Results 1 to 5 of 5
    Reputation: larryarroyo's Avatar
    Mar 2012
    Xt front der and shifter problem
    I just installed my xt FD and shifter, all is fine but when I shift to granny gear(smallest chain ring) there's loud thus noise like you slam something against the bike. Did i installed it wrong or is it broken. Please help me, your advice is very much appreciated..
    Thanks,
    Larry
    MTB B'dos
    Reputation: LyNx's Avatar
    Since it's hard to interpret people use of descriptive words like thud, it's going to be very hard for anyone to help, but I'll give it a go. If I'm guessing this right, the "thud" you're getting is because the FD is hitting your seat-tube, you need to adjust the LOW limit screw to stop this, other than that no clue. If you don't know what I'm talking about, visit the Park Tools website and look through their tutorials on it.
    Second the hard to interpret sentiment, but I'll throw this out there too.
    Could your derailleur be hitting the tire? What bike is this on? Did this happen on the repair stand, or while riding? Is the derailleur straight in line with the chainrings?
    Take a pic if you can, from side and from above, and we can help more.
    Mar 2012
    Sorry if its hard to understand what I mean, thanks for the help.
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by larryarroyo View Post
    Thanks,
    Larry
    Are you talking about chainsuck? That's where the chain sticks to the chainrings past the bottom part where it would normally let go and go back to the rear derailleur, and instead of letting go, it starts wrapping back around and up to where the chain lands on the chainrings, making a complete loop... and jams. Sometimes, the chain gets jammed between the chainrings and the frame.
    This is pretty common. Do a search for chainsuck on these mtbr boards. It's been covered a lot.
    Often, chainsuck is caused by just shifting from the middle ring to granny gear while pedaling hard... under load. Lighten up during the shift and see if it goes away.
    Chainsuck looks something like this vid I stole of the youtoobz:
    <iframe width="560" height="315" src="http://www.youtube.com/embed/2R2sQnqjmJc" frameborder="0" allowfullscreen></iframe>
  1. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  2. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  3. XO Front Der Shifter Problem
    By K091254w in forum 29er Bikes
    Last Post: 06-10-2012, 07:27 PM
  4. Sram X0 front shifter problem
    By ts8169 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2012, 10:15 AM
  5. HELP with SCRAM X7 front shifter problem
    By edj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 08:27 PM
