oct 2012
    Quote Originally Posted by jdhunt0 View Post
    Hmm, My buddy was doing the research on it for his Goblin and he sounded like you had to change out the rear cartridge and derailer along with the front crank. It sounded like you needed a 3 ring crank up front to get a bash ring on.
    What did you do to convert your system and how has it been working?
  5. #605
    Oct 2012
    Check out this thread. Going 1x10 on the cheap!
    A wide/narrow ring and shortening the chain has worked great so far for me and a few others.
  6. #606
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: New Airborne Goblin
    Myself being another! The race face wide narrow set me back $50, but I bought it when it first came out so it has probably come down a bit. Other than that all you need is a chain tool
  7. #607
    Chris Bling
    Reputation: dustyduke22's Avatar
    Hey guys, looking to get my father in law a Goblin Evo. He is 6'2" with a 34 inch inseam. Would he most likely be on a 20"?
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  8. #608
    Reputation: KrazyKreitzer's Avatar
    New Airborne Goblin
    Quote Originally Posted by dustyduke22 View Post
    Those sound very similar to my measurements and I ride a 20".
  9. #609
    I think for the Evo I'd go with a 22 and a really short stem. I ride a Seeker 20" now and am roughly the same measurements as your father.
    Eric
  10. #610
    Chris Bling
    thanks man.
  11. #611
    New Airborne Goblin
    Quote Originally Posted by skyphix View Post
    Just curious why you recommend a 22"? I rode a 22" Goblin and it felt huge compared to the 20". I personally didn't like it.
  12. #612
    I think a 22 Goblin would be too big for me as well, but the Goblin is designed as an XC bike so a longer stem is appropriate. With a trail bike I'd like to let the top tube dictate the reach and run a short stem. Good feed back and quick steering despite the slack headtube. Plus, less exposed seat post means a stronger overall setup. Really I think 6'2 with a 34" in seem like we are is probably smack dab between the 20 and 22 size and either can work. It becomes a matter of preference.
    Eric
  13. #613
    Aug 2010
    I'm also 6'2" and have 34" inseam. When I ordered my Goblin they recommended the 20" model.
    I still made a few fitment changes... specifically wide riser bars and a 70mm stem so it'd feel more like my dirt bike. The riser bars made the most difference and I almost didn't install the short stem but I decided to try it anyway. I ended up liking the way it handles in really tight singletrack with the short stem so I think it's staying for now.
  14. #614
    I am 6'4" with a 33 1/2 inseam. I was recommended a 22 because of my long reach. I was on a 21.5 Fisher before. I feel really good on my bike. I have added a shorter stem and have wider bars ordered to try out.
    Sent from my Nexus 5 using Tapatalk
  15. #615
    Feb 2014
    Big Daddy can you give me the bottom bracket size for a Goblin got the frame for a build up but forgot to copy the size . I know it's BSA but that is all.
  16. #616
    Dec 2012
    Big Daddy Flyer (Jeremy) has moved on. Eric from Airborne has been checking in here once in a while to answer questions.
    Anyway, I think that it's a 68/73mm.
  17. #617
    Quote Originally Posted by MikeinMinn View Post
    Yes, that's correct.
    Jeremy
  18. #618
    Feb 2014
    Thanks for the help.
