Results 1 to 6 of 6
    Jan 2013
    Headset question
    I read through past posts and wanted to confirm what the correct headset for the Goblin. BDF had listed two-
    FSA Orbit C-40
    NO.42/ACB
    I am a little confused, does one replace the other? or they the same, thanks.
    Also when stripping down my existing frame for warranty replacement i had a little trouble with lower bearing removal. After removing the fork i gently tapped the lower bearing from the headtube. The two seals came out along with loose bearings and the crown race. It was then i realized the bearings internal race was still in the headtube(i think). Can anyone confirm the lower bearing is a single complete unit?
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    The lower bearing is one piece (as is the top bearing), and should easily be removed. Mine came out with my fingers, no tools needed.
    Jan 2013
    Your right, mine would not come out as a single unit. Part of the bearing was stuck in the head tube and when i tapped it from the inside it came apart with the bearings falling out of the cage. I got the replacement frame and realized how it was installed because it included a headset.
    Aug 2013
    Hey Greenkeep - did you ever figure out which bearing set you needed? I only ask for records, in case I need to get a replacement in the future.
    Reputation: BigDaddyFlyer's Avatar
    The FSA Orbit C-40-ACB fits both the current Goblin and HobGoblin.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Aug 2013
    Thank you Jeremy!
  1. Headset question
    By JetTeach in forum Giant
    Last Post: 08-31-2013, 10:39 AM
  2. Replies: 7
    Last Post: 08-02-2013, 07:29 AM
  3. Jet 9 RDO headset question
    By Wildebeast in forum Niner Bikes
    Last Post: 01-21-2013, 06:26 PM
  4. New WFO on the way...headset question
    By Leethal in forum Niner Bikes
    Last Post: 09-17-2012, 08:58 AM
  5. Headset Question
    By DJohnson in forum Niner Bikes
    Last Post: 03-29-2012, 01:30 PM
