Results 1 to 3 of 3
    Reputation: hrbib21's Avatar
    Apr 2013
    Hydraulic Brake Mineral Oil
    What kind of mineral oil is in the Guardian brakes? I assume it isn't the drugstore kind. One of my levers is quite loose, I have to pull it in quite a bit to get it to grab, so I want to do a bleed.
    CoolArrow
    Reputation: jhazard's Avatar
    Tektro advises against it:
    "...Tektro disc brakes are designed to be used with only Tektro brand mineral oil. Tektro uses a special additive to increase the temperature range and red color for ease of identification"
    TEKTRO BRAKE SYSTEMS
    While you can probably get away with drug store mineral oil, it's probably not the best practice. You can get an entire bleed kit for less than $15:
    Tektro MTB Hydraulic Disc Brake Bleed OIL Service KIT FOR Auriga Auriga Comp | eBay
    and
    Amazon.com: Tektro Mountain Bike Hydraulic Disc Brake Bleed Oil Service Kit: Sports & Outdoors
    Hope that helps!
    Cool BandolArrow
    Jerry Hazard – website
    Reputation: UEDan's Avatar
    If it's anything like Shimano's mineral oil system, DON'T use drug store stuff.
    But at that price for the kit, screw Pentosin have at it.
  1. Mineral oil brake fluid....on the cheap
    By BIGfatED in forum Brake Time
    Last Post: 11-13-2015, 01:11 PM
  2. Rock Shox Reverb hydraulic fluid - mineral oil?
    By shibiwan in forum General Discussion
    Last Post: 09-17-2014, 02:42 PM
  3. Dot brake fluid and mineral oil differences?
    By rjpstoked in forum Brake Time
    Last Post: 06-20-2012, 01:46 PM
  4. mineral oil brake recommendation?
    By jiker in forum Brake Time
    Last Post: 04-12-2012, 09:21 AM
  5. Replies: 2
    Last Post: 03-07-2011, 03:36 PM
