Results 1 to 10 of 10
    Lots of new things to me - this time it's the brakes
    I took a 5.5 mile gravel road shakedown cruise on the new Seeker yesterday. Very happy with it! I have a punch list of fitting and adjustment tweaks, but it's pretty close.
    Hydraulic brakes are new to me, and I'm wondering if I need to bleed the front one at least. The lever feels soft compared to the rear; I don't feel any braking until the lever is 30 - 50% of travel. It was about 24F, and I wondered how the temps might effect them, but the rear was substantially firmer feeling.
    Can anyone describe what a Clyde rider should "feel" with the Elixir 1's? Would it be a good idea to bleed them just as a matter of course on a new bike? Any other hints or tips?
    Bleeding them might not be a bad idea, but my Seeker came the same way. There is a travel adjustment screw just inside the actual lever - that should take out the extra travel and firm up the feel. Its not the "proper" fix but it worked fine on mine. Bleeding only takes about 10 minutes when youdo get around to it.
    As a side note: I am a clyde rider, around 250lbs, and found the Elixir 1's performed fine for most types of riding that are within the scope of an XC bike.
    Eric
    Nov 2013
    Quote Originally Posted by ChuckHubbert View Post
    Give it a few rides...if it is your first set of Hydro brakes they do feel a little different at first..and..at least to me Avids brakes have that feel to them across their entire line-up..
    Sep 2012
    I gave it a few rides and the bled them --which is a gigantic PITA, by the way. It's nearly impossible to suck air in the lines past the Elixir's ports/o-rings. The threads are not spot on.
    Even with a bleed kit, you might want to check into extra o-rings, and softer material for the threaded barbs (M5). The O-rings get torn up after each bleed so think of them as disposable.
    Dispose of your spent fluid properly.
    Quote Originally Posted by BodyLinksystems View Post
    Hm, really? I've blend XO on a buddies bike and the Elixir 1's that were on mine and didn't really have much trouble getting the air past the ports. It did take a while with the XO's because they were FULL of air but my Elixir 1's had just a few bubbles.
    I don't use the Avid-brand bleed kit though, I use this one
    Amazon.com: Avid Disc Brake Bleed Kit, Elixir, Code, Juicy, USA: Sports & Outdoors
    Works great as long as you dip the plunger in brake fluid before trying to bleed. Helps it seal inside the syringe so you don't end up sucking air past the plunger.
    Eric
    Sep 2012
    yeah, I've done bleeds before. Maybe it was my kit from BleedBicycles.com but it was a super pita and I was totally set up to do it fast in my shop. Oh well.... have to find more o-rings to give it another go.
    Sep 2012
    Just an update: I contacted BleedBicycles.com regarding my o-rings and they sent me a bunch of extra o-rings AND whole new kit that same day and even offered to send me the pro syringes when things slow down after Christmas.
    Super impressed with the customer service, so if you're thinking of getting a bleed kit I would feel confident about getting one from them.
    That is the bleed kit that I use, been very happy with it, good to know their customer service is top notch as well.
    Eric
    Sep 2012
    Just to follow up on BleedBicycles and the Pro kit I was promised: It never arrived and further attempts to contact them yielded nothing.
    Nice to offer something, but they should follow up either way.
    Jun 2014
    back to the OP's question. My seeker came the same way. I adjusted the lever position with the screw and rode it for a while. Once the pads bed in, the brakes feel better. I did clean the rotors with alcohol and that made them feel a lot better. I suggest you do that to both brakes.
    Bleeding them is involved and you need a "bleed kit" and some new fluid. There is a how to do it video on SRAM's website and must watch that before doing it, unless you have prior experience. Not to jinx your new bike, but the Elixir brakes have quality problems, so if they lock up or malfunction, contact Airborne for a waranty issue.
    In terms of feel, they will be a little spongy at first until the bed in after 2-3 rides. Cleaning them firmed them up quite a bit for me.
  1. Replies: 16
    Last Post: 08-05-2014, 02:49 AM
  2. Upgrade time (HT to FS) lots of questions!
    By Double~D in forum Bike and Frame discussion
    Last Post: 10-02-2013, 04:18 PM
  3. Replies: 97
    Last Post: 10-31-2011, 02:39 PM
  4. Replies: 0
    Last Post: 04-27-2011, 05:55 AM
  5. Replies: 0
    Last Post: 04-27-2011, 05:45 AM
