    Green Goblin Quanta hubs adjustable?
    Hi! The front hub on my green Goblin has a little bit (like maybe a millimeter) of side to side play. Can this be adjusted out?
    deleted, wrong thread.
    Reputation: BigDaddyFlyer's Avatar
    No, they aren't adjustable. Are you certain that the skewer just isn't tightened good and tight? Sometimes when the skewer isn't tight there is a little movement at the interface.
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Thanks! That seemed to have done the trick. I tightened it really tight and most of the play is gone. The little bit left can only be felt if you grab the tire and pull side to side. There's just a tiny bit of movement at the outer edge of the tire, but that's it. Thanks again for your help.
    Love the bike!
    Eric
