Results 1 to 16 of 16
    Feb 2012
    Airborne Goblin Component Weights
    Hey, I am in the process of deciding what items to upgrade next on my green Goblin so I took off the seatpost and stem to weigh them. I was too lazy to pull everything off the bars to weigh so if anybody knows the weight of the bars, please add the weight here. I weighed whatever parts I could conveniently get my hands on. I know some of these weights are very weight weenie-ish, but while the parts are off the bike, I figured I might as well. Never know who is going to want some random weight from a part. So here you go:
    Complete Stem: 246.4g
    Stem Faceplate: 31.7g
    Stem Faceplate Bolts: 23.8g
    Seatpost: 352.4g
    One WTB Tube: 172.8g
    Cool! I've swapped the stem, bars, seatpost, and wheels. I suspect it shaved nearly 4 lbs off the bike!
    There's only one bigger sheep than manufacturer's - consumers! - AndrewTO
    MTB Fanatic
    Reputation: Barheet's Avatar
    This is very helpful. You can see clear weight savings with even pretty minor upgrades like the seatpost and stem. The stem is something I'm looking to upgrade anyway due to my riding style and a Thomson seatpost saves quite a bit of weight there.
    I did laugh at your weighing of the bolts and the stem clamp by itself though. ;-)
    Nathan
    Reputation: swl7's Avatar
    Sep 2012
    what stem and seatpost do you guys use? Is the thomson seatpost pretty nice? most likely preference though.
    I used a TruVativ Team stem (~150 gr), but honestly anything light and solid should work. I have the Thompson post and it's solid, but definitely spendy. Neither a stem or a seatpost will make the ride smoother, but will shave some weight.
    The best thing you can do for $$$ light bike parts is buy a torque wrench and use it. I don't know how many seats I've seen slipping due to under torque and sheared items due to over tightening. Someone I know just had a carbon handlebar failure and looking at the pics, he had the stem faceplate tightened completely flush!!! He essentially crushed them.
    Airborne Product Dude
    Reputation: BigDaddyFlyer's Avatar
    The white handlebars that came on the green Goblin weigh 272.2 grams (.60lbs).
    While I don't want to get into weighing and posting weights of OE branded components, I will say that the new Goblin bars/stem are slightly lighter by a few grams due to design (mainly the stem) and lack of paint (the bars). The new Goblin seatpost is also slightly lighter due to lack of paint.
    While shaving 3-4 lbs by changing out the bars/stem/post is unlikely, you can save some weight here by going to nicer stuff from Thomson, FSA, etc. We use the components that we use because they save a little $$ while functioning well, and also are highly unlikely to fail due to being over-built.
    The biggest weight savings will be in the wheels/tires.
    Hope that helps!
    Jeremy
    Airborne Dude.
    Feb 2012
    Cool. I've already upgraded the front wheel and am feeling a little too poor to upgrade the rear right now. That's why I'm considering gradually upgrading the bars/stem/post when I get enough cash. Thanks for posting the weight of the bars BigDaddyFlyer. I'm not picking on the component choices from Airborne. Can't complain for the price I paid and everything has been very solid (minus the saddle that got bent rails on the first ride).
    It looks like it would be pretty reasonable to expect to shave just under a pound by putting on a reasonably light bar/stem/post. I calculated ~0.93-lbs saved by going with Ritchey WCS bar and stem, and the Thomson Masterpiece seatpost.
    Quote Originally Posted by Copperhed51 View Post
    Yeah no worries, I didn't think you were bagging on us. I just wanted to ensure that in the future no one asks me to go out and weigh every OE component we use .
    I also wanted to comment on why we use the components we use so that when people do future searches and find the thread its in there for posterity.
    Jeremy
    Airborne Dude.
    Nov 2012
    Quote Originally Posted by BigDaddyFlyer View Post
    Hope that helps!
    Jeremy
    thanks for the info. one quick question - maybe it is already posted elsewhere but I have not found it. what is the weight of your new Goblin as stock (for say an 18")? what about the wheels themselves?
    thanks
    Hope that helps!
    Jeremy
    Sorry, I didn't mean to lead anyone to believe I shaved 3-4 lbs with just a stem/bar/seatpost swap. I also swapped the wheels to arch ex's and the tires to Ignitors. Plus, I went tubeless.
    Quote Originally Posted by agb65 View Post
    thanks
    Like other manufacturers, we don't like to publish complete bike weights due to potential varriances in component weights. That being said, we have a new black 18inch Goblin in the office that's just under 27lbs.
    I don't have a weight to publish on the stock wheelset, sorry.
    Jeremy
    Airborne Dude.
    Feb 2012
    thanks
    Only thing I can tell you about the wheels is that the front wheel (w/o disc or skewer) is over 1,000g. My scale only goes that high and it was overloaded with the front wheel on there.
    That's not that unusual for a 29er wheel with a wire bead tire on it. The wire bead tires are much heavier than their folding counterparts.
    Airborne Dude.
    Feb 2012
    Indeed. I guess I should have mentioned that this was without a tube or tire on it (but there was a decent layer of dust on there). Also, the rim strip was included when I weighed it. The stock wheels are perfectly functional and are pretty easy to convert to tubeless (ghetto or Stan's or whatever) so I don't complain about them. I still run the stock wheel on the rear (Gorilla Tape ghetto tubeless) and beat the hell out of it. The wheel never complains so neither do I.
    Sep 2012
    Im gonna chime in here on the wheelset weight issue. When I got my green Goblin I found a Vuelta Nine wheelset for around $270 on the web. I ordered them and offset some of the cost by selling my nearly new WTB wheelset. Published weight on the Vueltas is around 2000 grams per pair. I have been very happy with them. Nothing wrong with the WTBs though. Just wanted to shave some weight at a maximum impact with minimal cost. Love my Goblin.
    Sep 2012
    anyone know the weight of the weinmann disc bull's on the guardian? doesn't seem like the weight exists on the internet lol
Hot Deals
Contests
Latest Mountain Bike Articles
