    Jul 2013
    Will a fork from a 13 Specialized Carve fit a 13 Specialized Rockhopper?
    The measurement I'm really only concerned about is the steerer tube length. I'm looking to buy a used fork that's coming from a 2013 Specialized Carve and need to be assured that it will fit as is on a 2013 Specialized Rockhopper. Anybody know firsthand? The specs on Specialized website does not have that information. Thanks!
    You can look at the geo for head tube dimension by size to compare. A 19" RH is 115mm same for the Carve. Carve is tapered steerer.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by eb1888 View Post
    You can look at the geo for head tube dimension by size to compare. A 19" RH is 115mm same for the Carve. Carve is tapered steerer. RH is straight. That is not compatible.
    I thought the Rock Hopper had a Tapered head tube also ?
    And used a lower bearing reducer to a 1-1/8" to fit the lower 1-1/2" head tube ?
    I must be miss understanding the use of the reducer.
    Sorry I'm just getting back into MTB after being out for 8 year's and trying to understand and learn
    So if Head tube length on a 19" R.H and 19" Carve are both 115 mm.
    I thought this would work
    Head tube angle for a 19" RH is 71* and the Carve is 71.5* now this shouldn't matter right ?
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Never trust a fart
    Reputation: frdfandc's Avatar
    Rockhopper has a tapered head tube. It just uses a reducer headset to accommodate a 1 1/8 straight steerer tube fork.
    The Carve is very similar to the Rockhopper as far as geometry goes. The Carve fork should fit fine with the proper headset.
  1. Fork upgrade for Specialized Carve SL SS
    By bstoic in forum Singlespeed
    Last Post: 07-31-2015, 07:33 AM
  2. Fork upgrade for Specialized Carve SL 29er SS
    By bstoic in forum Shocks and Suspension
    Last Post: 07-24-2013, 12:05 PM
  3. New fork for 2013 Specialized Carve SL SS
    By bstoic in forum 29er Components
    Last Post: 06-05-2013, 02:40 PM
  4. Replies: 5
    Last Post: 06-22-2011, 08:27 AM
  5. Is it worth upgrading the fork on a specialized rockhopper?
    By BeaverTail in forum Bike and Frame discussion
    Last Post: 06-19-2011, 06:56 AM
