Results 1 to 6 of 6
    Aug 2013
    Xlr rebound dial question
    Just picked up a used 2012 scalpel 1 with the rock shox xloc remote. I have noticed when I turn the xlr rebound dial in either direction, it never seems to reach a stop point. I had the LBS check out the bike when I first got it a couple of weeks ago and everything checked out. I have noticed the xloc acts like it may need to have air bled out of it. But my main concern is whether the rebound dial is working correctly? Shouldn't it reach a point where it stops?
    Thanks,
    M. Hawley
    ballbuster
    Reputation: pimpbot's Avatar
    Probably a better question for the cannondale forum.
    Aug 2013
    Thanks, I'll post the question there also.
    I have a 2012 PBR (same but no remote lockout) and the rebound has like 10-11 or so total settings, and definitely stops when you hit either end.
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
    Aug 2013
    Does it make a difference whether the shock is locked out or not in regards to the rebound dial stopping?
    I just tested it today and when locked out the rebound dial still worked the same
    '14 Kona Zone Two
    '13 Surly Big Dummy
  1. 2008 Fox RLC rebound dial
    By rootsandrocks in forum Shocks and Suspension
    Last Post: 02-01-2013, 08:28 AM
  2. Increase RP23 rebound speed (dial maxed out)
    By mr2peak in forum Shocks and Suspension
    Last Post: 10-13-2012, 05:16 AM
  3. 2010/11 Reba RL rebound dial won't turn
    By StolltheMusic in forum Shocks and Suspension
    Last Post: 05-25-2012, 05:59 AM
  4. Fox Float RL Rebound Dial stuck
    By Channner in forum Shocks and Suspension
    Last Post: 05-08-2012, 05:05 PM
  5. DHX 5 coil rebound dial position.
    By roughride in forum Shocks and Suspension
    Last Post: 07-24-2011, 09:54 PM
