Results 1 to 39 of 39
    Captain Climber
    Reputation: Jem7sk's Avatar
    Jan 2013
    KMC Z-72 on SkyHawk
    Anybody know how to remove this chain? I cannot find any info on it. Looks like it has a master link but I am not sure.
    Reputation: Mitch1171's Avatar
    Jan 2009
    Why are you removing the chain?
    Captain Climber
    Jan 2013
    I wanted to take it off to clean up my drive train while the bike is out of commission. Looks like it will take a missing link but what is on it now doesn't look like a missing link.
    Jan 2009
    Simple green!!!! Its works great!
    Resident Gear Head
    Reputation: provin1327's Avatar
    Mar 2013
    Can't you just use a chain breaker on any piece of the chain?
    2 Hands Working Do More Than 1000 Hands Praying
    Captain Climber
    Jan 2013
    I probably could but if this is made to be some sort of master link I'd prefer to use that. I was hoping someone knew something about these chains. They are only $10 on Amazon. I cold buy a spare and change them out every week. Clean the other one real good and lube real good and then switch them etc. there is a ton of sand here and my drive train gets gritty. I like to take things apart and figure them out good so I can fix something fast when needed and keep it super clean and in new condition.
    Dec 2012
    It should have a gold link that is the master link. Just take the pin out of it. It should just come of after that.
    -Airborne Skyhawk
    -2000 Raleigh M30
    -2008 Cannondale Rush 6
    Captain Climber
    Jan 2013
    It's not gold but ill give it a try. I noticed they sell a ss pack of missing links on amazon for $10. Might have to get those and switch out. Thanks
    Dec 2012
    KMC Z-72 on SkyHawk
    Quote Originally Posted by Jem7sk View Post
    Ok. Sorry just thought it might be because my master link was gold
    -Airborne Skyhawk
    -2000 Raleigh M30
    Resident Gear Head
    Mar 2013
    You could swap one of the links for a Sram powerlink
    Mar 2013
    I didn't mess with it to confirm what it was, but I could swear I saw a gold master link on mine.
    Earnest Hemingway once said "The world is a fine place and worth fighting for." I agree with the second part.
    Captain Climber
    Jan 2013
    Ill have to get a pic of it and post
    Captain Climber
    Jan 2013
    Here is a couple of pics:
    Dec 2012
    KMC Z-72 on SkyHawk
    Yes there is a gold plated master link on that chain
    -Airborne Skyhawk
    -2000 Raleigh M30
    Captain Climber
    Jan 2013
    Quote Originally Posted by sfb12 View Post
    So push that pin on the left out with a chain breaker?
    Captain Climber
    Jan 2013
    FYI, this is what I did. Popped right out. Soaked (and shook)it in some 2 cycle gas for a few minutes since I didn't have any diesel like Zinn recommends. Washed my bike, cleaned up the drive train, put it back together and tuned it up and lubed it. Seems to be as good as new! I'm going to try to get back on the trails tomorrow.
    Dec 2012
    Glad it all worked out for you and sorry I could help more I just didn't have the answers for that. Hope it rides well after that.
    -Airborne Skyhawk
    -2000 Raleigh M30
    Captain Climber
    Jan 2013
    Thanks sfb12.. Actually it was what you posted that gave me the confidence to go for it. My chain was twisted up from breaking the hanger and I just couldn't get it un twisted without taking the chain off. I figured a new chain is only $10 so if it didn't work I'd get a new one. I think I might get another chain any way if I don't have any problems with this master link and ill rotate them out to extend the life of my drive train.
    Captain Climber
    Jan 2013
    Damn master link... Whatever it is just broke. I ordered a new KMC z72. Can someone recommend a reusable master link for this chain so I can switch out these two chains when I want?
    NeedGod.com
    Reputation: Barheet's Avatar
    In my experience, KMC chains are total junk. You can't break them without the chain cracking or something and the master links are a joke. Also, I've never had one hold out for long on the trail. Order a SRAM chain instead. You'll be much happier.
    Nathan
    Jan 2009
    Chris If I may. You are to hard of a rider for that bike its time for a hobgoblin! LOL does this mean you wont be at the trail sunday? Hope to see ya there and you get that thing fixed.
    Captain Climber
    Jan 2013
    Quote Originally Posted by Mitch1171 View Post
    You may be right Mitch! I'm going to have to sell my Corvette so I can afford one. I am hoping to make it at least a year on this bike before I upgrade. If the new chain is not here by Saturday I may break the chain and bypass the master link thing and just use a pin.
    I want to ride dammit!
    Captain Climber
    Jan 2013
    Quote Originally Posted by Barheet View Post
    Hey Barheet, which entry levelish Sram chain do you recommend. Does it come with a reusable master link?
    I think this is why your master link broke. to open a master link you usually squeeze the two side plated together, and while doing so, compress the link lengthwise, so you are pushing the pins toward one another. A pair of park master link pliers make it easier.
    Park Tool Co. MLP-1 : Master Link Pliers : Chain
    If yous chain is still in good shape you can get a new masterlink for about $5.
    Dec 2012
    KMC Z-72 on SkyHawk
    I also semi agree with this. I hear of much better luck with SRAM then most KMC chains
    -Airborne Skyhawk
    -2000 Raleigh M30
    Captain Climber
    Jan 2013
    Swildnm... Thanks for the advice. I'm not sure this is a typical master link though. I think it is some kind of one time use thing. I did try to remove it like you said but it wouldn't budge. Not much info on this thing. I will get a regular master link for it though. Got ny recommendations?
    Dec 2012
    KMC Z-72 on SkyHawk
    It was supposed to be a reusable there is no reason for a quick link unless it was reusable. They make link replacements which will be your best bet. But if you were going to change chains your best bet is SRAM or sometimes shimano
    -Airborne Skyhawk
    -2000 Raleigh M30
    KMC's master links are called "Missing Link" But I bet a SRAM link would work just fine.
    NeedGod.com
    I have no idea what the model number of my chain is. I just pick up my chains at my LBS and they are about $35 for the SRAM ones. I think the link on SRAM chains is called "gold link" or something similar.
    Nathan
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by swildnm View Post
    This.
    If you try to push the pin out sideways you will destroy the masterlink.
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Would you put a low end driveshaft on the Vette? Love your bike. Buy a good Sram chain. Top of the line is what, $60.00?
    BTW: I'll buy the Vette for the cost of a Hobgoblin XO and throw in an extra $500..
    Captain Climber
    Jan 2013
    Quote Originally Posted by BigDaddyFlyer View Post
    This.
    Man, I'm confused Jeremy... What kind of chain came on my bike. Your website says it is a KMC Z72 but I just got a new one of these and it is not the same chain. The one on the bike says OCTA on the chain.
    The new KMC I just got has a reusable Missing Link with it that is very easy to put on and remove. I think this chain is slightly narrower than the one that came with the bike. When I put the chain together to measure how much to cut off it was off by half a link at the length of the original chain. This new KMC chain seems to work fine on the bike though. Just need to know what chain came on it to figure out hat master link to get for it.
    Captain Climber
    Jan 2013
    Captain Climber
    Jan 2013
    Quote Originally Posted by drjay9051 View Post
    Through in five more Hobgoblin XOs and you've got a deal... Actually, I should ask for 18 Goblins and ill be able to jack up the price when Airborne runs out soon
    Substitutions can and do happen at the factory during production runs. Sorry for any confusion.
    Jeremy
    Feb 2013
    Jem7sk did you manage to get the chain off in the end?
    I was cleaning mine today and decided to take it off the bike, if you've sorted it great, if not you need to locate the link and flex the chain, you should hear a click which will be the link popping off, I had to lever a flat head screwdriver in to separate them as it was a little fiddly.
    Popping it back on was just as easy, I've used SRAM and KMC quick links before but they can be difficult to get off without the correct tool, so I'll be sticking with the Taya link.
    Captain Climber
    Jan 2013
    Thanks coxino... I ended up breaking the Taya link and putting on a KMC Z72. It came with a missing link that works beautifully. I am going to get another on of those links and use with the taya and rotate these two chains. I am also going to get a pair of master link pliers to make the job easier.
    I still don't know how that original Taya master link works... Did you happen to get a pic of it disconnected?
    Feb 2013
    Sorry didn't manage to get a pic but this youtube vid might help https://www.youtube.com/watch?v=xW8dSXft-MQ
    Captain Climber
    Jan 2013
    How about that... Well, now that I know it is a Sigma Connector I found this vid too. Hopefully these two vids will help others. Wish I would have known all this last week
  1. Skyhawk and my Size
    By trailbikerider in forum Airborne
    Last Post: 04-22-2013, 10:58 AM
  2. Finally got my SkyHawk
    By Jem7sk in forum Airborne
    Last Post: 04-16-2013, 10:25 AM
  3. Help sizing a Skyhawk
    By luckycaribou in forum Airborne
    Last Post: 04-14-2013, 05:17 PM
  4. Ordering SKyhawk soon
    By dbigfot111 in forum Airborne
    Last Post: 02-26-2013, 07:52 PM
  5. Skyhawk!
    By backcountryeti in forum Airborne
    Last Post: 01-01-2013, 03:21 PM
