Results 1 to 13 of 13
    Reputation: Gibster's Avatar
    Jun 2013
    Hobgoblin touch-up paint
    Anyone found a good match for our Hobgoblins? Brand, color? I gota nasty spot I want to touch up.
    Sent from my GT-N8013 using Tapatalk 4
    Old Punk
    FYI
    Claire's nail polish has never failed to produce the color I need. You may creep out a bunch of tweens while you are there rifling through the colors though.
    '09 Specialized Rockhopper expert 29
    Born 26" trials
    '07 Specialized Allez
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by Gibster View Post
    If it helps, the color specification# is YS-9547.
    Its fairly close to a Jaguar color they used a couple of years ago. If you go into your local auto parts store that carries touch-up paint, take a look at the Jaguar touch-up paint section.
    Hope that helps,
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Reputation: strfyeing's Avatar
    Mar 2013
    Doesn't help the paint situation, but I got some helicopter tape and put it on the down tube, head tube, chain, and seat stays to help protect the frame. Best part, it's virtually invisible and easy to apply with a little patience. Good info about the color matching, thanks BDF.
    Jun 2013
    Quote Originally Posted by BigDaddyFlyer View Post
    Hope that helps,
    Jeremy
    Thanks BDF for the information.
    Jun 2013
    Hope that helps,
    Jeremy
    BDF is that for the Normandy Blue or the Satin Midnight Black?
    Blue.
    Jeremy
    Quote Originally Posted by strfyeing View Post
    What is helicopter tape?
    Aug 2013
    Same kinda stuff as invisishield for your smartphone screen. It is a transparent high grade scratch resistant film. ISC Racerstape.com Save Your Paint!!! surface guard tape 2"x12' : Amazon.com : Automotive
    Sep 2013
    Do you have the paint code for the white used on the guardians?
    Sorry, I don't have a special code for the Guardian Gloss White, it's just a bright, clean gloss white. Should almost be the easiest color to touch up in our line. Good luck!
    Jeremy
    Sep 2013
    White can be tricky. If you get the wrong shade it looks like dried bird crap.
    Quote Originally Posted by rmcrom View Post
    I understand that, having been a car-nut and bike-nut for years. But white is still easier to find a match for than shades of grey or colors. Plus its non-metallic which makes it easier.
    Thanks,
    Jeremy
  1. Touch up paint?
    By cycleboy in forum Niner Bikes
    Last Post: 05-02-2016, 04:42 PM
  2. Looking for touch up paint
    By yeti575inCA in forum Yeti
    Last Post: 06-06-2014, 02:12 PM
  3. Touch up paint
    By mb2boost in forum General Discussion
    Last Post: 08-14-2013, 10:17 AM
  4. Touch-up paint?
    By neilether in forum Ibis
    Last Post: 10-06-2012, 11:56 PM
  5. touch-up paint
    By Limey Johnson in forum General Discussion
    Last Post: 09-14-2011, 09:29 AM
