Results 1 to 14 of 14
    Aug 2013
    Lubing/Greasing new Airborne Bike.
    The search function on mtbr seems to be a little funky, won't show any results and google isn't showing that this question was asked before but I apologize if this question has already been asked. So I'm getting my new Airborne Seeker in the mail today but I am wondering what, if anything, has already been greased on the bike. Is there anything I should disassemble in order to apply grease to threads? Thanks guys.
    Nov 2012
    Everything was greased on my goblin when I first received it. Just grease the pedal threads.
    May 2012
    I also grease my seat post.
    Thinking back maybe I should have put a little grease between the stem and handle bars?
    Nov 2012
    Yea I greased the seat post too. Forgot that one.
    Aug 2013
    Thank you very much for the responses.
    May 2013
    Quote Originally Posted by trevor_b View Post
    Any brand you would you recommend specifically for seat grease/lube?
    Nov 2012
    I use Phil wood grease for everything.
    Aug 2013
    Phil Wood, for sure. I think the only things I had to grease were the pedal threads and seat post. You'll want to lube the chain, too, with your choice of lube.
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    What did you guys use to remove the factory stuff off the chain? No matter what I have tried, the chain is still sticky.
    Aug 2013
    Quote Originally Posted by s0ul_chicken View Post
    No need to remove it, really, but if you want to a citrus degreaser and a spin through a chain cleaner would remove it.
    That factory lube is great if you don't live where its dry and dusty, but around here it just collects grit. I usually soak my chains in mineral spirits to get the factory lube off. Let it dry, and them relube with Finishline Dry or Pedros Icetech Wax.
    Aug 2013
    Thanks guys, and yep, it's dry and dusty here in the high desert so getting that much off there is on the Priority List! Now all I need to do is get that damned Powerlink to release...
    Reputation: BigDaddyFlyer's Avatar
    Pick up a set of these:
    Park Tool Co. MLP-1 : Master Link Pliers : Chain
    They are worth their weight in gold if you have ever struggled to get a power link apart. They make things so simple and quick.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Re: Lubing/Greasing new Airborne Bike.
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    :thumbup:...and they work great on the 10-speed PowerLock links!
  1. Airborne Guardian Vs Airborne Zeppelin Elite
    By ATVMXR in forum Airborne
    Last Post: 01-25-2014, 03:03 PM
  2. Cleaning and lubing a cassette body
    By Dr.Mushy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2012, 08:42 AM
  3. Lubing chain - newbie question
    By sanjayc in forum Beginner's Corner
    Last Post: 01-20-2012, 11:31 AM
  4. Lubing Locks - What do you use?
    By highdelll in forum Commuting
    Last Post: 10-08-2011, 08:12 PM
  5. cleaning amd lubing
    By blkcheerio in forum General Discussion
    Last Post: 04-18-2011, 04:56 PM
