Results 1 to 7 of 7
    Captain Climber
    Reputation: Jem7sk's Avatar
    Jan 2013
    How wide of a tire will fit my SkyHawk?
    I'm going to build a set of wheels and am considering the Sun Ringle Inferno 27 rims at 27mm. How wide of a tire should I put on these rims and will they fit my SkyHawk?
    Reputation: BigDaddyFlyer's Avatar
    The stays have 65mm of spacing between them where the tire sits, which is roughly a little over 2.5 inches. I wouldn't recommend anything larger than a 2.2 inch tire back there if you want to have adequate clearance for mud/dirt/run-out.
    Hope that helps!
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Captain Climber
    Jan 2013
    It does Jeremy.. Thanks!
    Feb 2013
    You should also watch out for clearance of the front derailleur with the wider tire on the back.
    Captain Climber
    Jan 2013
    Yeah, I noticed I am already running close to that but I am removing that and going to 1x9.
    Feb 2013
    Quote Originally Posted by Jem7sk View Post
    1x9 should be sweet, would be interested to see what it takes to switch out and how it rides.
    Captain Climber
    Jan 2013
    I'll keep you posted... Got a few projects planned during the rainy season here in Florida.
  1. Wide rear tire?
    By kragu in forum 29er Components
    Last Post: 12-11-2012, 07:37 PM
  2. Wide, fast XC tire.
    By happybiker in forum 29er Components
    Last Post: 10-15-2012, 09:54 PM
  3. Is my tire too wide for my rim?
    By Two Wheelin in forum Wheels and Tires
    Last Post: 01-08-2012, 10:35 PM
  4. wide tire
    By bnelson in forum 29er Bikes
    Last Post: 11-21-2011, 08:07 PM
  5. Recommend a Wide Slick Tire
    By jakedsnake in forum Wheels and Tires
    Last Post: 07-30-2011, 07:47 PM
