Results 1 to 3 of 3
    Hobgoblin torque spec question.
    I just purchased the Hob and love this bike, love it! I have questions regarding the torque specs that are listed on AB website. They list the various specs below.
    Recommended Torques:
    Upper and lower shock pins: 100kg/mm
    Upper Pivot to frame (6802 bearing): 200kg/mm
    Upper Pivot to seat stay (699Z bearing): 90kg/mm
    Lower Pivot to frame (6802 bearing): 200kg/mm
    Lower Pivot to chain stay (6902 bearing): 180kg/mm
    These seem very high. If you convert it to lbs/in it is 11,199.48 and 1265 nm again all way out of range for a bicycle. I thought it was a typo and contacted AB for some explanation. In the mean time what do you all think? My feeling is it should be expressed in kgf/cm which would make it a respectable 19.6 nm, using the 200kg/mm as an example. Your thoughts? Thank you.
    Reputation: OutLore's Avatar
    Aug 2013
    Bringing this thread out of retirement... I have had these specifications stored away for a while - I got them from the Airborne site a while back. They seem really low to me, so I emailed support@airborne tonight to see what they recommend.
    Upper and lower shock pins: 0.98NM 8.67in/lb
    Upper Pivot to frame (6802 bearing): 1.96NM 17.35in/lb
    Upper Pivot to seat stay (699Z bearing): 0.88NM 7.79in/lb
    Lower Pivot to frame (6802 bearing): 1.96NM 17.35in/lb
    Lower Pivot to chain stay (6902 bearing): 1.76NM 15.58in/lb
    Mine has developed play in the upper pivot where it is attached to the frame - almost as though the "tube" on the frame where the pin goes through is worn - at the top of the suspension travel there is a noticeable knock, and play in the suspension, which is causing creaking.
    Hopefully I'll have an answer on the torque settings soon, and I'll update the thread - this was about the only thing that came up in a google search, so it might help someone else in future
    Aug 2013
    Answer from Airborne Support
    Just for future reference, if someone searches for Airborne HobGoblin suspension torque specifications in the future - here's the response from Airborne support:
    Upper and lower shock pins: 09.8NM
    Upper Pivot to frame (6802 bearing): 19.6NM
    Upper Pivot to seat stay (699Z bearing): 08.8NM
    Lower Pivot to frame (6802 bearing): 19.6NM
    Lower Pivot to chain stay (6902 bearing): 17.6NM
    USE Loctite 243 ON THREADS
    Seems the website had the decimal point in the wrong place - I can't find the page any more, but apparently it's been corrected.
  1. Altitude 29 torque spec
    By devil9988 in forum Rocky Mountain
    Last Post: 11-24-2013, 03:49 PM
  2. New pivot torque spec? DT?
    By stumblemumble in forum Turner
    Last Post: 03-27-2012, 08:25 PM
  3. Headset Torque Spec.
    By soontobe29er in forum Giant
    Last Post: 08-20-2011, 06:08 AM
  4. Torque Spec on Lopes Link
    By mdc in forum Ibis
    Last Post: 03-16-2011, 09:13 AM
