    Reputation: Streetdoctor's Avatar
    Oct 2011
    XX1 chainring/chain question
    Will dropping from a 30t to a 28t require me to shorten the chain a couple links? Trying to figure out if I need to order a new powerlock link or not also..
    No.
    You have reduced the circumference of your chain ring by 1". Since the chain is only wrapped on half the chain ring, you've reduced the length of chain required by 1/2 " - one link.
    Oct 2011
    Feb 2007
    I just changed from 30t to 28t, and I did remove a link (a link being a 1 inch long section composed of the wide section and the skinny section). I was hoping I wouldn't have to so I could quickly change between the two rings, but there was too much slop in the chain after the ring change.
  1. Gap between chain and chainring
    By dexetr30 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2013, 03:08 AM
  2. Chain jumping from small chainring to middle chainring
    By menusk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2013, 10:31 PM
  3. Clicking KMC Chain on XT Chainring
    By carpy95 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2012, 08:36 AM
  4. DIY Chain tensioner for 1 to 3 chainring
    By David C in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-07-2011, 09:35 AM
  5. Dirty chain & chainring question
    By rickcin in forum General Discussion
    Last Post: 07-01-2011, 08:29 PM
