Page 1 of 2 12 LastLast
Results 1 to 25 of 41
    Any 160mm 650b Forks Out There?
    If the Carbine is 160mm, why put a 150mm fork on it? I'd like to keep the same travel front/rear or 10mm more up front if not even.
    RS Rev has always been a fav fork but it's only 150mm.
    Anything else?
    UPdate: silly me. Ok the Fox CTD is 160mm. I prefer RS but Fox is ok.
    We Ride In God's Country!
    Actually, the Carbine is a 140 or 152mm travel frame depending on what travel setting is used.
    Quote Originally Posted by ducrider View Post
    Oh, it is? Thanks for letting me know. A 150 fork is good then
    The upcoming X-Fusion Slant is also 160mm, but I don't know if an internal 10mm travel limiter will be required like on their current 26" forks in a 650b application.
    Reputation: Duncan1104's Avatar
    Quote Originally Posted by Duncan1104 View Post
    The Revelation 150 is only 5-6mm shorter (axle to crown) than Fox's 160 so the geo will be pretty much the same. The Revelation feels much better than the fox. Plus you won't notice 10mm less travel.
    You sure about that? I haven't seen the official drawing for the 650b Revelation (it's not up on the Rockshox service site yet), but Bike Rumor lists the A2C length of the 150mm 650b Revelation as 539mm (Rockshox 650B Revelation Spotted, Gives Up Details - Bike Rumor).
    The A2C of the 160mm Fox 34 650b is 554.4, so a good 15.4mm difference between it and the 150mm Revelation.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    X fusion vengence, doesnt need a travel limiter
    I don't post to generate business for myself or make like I'm better than sliced bread
    Reputation: skyak's Avatar
    German-A Excite Criterion and Boost models are offered with 150mm travel and 650B. Axle to Crown is 545mm.
    german:A.® - lightweight bike engineering since 1995
    Quote Originally Posted by savechief View Post
    Oops. You're right. For whatever reason I was mixing up the a2c of the Fox and X Fusion. The X Fusion slant is 545.
    What I'd really like is a 650b 160 coil fork. All the forks so far are air only. Weight penalty but can't beat the plushness of coil.
    Come on Fox and RS!
    old's cool
    Reputation: derby's Avatar
    Quote Originally Posted by myitch View Post
    Come on Fox and RS!
    RS Lyrik coil, and u-turn coil clear Neo-moto 2.3 safely. I ran this for a few years with 650b.
    Fox 36 coil clears (pretty sure). The arch with plenty of gap, I haven't measured the crown clearance at bottom travel. Maybe someone can confirm?
    X-Fusion Vengeance coil easily clears the largest volume 650b. I'm on this now, an HLR. Awesome fork!
    ultralord Administrator
    Reputation: francois's Avatar
    Aug 1996
    Come on Fox and RS!
    The new Fox air fork, kashima 160mm 650b fork is ridiculously smooth and tuneable.
    fc
    Dissolved member
    Feb 2012
    If you can live with its limitations, a good used Lyrik U-Turn is a nice and relatively inexpensive fork to get you experimenting with 650b. The problem is, once you get to taste the 650b goodness, you will want more. You will want to step up and try the highly praised HD and NN and ... you will be SOL. I am still hoping for the 2.25 HD&NN and Maxxim Ardent to clear the Lyrik but if not, I can live with the excellent Neo Moto for a while. There will be a moment when I will want to switch to a Vengeance though.
    Quote Originally Posted by StiHacka View Post
    HD and NN? Translate please. Thanks.
    Reputation: in the trees's Avatar
    Mar 2005
    Schwalbe tire models -
    HD = Hans Dampf
    NN = Nobby Nic
    The NN and HD won't clear the Lyrik's arch? Bummahs. I'd prefer not to have to buy a new fork. What about the Fox 36 VAN?
    RENO/TAHOE
    Nov 2012
    I have a 2013 fox talas ctd 34 160mm 27.5 15qr tapered kashima on my 2013 intense carbine 27.5 and is super smooth. I used to have a 36mm vanilla on my nomad and i am blown away at what it can do!
    Dissolved member
    Feb 2012
    The 2.35s likely won't. The 2.25s might. 36 fox forks should be fine but I have no experience with those.
    Reputation: Simplemind's Avatar
    Any updates to the OP's question?
    Dissolved member
    Feb 2012
    XFusion Vengeance 160/170mm is officially a 650b fork.
    I guess I should have defined "good" as light, smooth, and reliable. The Lyrik is so close, but not in a 150mm.
    Dissolved member
    Feb 2012
    Quote Originally Posted by Simplemind View Post
    I am confused now. The Vengeance HLR Air is light, smooth and reliable but not a 150mm fork. Lyrik U-Turn is smooth and reliable and can do 150mm but definitely not light and won't work with any larger tire, forget about anything bigger than Neo Moto 2.3.
    Reputation: airwreck's Avatar
    Hurry up and wait... Fox is still ruling for 160, Pike soon, BOS looks good but no date, X-fusion sort of but waiting for the new and improved, White Bros has a 150, Magura has a 150.
    I would really prefer a dedicated 650b coil fork w/ 150mm travel, that can accommodate a 2.35 HDampf size tire.
    Doesn't look like coil will be an option, and that's almost true for DH forks now also.
    As a diehard coil user I will admit that I'm getting along well with my solo air fork.
    I would really prefer a dedicated 650b coil fork, that can accommodate a 2.35 HDampf size tire.
Hot Deals
Contests
Latest Mountain Bike Articles
