Page 3 of 4 FirstFirst 1234 LastLast
Results 201 to 300 of 363
  1. #201
    May 2012
    Here is a quick pic. I need to lower the seat post and put my pedals on tonight:
  2. #202
    Reputation: CYCLEJCE's Avatar
    XL I assume, judging by the stem length. Did it come with the Thompson post?
  3. #203
    May 2012
    The bike is a 19 inch. I bought the Thompson 410 post because I thought I might need more room due to my 36" inseam.
  4. #204
    Mar 2012
    mbakes,
    Looks great!
  5. #205
    May 2012
    Set it up a bit at lunch. The 19" seems to fit but I can't believe how big this bike is with the 29" wheels. It is a pretty strange feeling being on a bike that is so high off the ground and physically large, especially when I am used to riding my road bike. It dwarfed my old hard tail mountain bike. Not sure what I think at this point.
  6. #206
    Reputation: BigDaddyFlyer's Avatar
    Thought you guys might like an advanced preview of the new HobGoblin ad that drops this week in the latest issue of Decline.
    Attached Thumbnails Attached Thumbnails Airborne HobGoblin?-decline_hobgoblin_ad.jpg
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
  7. #207
    Good looking ad, good looking bike.
  8. #208
    Quote Originally Posted by mbakes View Post
    you could start by getting rid of all of your stem spacers and possibly a shorter/drop stem all together .
  9. #209
    May 2012
    Nice ad. The bike is every bit as good looking in person.
    Quote Originally Posted by CYCLEJCE View Post
    Thanks. I'm going to work on the fit. My fit issue is that I have long legs and a short torso which is why I have a custom frame on my road bikes. My comment was more that the bike is just physically large with the 29" wheels. I'm guess it's just a matter of riding and getting used to it.
  10. #210
  11. #211
    NeedGod.com
    Reputation: Barheet's Avatar
    I experienced the same feeling of riding on a monster truck when I started on my 29er. I imagine it's a little different on a FS. I quickly got used to it though.
    One thing that really helped me was lowering the stem and eventually flipping it upside down.
    By the way, thanks for posting the pic. This is the first pic I know of taken by a customer.
    Nathan
  12. #212
    Yeah, I got the same thing when I first rode my 29er. Now it feels totally natural and my old 26" bike feels like a toy. You'll get used to it.
  13. #213
    May 2012
    I think the first thing I do tonight is flip the stem, removing spacers or both (thanks, CYCLEJCE). The more I think about it the more I think being in such an upright position is probably adding to the feeling of the bike being large.
  14. #214
    MTB B'dos
    Reputation: LyNx's Avatar
    The only reason you should feel "ontop" as compared to "in" the bike is if the BB height is drastically different between your old frame and the HG. What you should notice is the handling should feel a bit better because relative to the axles you should be more "in" the bike. i.e. your CG in relation to the axles is lower and hence cornering should be improved. Check the fork and shock pressures, make sure you don't have them jacked up too high for your weight.
    As to fit, I'd have thought that with a long inseam like that and if you say you have short arms you'd be running a shorter stem - that looks like a 120mm to me. How tall are you with that 36" inseam? Is that the stock bar and what width?
  15. #215
    May 2012
    The stem came with the bike and have not had a chance to play around with fit beyond some seat post and seat adjustment. I bought the smaller frame to accomodate my shorter torso. I'm 6'2". My road bike has a 54 tt ctc and a 59 ctc st.
  16. #216
    Feb 2012
    Lookin' good, mbakes! Can't wait to hear your ride report. Think you'll get out in the morning?
    **BRENT**
  17. #217
    May 2012
    My first ride will be Saturday. I flipped the stem and dialed in the fit a bit more by moving the saddle back a bit which has improved comfort.
  18. #218
    CoolArrow
    Reputation: jhazard's Avatar
    Wow.
    Hobgoblin arrived this evening.
    Wow.
    The frame is off the hook. Beautiful paint, beautiful tubes, and I'm a big fan of the multi-link design. Got it thrown together pretty easy:
    Unpacked/wrapped in about 20 minutes. Threw it in the stand, flipped the stem around, installed the bars, then the front wheel (Kudos for Airborne using the same size allen heads on all the stem hardware). With the exception of pedals, the bike is ready to go in 30 minutes. Only needed two different sized wrenches. (of course, be sure to double-check ALL nuts n bolts before going for a ride!).
    Mine (a 17" inch) is performing well on the bathroom scale test at ~30lbs, stock setup, no pedals. That's pretty darned svelte for such a bike I'd say. Plus, it's a real looker... ;D
    Cool BandolArrow
    Jerry Hazard – website
  19. #219
    MTB B'dos
    I'm curious to see a pic of you on the bike, from your description and your bikes it seems your legs are oddly longer proportionately than your arms I'm 6'2.25" and have a 35.25" inseam and arms to match, hence although a lot would say just going by my height I shouldn't ride an XL, when they see me on one of my bikes they quickly reassess their comment. Really interested to read some none vested thoughts on this bike and the suspension.
  20. #220
    May 2012
    A friend of mine saw the pic of my bike and pointed out that I may have received a 120mm stem instead of the 105 that is supposed to come with the 19". I received the info on the way in to the office so I will confirm at lunch today.
    Yes, I have a short torso/arms and long legs. I don't think it will be a problem fitting the HG. It will just take a little tweaking.
  21. #221
    May 2012
    Took my first ride today. Did about 5 miles on the trails and had a blast. I have not mountain biked in at least ten years and that was on a 26r hard tail. It took a good 10 to 15 minutes to start to get used to the wheel size. These trails have a lot of tight areas so I still need some work on my handling skills. I think I may change out the tires. They did not seem to hold tractions on some areas, which caused my one fall. Overall, my impression was very good. I do not have must to compare to so my opinions won't help anyone much in making a decision. So far no brake squeals. My old bike had XT shifters and I think I prefer them to the SRAM. I felt I had a lot of accidental shifts because my thumb would hit the shifter while riding over bumps. I will give it some time to get used. Looking forward to tomorrow mornings ride.
  22. #222
    Reputation: toddre's Avatar
    Glad you like it... I may pick up a frame after Santa visits next week. When I went to SRAM triggers (always used twisties), I too had the mis-shift issue. With a bit of trial and error I realized that you have to move the units toward the stem more. Doing so puts everything in the right place. Might want to take alook at getting SRAM Matchmakers, too.
  23. #223
    May 2012
    Quote Originally Posted by toddre View Post
    Thanks. I realized part through the ride that the shifter were too close to the grips so I stopped and moved them over a bit. I think I am going to push them in a bit further. This did help.
  24. #224
    May 2012
    That is the first thing I noticed on my black Goblin, when I first sat on it and familiarized myself with the controls. Moved the shifters and the brakes in. I have to consciously try to shift, there is no way I can do it with out it being intended.
  25. #225
    May 2012
    On the trail today:
  26. #226
    May 2012
    On the trail today:
    Cool, Looks nice, mid 30's here in Delaware, not going to ride for a while. But do have to work on a stubborn VW TDI that doesn't want to start, so I will be "outside"
    Oh and I hate to be that guy.... Reflectors man..
  27. #227
    May 2012
    I know, I forgot to take the reflector's off this morning. It was a little embarrassing but nobody said anything. Besides my two falls probably much more entertaining.
    Despite the two falls, I am getting used to the bike. The two falls were more results of not knowing trails then anything else. I just hope I can make it through this initial phase of scrapes and bruises.
  28. #228
    CoolArrow
    REAlly getting into this bike...
    Cool BandolArrow
  29. #229
    May 2012
    No action shots yet. I've been dialing in the ride a bit each time I am out. I dropped the pressure in the tires and tractions has improved:
  30. #230
    TXTony
    Guest
    Quote Originally Posted by jhazard View Post
    Gotta dig it!
  31. #231
    CoolArrow
    Video up...
    Hobgoblin in New Mexico:
    <iframe src="http://player.vimeo.com/video/56603460" webkitallowfullscreen="" mozallowfullscreen="" allowfullscreen="" frameborder="0" height="309" width="550"></iframe>
    Cool BandolArrow
  32. #232
    Dec 2012
    Just pulled the trigger on 1 tonight! Looking to get back on the trails after a 15 year hiatus. 2 blown out discs will require some cushioning and I hope this fits the bill.
  33. #233
    May 2012
    Quote Originally Posted by mwm70 View Post
    I hope you enjoy yours as much as I am enjoying mine. I also came back to mountain biking after 10 to 15 years.
    jhazard, great video!
  34. #234
    CoolArrow
    I was actually getting a bit bored with "trail riding" - 29ers got me hooked again, and the Hobgoblin has me stoked! You guys will love it!
    Cool BandolArrow
  35. #235
    Glad you are digging the HG! Mind if we "borrow" that shot for our facebook page sometime? Thanks!
  36. #236
    May 2012
    Absolutely. I wish I could get some better shots but there is a nice canopy on most of the trails so light is low. I am digging it, not my body. Both me and the bike have taken quite a beating since its arrival.
  37. #237
    Mbakes:
    Is that a wood trail feature in the background? No wonder you are taking a beating!
    Let's see some action shots!
  38. #238
    May 2012
    There are a few of those. One is probably 100' long and narrows in the middle. I dropped about 2' off of that one on one ride and took a nice hit. Out of about 40 plus miles of ridding over 6 different days, I've had 3 falls which I felt for a while after. I am pretty sure I bruised some ribs on my first fall which I still feel 2 weeks later. Between not knowing the bike and the trails, I knew there would be some pain involved and at 52 it lasts a bit longer than it did that last time I was out there, years ago.
    Hero 3 is coming soon.
  39. #239
    [QUOTE=Hero 3 is coming soon.[/QUOTE]
    I got one for Christmas from the wife, I'm sure it will result in some riding beyond my capabilities....
    Nice ride BTW!
  40. #240
    May 2012
    I hope to have mine within the next month or so. I have a custom Ti road bike frame to pay for first. I forgot that I took a picture of part of the wood bridge:
  41. #241
    Nice looking bike!! Thinkin about gettin this bike. Though im used to a hard tail! Im coming off of a 2012 big kahuna and im looking for a fs 29er. How is the pedaling on this bike? Anybody have any pics of what a small frame looks like?
  42. #242
    Dec 2012
    OUT FOR DELIVERY!! hopefully will have time to put it together tonight.
  43. #243
    Congrats! nothing like new bike day, hopefully the trails in your area are rideable today!
  44. #244
    Dec 2012
    Thanks, will be too late tonight but the weekend looks perfect!
  45. #245
    Sweet video Jerry!
    I would be interested to see some reviewers compare this to the Anthem.
    There's only one bigger sheep than manufacturer's - consumers! - AndrewTO
  46. #246
    May 2012
    Congrats! Let us know what you think.
  47. #247
    Dec 2012
    Absolutely. After a 15 year break and coming from a titanium hard tail it will definitely be a change, but I am excited about getting back out there.
  48. #248
    Sep 2012
    Hey Jerry, those of us in the Midwest that still have plenty of snow in the front yard are not amused.
    You can take your fancy-schmancy new FS 29er and your warm/dry climate and....
  49. #249
    Sep 2012
    Will you be building tonight?
    Send pics!!
  50. #250
    Dec 2012
    Quote Originally Posted by jeffharris1us View Post
    Send pics!!
    Yes I did. Build went pretty smooth.
    This was my first bike build since 1998 when i left the shop i ran.
    - Overall the bike was well packaged and pretty much in tune.
    - Had no trouble with the front derailluer.
    - Brakes were rubbing but a quick centering solved that.
    - Adjusted the headset and set handlebars.
    - Rear derailuler fought me a little. Could not get it to shift consistently at both ends of the cassette. Low side would shift fine than the high side would miss shift and vice versa. I know in older equipment that was a sign of the derailluer hanger possibly being out of alignment. Dont have an alignent tool so i will keep playing with it and see. Limit screws were too tight as well.
    Pic after pulled right from box:
  51. #251
    Dec 2012
    Sorry about 2 posts, could only get 1 pic to upload in first one.
    All in all it is a very nice bike. No regrets after seeing it in person.
    Looking forward to getting out on it this weekend.
  52. #252
    CoolArrow
    Enjoy your new build!
    Cool BandolArrow
  53. #253
    MTB B'dos
    What size is that Mwm70, stem looks quite long? Again, interested to hear ride reports from those NOT affiliated with Airborne. Curious, are the graphics under the clear coat or ontop? Not a fan of the absurdly huge DT logo.
    Really like the look of these bikes and they're a great deal, only wish I didn't not like SRAM stuff so much, although I guess you could just sell the SRAM drivetrain & brakes and replace with Shimano stuff
  54. #254
    Dec 2012
    It is a 21". Stem feels a touch long so I might switch that out. Did not pay attention to decal will let you know about that and impression after first trail ride.
  55. #255
    Nov 2012
    Good looking bike mwm70. What was wrong with the headset? What did you do to adjust it?
  56. #256
    The graphics are under clear, but I guess there's always the option of stripping and repainting if you don't like our "subtle" graphics.
    You may be better off considering getting a frame-only versus a complete, if you end up wanting to sell the SRAM stuff anyway it might be cheaper and less hassle in the end to just get the frame.
    J.
  57. #257
    Dec 2012
    It was over tightened slightly for shipping. I loosened the stem bolts and then hex bolt in the top cap then retightened the top cap bolt gradually until there was no play in the headset. Holding the front brake and rocking the handlebars to and away from you until the "slop or play " is gone then tighten stem bolts to secure.
  58. #258
    May 2012
    Enjoy your new ride!
  59. #259
    MTB B'dos
    I think you guys should consider offering the frame in RAW with a sticker kit and those who don't mind the gawd awful huge logo could install them and those of us who like a bit more subtle wouldn't. Could also offer a more subtle decal set, you know about 40-50% that size
    Quote Originally Posted by BigDaddyFlyer View Post
    J.
  60. #260
    Reputation: jkidd_39's Avatar
    Sep 2012
    Or you could strip down the frame instead of asking the manufacture to do it. The reason Airborne is so price competitive is b/c they don't offer 20 colors and such.. If they offered blue, green, orange, red, and raw you would be paying $3k for a hobgoblin..
    just saying
  61. #261
    You can't please everybody. Airborne offers a quality high value product at great prices. Why is there always somebody picking it apart about some detail. "Why can't it have this fork? These brakes? Why can't the graphics be smaller/bigger/redder/greener....?"
    Sandpaper is cheap... If you want a bare frame you can have one. Wouldn't take long to sandblast a frame, I'd bet it wouldn't cost much to have it done.
    I think it looks great. Of course it really doesn't matter to me because I want one to RIDE.
  62. #262
    CoolArrow
    Quote Originally Posted by swildnm View Post
    Cost me about $100 last time I sandblasted a frame - but careful, sandblasting does heat up the aluminum and can affect heat-treating. Honest, google it. Aircraft stripper works nicely as long as you have a warm environment...
    That said - good point Its an incredible value, and I don't mind the graphics so much...
    Cool BandolArrow
  63. #263
    We actually appreciate all thoughts and comments about our products, as long as they are done in a tasteful manner ("that sucks" commentary probably won't be received well ).
    I don't mind the comments on the paint, graphics, etc. Everyone does have different tastes and like most companies, we try to please the most people but can't hit a homerun with everyone every time.
    I'd like to think that one of the things that makes us different is the fact that we are approachable/interactive and do listen to our customers. For example, a lot of the changes that were done to the current black Goblin to make it different/better than the former green one were the result of customer input and feedback.
    At this point we can't offer an additional colorway or raw option on the HobGoblin, but we can take it into consideration for future versions. I will say that from a branding standpoint that I personally dislike not having decals under clear, because I think it looks "cheap" and runs the risk of the decals coming off with use. But that's just my opinion.
    Thanks a bunch and keep the suggestions coming! Oh and the weather is going to be warm this weekend here in Ohio, so don't forget to get out there and ride.
    Jeremy
  64. #264
    May 2012
    Would I have preferred a more subtle logo, probably but in the end, it's about the bike. The HG is an excellent value, the look was not much of a consideration. I agree with BDF, decals need to be under clear or they do look cheap on a bike frame.
  65. #265
    Jeremy
    Understood, and you do a great job of it. But I find
    to be over the top. I think you've done I fine job of explaining how you provide the product you do at this pricepoint. I've changed a lot on my Guardian as I grew as I've grown as a rider, and found that I was commited to cycling. And I fully intend to order a Hobgoblin XO in March. But I already have changes in mind for it to fit me. Wider bars, shorter stem, different fork, dropper post. But it is still a hell of a deal as is. And the parts that come off I can either reuse on another bike or sell. I guess my point is that the price is so good you can afford to customize.
  66. #266
    MTB B'dos
    I stick to my comment about the logo, it if frikin HUGE, not only is it a very bold font, it's also just physically as big as the DT will allow it to be AND the contrast they use of white on dark blue, or white on Orange for frame only makes it even worse. Just take look at the any of the Big3s bikes, not even they have such HUGE logos. Will agree though, logos ontop of clear coat do not look as finished and will get scratched and damaged much easier, although Turnerites have been doing it this way for a very long time
    I do think though that these bikes are great value, but if I only bought stuff on performance laone
    Quote Originally Posted by LyNx
    Gawd Aweful Huge logo
    to be over the top.
    Jeremy
  67. #267
    Understood.
    The black on the orange doesn't seem to stand out too much.
    Attached Thumbnails Attached Thumbnails Airborne HobGoblin?-hobgoblin-john-bryan.jpg
  68. #268
    Need 4 Speed
    Jan 2013
    cane creek angleset headset
    If I was to use an angleset like the cane creek would I be able to use a 120-140mm fork? If so, would this make the Hobgoblin's suspension unbalanced?
    Thank you in advance on any and replys.
    Airborne, I like what you guys and gals are doing. keep up the great work.
    P.S. 650b/27.5....Just saying.
  69. #269
    CoolArrow
    it if frikin HUGE... Just take look at the any of the Big3s bikes, not even they have such HUGE logos...
    I'd say that's a bit larger than Airborne's - that 'fsr" doesn't even fit on the tube! (all in good fun!)
    I agree, the logos on Airborne ARE huge, but they don't really bother me, I kinda like it actually. But where the big three might not blast their name in huge legible letters down the side, they do give the bikes a pretty big graphic makeover a lot of the time - something I don't care for.
    One thing for sure though - Airborne listens to their customers. Maybe the logo thing will change in the future.
    BTW, LOVING the Hobgoblin. Great job Airborne!
    Cool BandolArrow
  70. #270
    Reputation: KrazyKreitzer's Avatar
    This. I think the new style Airborne logos are tasteful. I've even considered getting my green Goblin powder coated and using the new logos on it I like them so much. Very simple and easy to read. I like to be able to read the logos on bikes as I pass on the trail.
  71. #271
    Jun 2012
    BigDaddy Can you get a Hobgoblin frame kit with no paint?.
    Giant XTC 2 29er
    KHS Flagstaff 29er FS
    Neon Bow Trials Bike
    Norco Fluid 9.2 29er FS
    Norco BIGFOOT FATTY
  72. #272
    Sorry, all of our frames are painted, decalled, and cleared at the factory.
    Jeremy
  73. #273
    Quote Originally Posted by T-Rider4Life View Post
    (Sorry that I somehow missed this question earlier)
    Thanks for the kind words!
    OK, on the HobGoblin the frame design is based around a 100mm fork. While you can put a 120mm fork on there, doing so will void the frame warranty as it is outside of the design parameters of the frame. We test all of our frames to the strict EN14766 European standards but the passing test results are based on a 100mm fork. Anything beyond that is unpredictable as far as frame longevity goes.
    From a performance standpoint a 120mm fork will slacken the HT and ST by a degree or two and also raise the BB. 140mm will probably be extreme as far as slack and BB height.
    Also, I'm not super versed in the Angleset, but I think the last time I checked they didn't have one for 1 1/8 to 1 1/2 inch IS-style headsets.
    Thanks again,
    Jeremy
  74. #274
    Need 4 Speed
    Jan 2013
    Thanks again,
    Jeremy
    Thank you Jeremy. Your quick response means alot. Very impressed with the bikes and the company.
  75. #275
    What? There's more?
    Reputation: tyrebyter's Avatar
    I like the big logo. In fact, bigger by a factor of 2 or 3 would be nice... wrap right around the tube. All subjective, yes? Objectively, you can't get more bike for the money. Now if it just came in a 650B...
  76. #276
    CoolArrow
    Quote Originally Posted by tyrebyter View Post
    Actually, wouldn't 650B be LESS bike for the money? Sorry - had to!
    I do think it would be sorta cool to wrap the logo all the way around.
    Cool BandolArrow
  77. #277
    What? There's more?
    650/29=22.4.... Nope. 650 is 22.4 times more. It's all math, you know. Like how a wheel 25mm bigger in diameter than a 26 is called a 27.5. Huh? Anyway, If I could talk myself into a 29er, Airborne would sell another bike. I like their products and I like their attitude.
  78. #278
    CoolArrow
    Ahhh, I see - "math".
    Airborne is great people and great ideas, I'm anxious to see them grow.
    Cool BandolArrow
  79. #279
    To be fair Tyrebyter sold me on 2 Airbornes, soon to be three. When Airborne gets their 27.5 bike done they should give him a discount as commission. Any news on the 27.5 BDF?
  80. #280
    Jun 2012
    I think I am sold on the hobgoblin frame kit, its a sweet frame, colour is not my cup of tea but you can't please everyone, nothing a stripping and powdercoating cant fix.
    One question though, is the warranty good in Canada?
    Giant XTC 2 29er
    Norco BIGFOOT FATTY
  81. #281
    No news on 650B at the moment, sorry!
    Awesome! Yep, warranty is good in Canada also.
    Jeremy
  82. #282
    Jun 2012
    one more question I see the BB is press fit 30, with a BB92 pressfit still work in the opening? I just bought new cranks raceface turbine X type and the matching pressfit BB92 BB. There are so many BB now its really confusing.
    Giant XTC 2 29er
    Norco BIGFOOT FATTY
  83. #283
    I believe the 92 is too wide. You mostly see bb92 on carbon bikes. I could be wrong...
  84. #284
    Jun 2012
    From what I see most 29ers with press fit use BB92, Giant, Rocky Mountian, and a host of others. My giant is BB92 and its aluminum. A 68-73 thread in is the same width as a pressfit. My older cranks are RF Ride in a threaded BB 68-73 and they fit perfectly in my BB92 pressfit and the Shimano cranks that came in the Giant fit the RF threaded BB perfectly 24 MM spindle. So many different names for the same **** is crazy.
    Giant XTC 2 29er
    Norco BIGFOOT FATTY
  85. #285
    BB92 will work as the frame has 41mm opening with an actual measured BB shell width of 89.2. There is a little internal sleeve overlap of the BB when assembled into the frame.
    Just be certain you buy the "mtb" bb and not the "road" bb that is actually 86mm wide. SRAM's "Pressfit GXP Mtb" bottom bracket fits perfect and that's what we use.
  86. #286
    I looked up the SRAM part# if this helps:
    "00.6415.033.020 AM BB PRESSFIT GXP MTB BB92"
    Jeremy
  87. #287
    Jun 2012
    perfect the BB I have is the race face BB92/X type so I should be golden, thanks for your time. It does mean allot when companies actually take time to talk with the owners and soon to be owners of their product. The more I look at the bike online the more that colour is growing on me, not sure how all my red hope stuff will clash with the orange though. Oh I did have one last question, what is the biggest middle ring I can run with clearance, currently have 24x36 setup with bash.
    Giant XTC 2 29er
    Norco BIGFOOT FATTY
  88. #288
    Dec 2011
    I was about to ask what standard was the BB thanks for reply Big Daddy
    also is there any chance you might come out with Hobglobin XT???
  89. #289
    Quote Originally Posted by fahza29er View Post
    Thanks for the kind words! Glad to know that what we do makes a difference.
    If you didn't notice, the bearing caps on the frame are all anno red and they look great with the orange. That should also help pull in the red from your Hope parts.
    OK, this is going to be a somewhat subjective answer.
    The frame was really built around using a 2x10 set-up, and that's what we use on our production bikes. We've never installed a triple in one.
    That being said, in our frame drawings it looks like there is enough space for a 24/32/44 triple set-up. I can't guarantee without a shadow of doubt that your 36 is going to fit OK. The 38 on our 2x10 system fits just fine with plenty of clearance, but that is further outboard than what your 36 would be. I don't know what the difference in chainline is between where the middle ring on a triple is compared to the outer ring on a double. I'm guessing that if your 36 is 5mm or less inboard than the outer ring on our double, you'd be fine. Much more than that..........I'm not certain.
    So you'd have to try it to see if it fits. I wish I had a better answer than that but hopefully that helps a little bit......
    You're welcome!
    We don't use Shimano very much as we all prefer SRAM for various reasons. Right now the XT version of a HobGoblin would be a little redundant for us while we are carryin an XO level bike as they are similar in level. You never know what the future holds though!
    Thanks for all of the questions and interest~
    Jeremy
  90. #290
    Dec 2011
    I was reading on suspensions but dint find the exact one used in the HG is this just like the #4 Twin link four bar Buyer's Guide To Mountain Bike Suspension, Part 2 - BikeRadar
  91. #291
    We liked this pic so much we "borrowed" it for our FaceBook page today.
  92. #292
    Hobgoblin size question. I am 5'7" and have a 30" inseam. I currently ride a 16" Guardian with an 80mm stem, I'm right at the top of the stock seatpost. I'm happy with the fit, but I'm looking to the Hobgoblin as more of a Trail/AM bike and plan to run it with a much shorter stem. Probably more like 45mm. What size would you advise? I'm thinking 17".
  93. #293
    Based solely on your sizing dimensions, we would tell you to buy the 15".
    But given how you want to set it up, with a shorter stem and probably a zero-offset post, then we feel comfortable with you buying the 17.
    You shouldn't have any issues with stand-over with either size.
    Hope that helps!
    Jeremy
  94. #294
    May 2012
    Cool. My wife was not nearly as impressed as I was.
  95. #295
    BDF. Will a 15" frame fit a full size h2o bottle?
  96. #296
    May 2012
    Hobgoblin in the Everglades:
  97. #297
    Mar 2012
    mbakes,
    How are you finding the HobGoblin? I'm looking to possibly pull the trigger on this soon but am a little put off by the starting weight...I've been used to riding 20lb hardtails for the last 18 or so years. Thanks for any insights.
    Keith
  98. #298
    May 2012
    I used to ride a lighter weight hard tail and the HG is my first full suspension bike so not a lot to compare to. Riding the more technical stuff here it's great. I dont have any hills to climb so the wight is not a problem. We have a lot of real short steep climbs, like 10', 15' . The biggest adjustment for me is that it is a 29r but after a few runs, I adjusted. Yesterday's ride was 27 miles on mostly gravel double track. I tried to ride it as a HT but it wasn't long before I realized that it was just more comfortable with the rear suspension active. I became pretty fatigued during the ride which has more to do with my fit set up than the weight. I should add that I am note used to being on a mountain bike for so long. My road bike is custom made so I can ride it for hours without a problem. I'm going to tweak my set up to make it more comfortable on long rides. The only thing I don't like about the HG is hat it's not an XO but that was a money issue at the time. The bike rocks for the money and then some.
  99. #299
    Nov 2012
    What do you plan to change to adjust fitment?
  100. #300
    May 2012
    Shorter stem and a different seat. One of the rails popped out during a fall on seat that came with the bike. I replaced it with a seat I had laying around. It was fine for the short rides but killed me on yesterday's ride. I'm going to put my road bike saddle which is a Selle SMP Lite 209. I may run the stem turned up on longer rides.
