Results 1 to 7 of 7
    Apr 2013
    Best Chain Tensioners for Wingman
    In all the reviews, they said the thing that stood out is that the wingman needs an easy fix of a chain tensioner on the horizonal droupout. I have been looking around, but I wanted to know if anyone had suggestions on the best chain tensioner for the Wingman?
    I'm using the DMR Chain Tugs. I had to modify them with my Dremel to make them work. I would avoid them if I were you.
    Apr 2013
    Ok good to know, thanks!
    Anybody else running chain tensioners?
    Just swapped out the DMR's for a set of Redline tensioners I picked up at my LBS.
    These are the ones you want! I like 'em!
    Amazon.com: Redline Alloy Chain Tensioners 3/8, Pair Black: Sports & Outdoors
    I had to get two different sets and cobble them together to make one sort of working set. The problem is how thick the frame is for them to fit.
    I am going to try the Redlines.
    Reputation: BigDaddyFlyer's Avatar
    Quote Originally Posted by pearsth View Post
    The Redline tensioners work, I had those on mine for awhile.
    Also, if you take a look at the drop-out, there's a threaded hole there in the front of the dropout that goes thru it that you can use as a built-in tensioner. I can't recall the thread and pitch (M12 or M8?) but if you go to your local hardware store you can get one with an allen head, and with that and a corresponding nut you can keep the wheel/axle centered that way.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Jeremy, great idea on using the existing threaded hole. That would be a the cleanest approach to solving the problem and probably even be easier to adjust. Airborne should publicize this approach or even source the bolts and sell them as an accessory.
  1. new wave of 2x tensioners
    By thegromit in forum All Mountain
    Last Post: 12-29-2013, 12:53 PM
  2. Where can I find tensioners like this?
    By HOV in forum Singlespeed
    Last Post: 06-05-2012, 07:20 PM
  3. Thoughts on Chain Tensioners
    By bank5 in forum Singlespeed
    Last Post: 02-12-2012, 05:29 PM
  4. New to Singlespeed tensioners
    By CislerN in forum Singlespeed
    Last Post: 10-23-2011, 02:56 AM
  5. Tensioners are such a fad...
    By TroutBum in forum Singlespeed
    Last Post: 03-23-2011, 08:25 PM
