Results 1 to 11 of 11
    Breezer Jetstream vs Airborne Goblin
    I have narrowed down my new 29er choices to these 2, the Breezer Jetstream Comp ($1099 on Nashbar.com), and the Airborne Goblin (2012 version, $1049).
    Airborne Bicycles. Goblin
    Breezer Jetstream Comp 29" Mountain Bike - Overweight Code G Restricted
    The Breezer is a bit lighter, I think, but the Goblin has a bit better fork. I feel a bit more comfortable buying from Airborne than Nashbar, but I love the idea of shedding a few pounds on the stock versions, plus I am still a bit iffy on how long the novelty of the Goblin paint scheme is gonna take to wear off.
    What do you all think?
    Reputation: hangdogdaddy38's Avatar
    Dec 2010
    Just looking at the package I'd go with the Goblin. Have read a lot of +'s here in the forum on the Goblin.
    Mongoose Summit Pro
    Gary Fisher Tassajara
    Motobecane Fantom Trail DS
    Trek 2011 X-Caliber
    The New Goblin gets you a tapered steer tube and 38/24 tooth chainrings which is nice for a 29er. I know I'm sometimes begging for an easier gear with my 39/26 setup.
    28+ for both. The "new" Goblin has 100mm tapered steerer 15mm thru axle Reba fork. A lot better front end and only needs a light wheel and tire. The Breezer has a shorter chain stay(438 vs 450). but the model isn't on their site although the Thunder appears to be equivalent.
    Well now the Brrezer Jetstream Comp is available (size Med which is prob right for me at 5'11") on Nashbar for $950, plus shipping of $39 for total of $989. Seems like a good deal, all SLX drivetrain. Everyone still think the Goblin is the better deal, for $1050? I just can't get over that green- seems maybe a bit young for me at 42 y.o.
    I would check. If the Goblin has a Reba fork, tapered head tube, and 15mm axle. It is definetly worth it. I went from a standard head tube 9mm quick release 26er. To a tapered, 15mm axle 29er. Even with the 29 inch wheels(same exact wheelset except bigger) the front end steers so much more precise.
    Sep 2012
    Goblin 2013
    This is a sweet setup and an awesome deal for $1200
    6061 Hydroformed Aluminum Hardtail 29"
    Fork
    RockShox Reba RL 29 Dual Air w/Lock-Out, tapered steer, 100mm
    Headset
    Ahead Sealed Cartridge 1 1/8" to 1.5" tapered
    Brake Levers
    Avid Elixir 7
    Brakes
    Avid Elixir 7 Hydraulic Disc
    Rotors
    Avid 180mm front, 160mm rear
    Shifters
    SRAM X-7 2x10
    F Derailleur
    SRAM X-7 2x10
    R Derailleur
    SRAM X-7 2x10 Mid-Cage
    Cassette
    SRAM PG-1050 11-36T 10-Speed
    Chain
    SRAM Powerchain 1051
    Crank
    SRAM X-7 2x10, 38/24 rings
    Bottom Bracket
    SRAM XR GXP Sealed BB
    Pedals
    NONE
    Rims
    WTB SpeedDisc XC Alloy Double-Walled with eyelets
    Hubs
    KT HiFlange Sealed Bearing 32H
    Spokes
    Black 14g Stainless
    Tires
    GEAX AKA 2.2"
    Handlebar
    AIRBORNE Alloy Flat, 640mm width
    Stem
    AIRBORNE Alloy +/- 7 Degree Rise, size specific
    Saddle
    Selle San Marco Ponza Power
    Seat Post
    AIRBORNE Alloy 31.6mm Diameter, 350mm Length
    Extras
    Owner's Manual, Clear Coat, H20 Bottle Mounts
    Mar 2011
    that is why i orderd a 2013 NEW GOBLIN !!!!! SEARCHING FOR MAYBE GREEN SPOKES OR WHITE SPOKES :d WILL ROCK !!!!!
    Quote Originally Posted by fordohio View Post
    Where are you seeing the 15mm axle? I haven't seen it in the literature, and the photo seems to show a standard 9mm QR. Not a big deal to me, but figured it's worth clearing up for other people reading your post.
    Reputation: BigDaddyFlyer's Avatar
    To clarify: The new Goblin does not have a 15mm axle. We just couldn't afford to get it on that bike at the pricepoint we are selling it at.
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Sep 2012
    I looked at the same bikes you have and chose the Airborne Goblin. I am 53 and I like the color. But honestly the color is not important out on the trail, only in the photo ads. If you can swing it though I would recommend the 2013 Goblin for you. They took a good bike (the 2012) and made it better. I have since done several upgrades to my bike and I absolutely love it. The Reba fork is the best I have ridden and is super adjustable. Either way enjoy your new bike whatever it is and let us know how you did!
