Results 1 to 12 of 12
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Need to service Quanta rear hub...
    ...as I am starting to get some irregular noise from it. Has anyone taken these hubs apart for servicing? I am having a very hard time finding any real information out there, so any help to point me in the right direction would be greatly appreciated!
    Aug 2013
    My rear hub is making noise too. It only has 200ish miles on it. I'm just going to take mine to a shop since I don't know much about the hubs yet. I'm interested to see what you find.
    Dec 2012
    I've had mine apart. First the caps had to come off using some Allen wrenches. Then I used a rubber mallet to tap the axle out which also presses the far bearing out as well. Then I used a large bolt (if I remember right) to tap out the other bearing.
    Since I had mine apart for a broken axle, I didn't have to find replacement bearings. So I can't help you there. But once you have it apart, it is fairly simple.
    Dec 2012
    Incidentally if you find you also have a broken axle (unlikely although your bike has seen its fair share of wrecks), when/if you replace it with the cro-mo version, be sure that the little spacer that rides on the stock aluminum axle has come out before you install the new axle. The cro-mo ones are machined so that they don't require the spacer.
    Reputation: BigDaddyFlyer's Avatar
    Sometimes rear "hub noise" is from other things. First thing to check is the rear skewer. Sometimes they can get noisy. Then next check the cassette to ensure the lock-ring bolt is tight.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Aug 2013
    Quote Originally Posted by MikeinMinn View Post
    When you tapped out the axle, was it toward the non-drive side?
    Good to know Mike! And yes, I have had my fair share of wrecks... so that is another reason to check the hub/axle. I am still really new to the sport, and I am a hard learner!
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    Check and check - I will take the wheel off tonight to check the cassette lock-ring as I just added the OneUp 16T last week, and double check the skewer.
    Post edit - mileage since August purchase is 1250 miles - not sure if that is another good reason or not to tear into the hub...
    Dec 2012
    Quote Originally Posted by s0ul_chicken View Post
    I wish I remember that for sure, but my recollection is that it doesn't matter.
    Aug 2013
    I got the axle out, but it took a bit more than a tapping (yikes!). Axle is fine, bearings are in great shape, so I put it all back together and the noise that I was hearing went away. I couldn't get a chro-mo replacement in town here, so I will have to order one off the net instead for the next time I decide to take it apart.
    Glad it was probably just a grease and torque issue!
    Eric
    Dec 2012
    Glad to hear that everything's fine.
    Give Airborne a call. They had them in stock when I did mine.
    As for my use of the term 'tapping'...well, OK, somewhere between tapping and pounding That first time I was kind of nervous too.
    The cro-mo axles are warranty stock we have are for any warranty issues that may arise. We don't carry them for sale to the general public, sorry.
    Jeremy
    Aug 2013
    All I need to tackle now is a fork rebuild!
  1. Replies: 9
    Last Post: 02-18-2015, 11:34 AM
  2. Replies: 3
    Last Post: 05-16-2014, 04:32 PM
  3. Green Goblin Quanta hubs adjustable?
    By perturbo in forum Airborne
    Last Post: 12-11-2012, 12:13 PM
  4. Hadley rear hub service
    By flagrider3 in forum Wheels and Tires
    Last Post: 10-10-2012, 11:22 AM
  5. Q: Fox rear shock service kit
    By beanbag in forum Shocks and Suspension
    Last Post: 08-12-2012, 12:24 PM
Members who have read this thread: 4
