Results 1 to 13 of 13
    lmw
    lmw is offline
    Apr 2013
    having problems changing my cockpit
    im trying to install my new handlebars and stem for my goblin but i've ran into a few issues.
    1. how do I remove the airborne stem? I took out all the screws, but its still stuck on.
    2. i cant remove the brake levers from the handlebar, the screws seem to have been coated in super glue. the avid manual says use a 4mm hex wrench, which i've been doing, but i can't even get them to budge without my wrench bending or stripping. why are these so hard to remove?
    thanks
    lmw
    lmw is offline
    Apr 2013
    never mind about my first question, i just realized the rubber circle thing pops out from the stem
    still cant figure out these brake lever screws though
    Nov 2012
    They shouldn't be that hard to remove. Mine loosen just fine.
    lmw
    lmw is offline
    Apr 2013
    you are right, they shouldnt be that hard to remove, not sure why both levers seem to be set in stone
    Nov 2012
    Did the shifters come off just fine? One of those two clamps take a torx 20 I think.
    lmw
    lmw is offline
    Apr 2013
    i had no issues removing the shifters. i just tried a torx bit and it fit perfectly, but still neither brake would budge a millimeter. looks like whoever put the brakes on went waaaay too tight..
    Reputation: BigDaddyFlyer's Avatar
    They are torx, as you figured out.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    lmw
    lmw is offline
    Apr 2013
    did you guys use loctite?
    No, I don't believe so. They should be installed with a torque wrench. I can't say why yours may be too tight.
    Jeremy
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Like I said on the other thread, mine were really tight too. I had to spray penetrating oil on them and put the torx bit in my ratchet for more leverage to get them to budge
    Reputation: hrbib21's Avatar
    Apr 2013
    Try PB Blaster overnight.
    lmw
    lmw is offline
    Apr 2013
    i managed to 1 one off after using some penetrating oil, but i ended up stripping the other one pretty badly, oops
    Dec 2012
    Quote Originally Posted by lmw View Post
    Did you use a torx bit or a hex? If you stripped it with a hex you should still be able to get it out with a t25 torx
  1. CX Cockpit Geo Fit
    By LowOnO2 in forum Cyclocross
    Last Post: 12-19-2012, 10:26 AM
  2. Help with cockpit set up
    By dimitrin in forum All Mountain
    Last Post: 12-03-2011, 07:02 PM
  3. 200mm cranks,drive problems,endow problems
    By Realslowww in forum Clydesdales/Tall Riders
    Last Post: 10-19-2011, 04:11 PM
  4. Cockpit Help PLEASE.
    By davis119 in forum Beginner's Corner
    Last Post: 08-26-2011, 08:22 AM
  5. New Cockpit ergonomics
    By dickt3030 in forum 29er Bikes
    Last Post: 02-23-2011, 01:24 PM
