Wide rear tire?
I happened onto a good deal on a 2.4 Racing Ralph. I'm currently running a 2.25 RaRa out back and I love it, but its starting to get low on tread, and I'm not sure what to do with the 2.4. I don't really want to put it up front - running a good condition Nobby Nic, and I don't think the RaRa is burly enough for me.
I know the thing to do is run a skinnier rear than front, but other than a bit more weight, are there any disadvantages to running a fatty like that in the back? I'm assuming its still going to roll well, and I know it'll fit (RIP 9)... What am I missing here? Why don't more people run a fat rear?
weight A lighter tire spins up faster and easier the 2.4 probably weighs around 800 grams and a 2.2 5 or 600
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
The trade off is better cornering and traction downhill, no? I'm not so concerned with climbing efficiency, but would love a little more confidence downhill.
Usually, frame clearance. Many frames do not have the room for 2.35-2.4" tires, and if they do, a rider will go for a burlier model than the RaRa, such as the Ardent, Hanz Dampf...
mtbtires.com
So what the f am I supposed to do with that tire!?
I'll be interested to see what people are running out back for a big tire. I like big tires, but I ride rigid, so I use them for the added cush. I've tried the 2.4 Purgatory, and liked it. Right now I have a 2.4 Trail King out back, but it's a heavy, slow rolling tire. Pretty great grip though. I think I'll use a Racing Ralph 2.4 out back in the Summer when the trails are dry. The Ralph seems really light to me.
Use it! See if you like it. That is all that matters.
And the RaRa 2.40 is a very light tire for its size.
mtbtires.com
I have owned a Rip9 & liked a big tyre on the rear, Even on my Jet9 RDO I run 2.4 Racing ralph rear & also 2.35 Nobby Nic.
Go for it fit the 2.4 on the rear.
Why not a Nobby Nic 2.35 in the front and rear on your RIP?
That being said, here's my RIP with the Nic 2.35 up front, Ralph 2.4 in the rear...
RIP with NIC/Ralph combo by ,
I much prefer the Nic in the rear as well.
The 14 warmest years have all occurred in the 16 years since 1997.
I occassionally run an Ardent 2.4 F&R on my N9. In super rocky/rooty terrain (certain MD trails, WV), I really like the added durability, grip and volume out back. Most of the time though, I try to run something a little lighter/faster out back.
The only reason, in my eyes, to run a narrower tire on the back is clearance. I use the widest tire I can. The only negative is increased weight. Contrary to popular belief, wider tires roll better than narrower ones of the same design.
"I know the thing to do is run a skinnier rear than front"
I think that trend is mostly due to most bike frames having limited space for large volume tires, especially 29" frames.
The trouble with having an open mind is that people will insist on trying to put things in it.
I run WTB Dissents 2.5s F&R on my RIP9, don't like skinnies in the back as I find the traction is lacking in several situations(especially with the small knob tires). Don't mind the weight, not racing. Also run Nevs 2.25s F&R on GT peace 9R SS.
The 2.4 RaRa is only a little bigger than the 2.35 NoNi. I would use it till it wears out (about 3 weeks)
Raised in a Chicken-Coop by Chickens
one thing I forgot to mention that as a singlespeed, I really appreciate the benefits of a faster/lighter and usually smaller rear tire. But again, it really depends on the terrain.
I'll probably end up with a 2.35 RR on the back at some point...light(ish), big(ish) and fast
I'm running a conti xking 29x2.4 out back and a specialized control purgatory 29x2.4 up front on my WFO. seems to do what I need it to do.
gnewcomer aka OldMtnGoat
Weight and resistance will be greater.
However, a wider tire will also have more traction.
buy it, try it.
Don't like it on the rear, put it on the front.
buy it, try it.
Why will resistance be greater?
Better grip = more rolling resistance. The more tire you have on the ground, the harder you need to push to get it off the ground.
Interesting article on rolling resistance vs width here.
Are you aware that the footprint (contact patch) area are identical, irrespective of tire size. The footprint area is a function of weight, assuming equal tire pressure. Therefore the wide and narrow tires will have the same area in contact with the ground.
From the Schwalbe article Simplemind linked:
"Which factors affect rolling resistance?
Tire pressure, tire diameter, tire construction, tire tread and other factors all have an effect on rolling resistance. The higher the tire pressure, the less is tire deformation and thus the rolling resistance.
Small diameter tires have a higher rolling resistance at the same tire pressure, because tire deformation is proportionally more important, in other words the tire is "less round". Wider tires roll better than narrow ones. This assertion generally generates skepticism, nevertheless at the same tire pressure a narrow tire deflects more and so deforms more."
So basically, scratch rolling resistance off of the list of the drawbacks. Weight will still be an issue, but the above is interesting to me...
I like larger volume rear tires on my hard tail - helps take the edge off. So, either a) build up a hard tail around it, or b) mail it to me.
PS - Chainlove.com, huh?
Eat, ride, eat, rest, repeat.
I saw it on Chainlove and thought about it, but I wound up getting the tire from my LBS for $20. Just hanging on the wall for the last month or so, so I made them an offer.
I jumped on the Chainlove deal.
Mounted them up both front & rear on my Gunnar Ruffian, kind of tight on drive side chainstay but should be good as long as I say out of the mud. I will know for sure after a ride on Saturady.
A few weeks ago I got to demo a Surly Kranpus (29 X 3" tire) and liked it, my thought is it may be Krampus light like, maybe. 75% of the width on a much lighter bike.
Which tire has been on chainlove? The Ralph 2.4?
- You may not post replies
- You may not edit your posts
Forum Rules
