Results 1 to 3 of 3
    Jun 2013
    XT Brake compatibility with X9 shifters (9 spd)
    I'm going to replace my Juicy 7s with Shimano XT brakes and am wondering about compatibility with the shifter pod. I am running X9 9 speed on the SRAM integrated mount that allows the shifter and he brake to mount on one piece. What should I look for in the XT to keep this compatible? Or do I need to go back to having a separate bracket for each?
    I think I might be the last one to still be using the Juicy 7s so thanks in advance for your advice.
    Sep 2013
    Quote Originally Posted by Silent Drone View Post
    You need a Matshi adapter:
    Trickstuff
    That can be purchased from:
    http://www.radsportusa.com/
    Problem Solvers also has a solution. I tried both - definitely preferred the Trickstuff Matshi.
    Jun 2013
  1. SLX brakes and XT I-Spec B shifters compatibility
    By stygz1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2014, 02:11 PM
  2. Replies: 2
    Last Post: 04-16-2013, 09:13 PM
  3. XTR / XX Drivetrain Compatibility (Shifters / Front Der)??
    By G-Choro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2013, 09:10 PM
  4. Shimano compatibility question XTR shifters XT derailleurs.
    By Carloswithac in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-16-2012, 11:09 AM
  5. X9 Shifters w/ XT brakes Compatibility
    By Spudman003 in forum 29er Components
    Last Post: 05-03-2012, 03:35 PM
