Results 1 to 3 of 3
    Nov 2012
    Help Tuning New Skyhawk Bike
    so i finally had a chance to put together the bike, but before putting up the bike i notice 2 tiny scratch, paint scratch pretty much, the disc seems to be bent a little, its no biggie. to summary some mistakes that i made
    -while i was messing around with the calibers trying to adjust it some oil leak off the line, now there is no tension in it, the lever can touch the grip. not a good sign, it does not stop at all how can i fix this problem? and how do i adjust the brake calibers
    - how do i adjust front and rear derailer. Airborne is closed tomorrow. I really want to test out the bike
    thank you in advance
    you might have loosened the bleed screw, might have to rebleed the system. youtube has some video on adjusting derailleur, i used this one to help me adjust mine, Bicycle Maintenance: How To Adjust a Rear Derailleur - YouTube but if you dont feel comfortable doing it yourself, your better off having a shop do it, usually shop charge $15 to $20 for each derailleur
    Reputation: BigDaddyFlyer's Avatar
    Hey there, sorry to hear about your troubles. It sounds like you've loosened the bleed screw and compromised the system by allowing air to get in the line. The brakes will now need to be bled. I recommend to go to a local shop and have them bleed the brakes as it can be a complicated job for a novice bike mechanic, but for a trained mechanic it only take a few minutes with the correct tools. While you are there, have them do a quick tune on the RD since they will have the bike in the stand anyway.
    Sorry again for your troubles,
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
  1. Ordering SKyhawk soon
    By dbigfot111 in forum Airborne
    Last Post: 02-26-2013, 07:52 PM
  2. Skyhawk!
    By backcountryeti in forum Airborne
    Last Post: 01-01-2013, 03:21 PM
  3. Twist Shifters for Skyhawk?
    By MoTec in forum Airborne
    Last Post: 12-11-2012, 11:51 AM
  4. Need BB and crank info for Skyhawk
    By mavtek in forum Airborne
    Last Post: 10-23-2012, 01:20 PM
  5. New Skyhawk! Need some help tuning!
    By Pretty_Lights in forum Airborne
    Last Post: 09-21-2012, 06:01 PM
