I have one too. While agree that one doesn't need to go carbon - once you throw a dropper post on there and some chunkier rubber - your knocking on 30lbs' door. I've got mine built with a dropper, big rubber and coil suspension and it's 32lbs but then I need that for some of the races I do. I'd prefer the same setup AND a 27lbs weight. Unfortunately id have to trade up to a Carbine for that.
Jury's still out on the blue wheels, but the blue chain ring bolts are here to stay. I have a couple wheelsets for it - the Havens are my main wheels. We'll see.
I have been riding Havens pretty rough now for over a year and have had no issues at all. Just a fine adjustment with the pre-loader every once in a while and they are good to go - no regrets.
My comments are pretty much like Trojan's. Note: I'm a light rider (160 with full gear) with no power. I ride "light" as well, which means we have fairly mild trails here; even if I "mash" the pedals, there's still no power there; and I try to pick smart lines. That said, I ride the hell out of my bike when I can. The front Haven is new - I had to upgrade to 20mm for the new bike. Rear is on its 2nd season on two different bikes, and I've had zero issues so far. I really like the wheels a lot so far. No tape needed for tubeless = big deal. My Rovals were lighter, but every tire change mangled the tape. None needed here.
just bought some havens for my tracer, half price in the chainreaction sale, was aware of the hub issues but thought I'd give them a go as I was changing to a bolt thru fork. Four rides in the rear has play, tweaked it up with the preloader & its been ok for a couple of rides but it makes you wonder..
ah enough posts for pics
Put on weight, up to just under 30lbs, swapped forks for both thru's so couple of new sets of wheels, swapped brakes to XT with big discs, went 10 speed
light wheels, heavy tyres
Good looking rig jeremy - I'm a big fan of that flat black. Do you have any room to drop to a shorter and slightly lower stem? (hard to tell but it looks like an 70-90mm on there) I noticed a marked improvement in overall handling when I went to a stiff 60mm zero degree stem with 760mm riser bars. But judging from the XL frame and post height you may need all the room you can get. At 6'2" im pushing the limits of my large T2 but find the stability benefits outweigh the initial cramped feeling. Just my $.02
Thanks. Being 6'5" the riding position is good for my everyday riding, but i do feel a shorter stem for more steeper technical terrain would indeed help. I will get round to trying a shorter stem.
Ok, so maybe it isn't the best view of my bike, but I found this picture today on my GoPro and liked it a lot. Those are my buddies in front of me on our first time doing lift-assist riding in Pennsylvania.
Here is my set up.. I just added the new 34 ctd fox float and the bike feels amazing! Bike weighs in at 27.5 pounds.
Frame: Medium - Works Blue
Fork: Fox Float CTD 34 160mm
Shock: Fox RP23
Headset: Chris King
Handle Bar: Easton Haven Carbon
Stem: Thomson X4 70mm
Brake: Shimano XTR Trial
Rotor: Ice Tech (7 inch front, 6 inch back)
Crank: Raceface Sixc (double ring w/bash)
Pedal: Loaded Flat Pedals
Shifters: Shimano XTR
Derailluers: Shimano XTR
Cassette: Shimano XTR
Saddle: Selle Italia SLR Ti
Seatpost: Thomson Elite
Wheelset: Easton Haven
Tire: Schwalbe Nobby Nic 2.25
Updated build: Replaced the RP23 and Talas with a DHX5 ti spring and a Van36. Huge difference in the ride. Also added some straitline AMPs and Atlas bars and stem and a set of Schwalbe HDs.
Nice upgrades E203, i dig that matte black finish. Thinking about upgrading the RP23 on my T2 as well - how much do you suffer on the climbs going from air to spring on the TVP?
Thanks, I live in FL where we ride mostly in reclaimed phosphate mines. The climbs are short and steep so I hardly notice the extra weight. The ti spring reduces the weight by about 1/2 pound. The bike is just under 31 pounds. The biggest difference was the coil in the front which now tracks much better and makes it easier to pop the front end up quickly over roots and rocks. The bike launches off of lips and wooden stunts much better with the coils on both ends. It just became a more responsive and funner ride for me.
Looking to pick up a new old stock 2010 tracer VP in works red. My question is how dose a 150mm fork work with the 6.0 in the rear or would you run it in the 5.5 in the rear. I’m in So Cal and wanting to do some enduro racing.
Looking to pick up a new old stock 2010 tracer VP in works red. My question is how dose a 150mm fork work with the 6.0 in the rear or would you run it in the 5.5 in the rear. I'm in So Cal and wanting to do some enduro racing.
moto - I ran my TVP in both 5.5" & 6.0" starting with a Fox 32 140mm then switching to a Fox 36 160mm (both TALAS). You can run it in either mode depending on the trail, the geometry works with either combination. In my experience, the 6" was more fun on the rough stuff but very tricky to eliminate pedal bob on the climbs. In 5.5" the bike is more responsive and a better climber but definitely not as plush. Do you already have the 150 fork? If not I would consider a 36 160mm for the TVP or the T2 - noticeably stiffer and more confidence inspiring than the 32 for rougher riding, but for racing with some good climbs the 32 is very capable.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
