Results 1 to 7 of 7
    ....just cruisin through
    Reputation: dfrazm's Avatar
    Oct 2007
    X-Post: BIG tires on a Yelli
    So I just scored a pair of Maxxis Minion DHF 29 X 2.5 shoes. Mounted on Stans Flows (old, not EX). Wouldn't you know it - rubbage. I only have contact with two of the shoulder knobs (widest point), only on the non-drive side, and only on the chainstay (the seatstays still have a good 2+ cm clearance per side). There is NO noticeable wobble in the rim, and the tire bead is seated completely and evenly. I am using a Hadley 10mm through axle, so I know that the wheel is centered in the dropouts.
    I have not done a measurement of the chainstays to see if they are asymmetrical, does anyone know if the non-drive side chainstay sits a little further inboard than the drive side? The other issue could be wheel dish, as I probably have 1 cm clearance between the tire and the chainstay on the drive side.
    So: Are chainstays asymmetrical, or do I have a dish issue. AND, if it is a dish issue, do people have their wheels dished to absolute center no matter what, or should I just have it dished so that my tire is centered in the chainstays?
    X-Post: BIG tires on a Yelli-imag0416.jpgX-Post: BIG tires on a Yelli-imag0417.jpg
    Here are just a few of the key ingredients: dynamite, pole vaulting, laughing gas, choppers.....
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    I have a very slight amount of rub on a modified SLX front der with 2.4 Ardents but the stays are good. Looks like you could fix it with a few millimeters of dish, not many frames will take a 2.5".
    The wheel is a extension of the foot
    Reputation: tortfeasor's Avatar
    May 2005
    I had the same issue with a 2.4 RR on the non-drive side.
    Evil Following
    Intense Carbine 275
    Giant Anthem Advanced
    Canfield Yelli Screamy
    Tarmac SL4
    Ducati M1100s
    KTM 350 XCF-W
    Oct 2007
    Quote Originally Posted by tortfeasor View Post
    Did you find a solution you could live with, or go to a smaller tire?
    WNC Native
    Reputation: nitrousjunky's Avatar
    I had a Yelli for a bit with a set of P35s and Rampages. In the right position, I could get enough wheel/tire flex to buzz that spot as well. From the looks of the pictures, you need to just go to the 2.3 DHR2 (or the 2.3 DHF or HR2) on the rear. If you ride it hard enough to need those tires, you'll be buzzing the stays no matter how it's dished with the 2.5s.
    Just my .02
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: MMcG's Avatar
    Jul 2003
    Holy Moly that's some Mega tire volume there!
    Reputation: gulljammer's Avatar
    Oct 2010
    HD's rock my Yelli
    I would dish your wheel so that the tire is centered between the stays. I had the same issue with my Hans Dampf's. Dished the rim to center the tire, no problems. I normally run the trail on front and pace on back which lasts me about a year of aggressive riding. In this picture I have an old trail on back which I am trying to get a couple of extra miles out of before installing new sneakers.
    Attached Thumbnails Attached Thumbnails X-Post: BIG tires on a Yelli-dscn0188.jpg
    neg rep for contributing to thread deterioration and posting useless comment. - wadafuq.
    www.fattiremassive.com
  1. BIG tires on a Yelli
    By dfrazm in forum Canfield
    Last Post: 05-09-2013, 08:59 PM
  2. Recomend me some good Am tires for the Yelli
    By WVJon75 in forum 29er Components
    Last Post: 05-09-2013, 10:17 AM
  3. ? Cobl Gobbler road Seat post on a Yelli Screamy?
    By Sin-man in forum 29er Components
    Last Post: 04-25-2013, 10:54 AM
  4. (X-post) Yelli Screamy 650 B?
    By jeffw-13 in forum 27.5
    Last Post: 03-07-2013, 08:27 AM
  5. (X-post) Yelli Screamy 650B?
    By jeffw-13 in forum 29er Bikes
    Last Post: 03-06-2013, 04:21 PM
