Results 1 to 21 of 21
    Reputation: nukuck's Avatar
    May 2012
    Guardian Ordered!!!
    Just waiting for delivery of my new Guardian to be made. I guess that will be sometime next week and I can't wait to ride it
    Reputation: hrbib21's Avatar
    Apr 2013
    Cool. I'm in the same boat, ordered yesterday morning. UGH! The waiting sucks, lol
    Reputation: TheDocTx's Avatar
    Apr 2013
    The wait is rough, but so worth it!
    May 2012
    Yes!!! My Guardian just got delivered and the packaging looks really good. Now time to assemble.
    Sep 2012
    Upload pictures before, during, after the build.
    Check the rear derailleur hanger.
    Don't forget to turn the stem around on the forks.
    Sep 2012
    Oh, and Happy New Bike Day!!!
    May 2012
    Assembly complete! Pics coming soon. I did turn the stem and everything seems to be OK. However, the front rotors seem to be rubbing against the brake pads when I spin the wheel. I have checked for wheel alignment and it seems to be ok.
    Is there anything else I need to do to get my wheels spinning freely?
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by nukuck View Post
    First, double check that the wheel is in straight by putting the bike on the ground (tires down), open the QR, then tighten it. Sometimes "straight" in the stand is different than straight on the ground.
    Next, if that doesn't fix the rub, loosen the 2 5mm allen bolts on the caliper, squeeze the front brake lever, and while squeezed tighten the 2 bolts. Then check for rub, repeat again if necessary.
    Hope that helps, and thanks for buying a bike from us!
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Sep 2012
    Echo what Jeremy said.
    But, sometimes the loosen and squeeze method doesn't work to adjust the brakes.
    You might have to loosen the allen bolts and manually adjust the brake so there is a gap between the pads and the rotor. Then tighten the bolts.
    Folks say to avoid touching the rotor to prevent getting oil from you skin on it, so I try to do that. But, it's hard to believe that a little skin oil would impact braking significantly.
    I have found that adjusting hydraulic disc brakes is both a science and an art.
    Patience is the key.
    May 2012
    May 2012
    Thanks. I knew I'd get a quick response. From the various messages and replies I see on this forum, I'd like to conclude that Airborne's Cust. service is really good.
    May 2012
    Problem of rotors rubbing was not the brake pads. The caliper was not aligned properly. Surprisingly, the bolts were slightly loose so I had to realign calipers and tighten bolts. Took me about 15 minutes but front wheel is spinning nicely now. Thanks guys!!
    May 2012
    Quote Originally Posted by jeffharris1us View Post
    Upload pictures before, during, after .
    Some pictures
    Attached Thumbnails Attached Thumbnails Guardian Ordered!!!-2013-06-05-10.09.36.jpg
    Sep 2012
    Love the progression from picture 1 to 2 to 3. Like a baby bird hatching from an egg.
    Get it dirty then upload more.
    May 2012
    There is this tiny black plastic piece in a plastic pouch included with the components. What will that be for? Thanks
    Apr 2013
    looks awesome, I actually think the guardian looks better than the goblin... I like all the white painted stuff and red just looks great.
    May 2012
    Makes me remember of when my guardian was brand new... Feels like a very long time ago.
    Apr 2013
    UGH! They attempted to deliver mine but nobody home. Definitely tomorrow as I signed the door slip. Not that I'll be able to ride this weekend anyway considering the tropical storm coming our way (SC).
    Apr 2013
    Looks great, btw. That will be me tomorrow night.
    Apr 2013
    Rockshox includes that little block to help guide the front brake hose along the fork. There is a 'notch' on the top back of the fork brace. The idea is that the black plastic block cradles the brake hose (on top of the brace) and is held in place by a zip tie that circles the fork brace at the point of the notch. Confused yet?
    Most of us toss the plastic block into a parts bin and just use the zip tie all by itself!
    May 2012
    Thanks for your response h8pavmt
  1. Guardian...
    By hrbib21 in forum Airborne
    Last Post: 06-06-2013, 10:10 AM
  2. New Guardian! And some questions...
    By h8pavmt in forum Airborne
    Last Post: 05-26-2013, 11:27 PM
  3. Just Ordered My First 29er: The Airborn Guardian
    By getagrip in forum Beginner's Corner
    Last Post: 03-07-2013, 05:54 AM
  4. BB Height on Guardian
    By Barheet in forum Airborne
    Last Post: 11-02-2012, 08:09 AM
  5. How much does the Guardian weigh?
    By f1gpstar in forum Airborne
    Last Post: 09-16-2012, 07:40 PM
