Results 1 to 38 of 38
    Reputation: Rocke's Avatar
    Sep 2013
    Guardian Upgrade question
    I have been told the first thing i should upgrade on my guardian 2.0 are the wheels and the tires? Just seeing what you all thought about the advice given by LBS?
    I mostly ride on technical trails and have been told the current Kenda's will not do me justice...
    Any help is appreciated.
    Jul 2013
    Guardian Upgrade question-airborne-stock.jpgGuardian Upgrade question-img_9599.jpg
    First thing I swapped out was Bars, Stem and Seatpost.
    Then I went to 1x9 with Race Face Cranks and WnW Chainring. I live and ride in Florida and never get out of the middle gear anyway.
    I will eventually swap out the wheels and fork when they start to wear out.
    Resident Gear Head
    Reputation: provin1327's Avatar
    Mar 2013
    Wheels are a great, but very expensive upgrade. Ride the bike for a bit before you do any serious upgrading. Find an area you would like to improve on and upgrade that. Going tubeless is a very easy, cheap, and beneficial mod. As far as what tires to use, ask your LBS or post a thread in your local riding forum (where do you live?) and ask what tires other rides in your area are using. After that, play around with the stem, seat, grips, and bars. Those are relatively cheap upgrades that will benefit the handling and feel of the bike.
    2 Hands Working Do More Than 1000 Hands Praying
    Reputation: hrbib21's Avatar
    Apr 2013
    Cockpit is typically the area you would want to upgrade first unless everything fits to your liking. I have upgraded my handlebars (Truvativ Hussefelt), grips (ODI Rogue), and I'm about to pull the trigger on a shorter stem (Race Face 70mm). I'm also upgrading to a Kenda Nevegal front tire.
    Sep 2012
    I've replaced everything on my Guardian besides frame, brakes, seat post, clamp and stem. Cockpit is the most important to get set up right. After that I'd get the right tires for the areas you ride and then a good fork. I'd do wheels after that.
    Sep 2013
    So I guess go with the cockpit, thank you so much guys. I ride in Nashville mostly, going out to Chattanooga soon hopefully for an excursion.
    Thank again for the quick responses guys, so should i just go to local LBS and try some handlebars and grips?
    And, what is the benefit of a shorter stem?
    Resident Gear Head
    Mar 2013
    I would change grips and stem first. A shorter stem will speed up the steering and get your body farther back. This benefits descending but will move you off of the front wheel which may hinder cornering and climbing. It's all about personal feel. Ride a single trail a few times and get a feel for it. Change the stem and ride that same trail, making note of what changed. Grips are pretty basic. If you like something big, grab a big pair off the shelf and check the feel in your hand. If you like something simplistic, grab something small.
    Sep 2013
    I think Im going to upgrade the Stem Right away, from what you guys have told me and reading more. It would suit me a lot better going with a 60mm or 70mm stem.
    I'm 5-10 - 165 lbs
    Thinking ODI Rogue grips
    Rock face 70mm Stem
    Handlebars??- dont know yet.
    Tried the grips at LBS-feel awesome, but they are charging almost double as Amazon and pricepoint. Want to support them, but thats nuts.
    Sep 2013
    Quote Originally Posted by JohnPar5 View Post
Name:	Airborne Stock.jpg
ID:	832739Click image for larger version.
    Your bike looks awesome btw man
    Resident Gear Head
    Mar 2013
    Quote Originally Posted by Rocke View Post
    I'm 5-10 - 165 lbs
    Rock face 70mm Stem
    Ask them to price match. My LBS matches any price I find online, even when they have to special order stuff.
    It's best to go one increment at a time on stems. I would start at 90mm. Your LBS might have a cheap 90mm stem or they might slap it on there and let you ride around a bit, or allow you to exchange it after a few rides. They know you can't just pick a few items off a shelf and create the perfect fitting bike so they understand you wanting to try many different things, while only changing one thing at a time. If you change too much at once too drastically and you don't like it, you won't know which new item you don't like.
    Sep 2013
    Gonna go in and see if they will let me do that, they are pretty cool over there. Not sure if they are that cool though.
    Thanks for all the advice provin, really helping me out man. New to the whole thing, and just want a good feel.
    Jul 2013
    Thanks Rocke, I am really enjoying it.
    Sep 2013
    Bike shop let me try on some stems on their demo bike which is elevated so I got to maneuver and pedal for a while. 70mm felt like a dream, can't decide which handle bar I like though. Picked up some ODI TLDs though because they felt awesome and looked sick.
    Once, I get my stuff together I'll post some more pictures. Think I might have been to get a nevegal for the front tire...
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: Guardian Upgrade question
    I'm 5-10 - 165 lbs
    Rock face 70mm Stem
    I originally put rogues on my goblin, but recently switched to esi chunky....much better imo. I hated that the rogues have the lock ring on the outside, so the last 3/4" of the grip is rock hard. That's where I put the heels of my hands! But if you usually ride with your hands more towards the center of the bars, they'd be great grips
    Sent from my DROID RAZR using Tapatalk 4
    Apr 2013
    I would say with virtually any off payment terrain you'd want to swap out the front tire for something more aggressive. That's my opinion, at least, and it's what I'm doing. Nevegal is a great tire plus it keeps it in the Kenda family so the back still matches lol
    Sep 2013
    I think I'm going to get an NEVEGAL, ARDENT, or IGNITOR for the front. Anyone know between those which is a good choice?
    Leaning Nevegal just to keep in the family, but if one is a lot better than the other, I would be willing to have a divorce.
    Dec 2012
    Depends on your terrain, but generally I'd lean towards the ardent. Nevegal has good grip but rolls slowwww. Ignitor is just too small IMO, they need to come up with a bigger volume version
    Sep 2013
    Ardent 2.4? Not sure if that will clear without rub, I think someone else was talking about that too.
    Reputation: strfyeing's Avatar
    Mar 2013
    I replaced the front AKA on my Hobgoblin with a Nevegal. It's so much more confidence inspiring then the AKA for the kind of riding I do. I haven't noticed that it rolls slow, if anything I find that I carry more momentum knowing the front end isn't going to wash out now. I've not used either of the other two tires so I can't comment on them, but I'm diggin the Nevegal.
    Dec 2012
    If you go from a fast rolling, relatively light tire to a nevegal, you'll definitely notice a difference.
    Ardent is lighter, rolls much better, and has just as much bite. I can't think of a single situation I'd choose a nevegal over it...
    Dec 2012
    Go for the 2.25
    Sep 2013
    Quote Originally Posted by 8iking VIIking View Post
    Picking one up today, thanks for the help man. Hopefully, ill post some pics later today.
    Really interested to hear of your experiences with the SB8/Ardent combo. Been thinking of going this way after a few wet weather washouts with my AKA's. Do you have many wet roots or rocks to deal with?
    Sep 2013
    Yea, some trails definitely have those conditions. Even though, it's been an unusually dry season. Once I get the set I'll definitely let you know my experience.
    On paper everything looks good.
    Sep 2013
    Conti race kings hands down winner
    Dec 2012
    Quote Originally Posted by jrobinson72 View Post
    For a front tire? On anything but hard pack race kings would be terrible out front. Out back is a different story
    Thanks. Definitely look forward to it. I love the AKA's in dry or damp trails, and I don't have to deal with much mud, but I do deal with roots quite often. I had one flash washout at low speed caused by a wet branch, definitely shouldn't have washed out. Not exactly confidence inspiring in the roots.
    Reputation: BigDaddyFlyer's Avatar
    To be honest, not a lot of tires are great over wet roots. A lot of that boils down to technique and pressures. I ride AKA's and SB8's for 9 months out of the year and on my skinny tired mountain bikes in the winter I ride on Nevegals and truthfully wet roots here in Ohio arent' much better on the Nevegals. I still have to hit them at a right angle and use good technique to keep from spinning out or going down. Of course when the snow sticks I switch to my bike with 4" wide tires......
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Heh, yeah, I don't expect miracles short of studs over wet roots, just thinking there might be a better front tire for the times when I ride trails that are more roots than dirt. I really do like the SB8 and AKA design for a stock tire for the majority of riding.
    Also, my lacking technique should be able to be fixed by purchasing stuff, right?
    Sep 2013
    I decided to go with Purgatory 2.3's and have been loving the feel and grip and rolling speed of them. Still got the SB8 on the back, but my guardian has transformed into a loose over hardpack monster!!!
    Sep 2013
    Hey guys, If I wanted to upgrade the my xc28 fork to a Reba or Fox with a 15mm QR, would I have to replace my current hub or do any kind of other replacement? Or would that new fork fit as long as it wasnt 20mm?
    You'd need a new hub, as the KT hubs like most OE 9mm QR hubs aren't convertible. And frankly at that possible expense and committment, you'd be better off just get a whole new upgraded wheelset. Hope that helps!
    Jeremy
    Reputation: KrazyKreitzer's Avatar
    I agree with what Jeremy said. I replaced my fork with a 15mm maxle Reba and Black Flag Pro wheels and haven't looked back.
    Sep 2013
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    That's exactly what I was looking for, thanks Jeremy.
    Krazy, those are some nice wheels man. Cost more than my car I think... Lol
    Apr 2013
    Swapped to a Raceface 70mm stem Saturday, rode 12 miles, and it feels like a new bike. LOVE it.
    Sep 2013
    What size handlebars you guys rocking? I am thinking of getting something a little bit larger. Not sure where to start.
    Apr 2013
    700mm Truvative Hussefelt 20mm rise
    Sep 2013
    How do you like it?
    Is it worth spending a bit more and getting a carbon one?
    Or is the Hussefelt doing its job?
  1. Should I upgrade my Guardian fork to the Recon?
    By getagrip in forum Airborne
    Last Post: 03-07-2013, 08:01 AM
  2. To Guardian or to Goblin...that is the question....
    By FirefighterMTN in forum Airborne
    Last Post: 02-19-2013, 01:05 PM
  3. Looking for a fork upgrade for your Guardian?
    By BigDaddyFlyer in forum Airborne
    Last Post: 11-01-2012, 04:41 PM
  4. Upgrade question.
    By il2mb in forum Lights DIY - Do It Yourself
    Last Post: 04-23-2012, 08:19 AM
  5. Pro Upgrade Question
    By g-wiz in forum XC Racing and Training
    Last Post: 05-12-2011, 12:50 PM
