Results 1 to 11 of 11
    Reputation: mojo722's Avatar
    Wide Flat Bar Options
    I am looking for a wide (710+ mm) carbon bar. I've seen the new Thomson bar and the Niner bar. They both seem nice. Are there any other options I may be overlooking?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Syntace Vector, 740mm +/- 5mm or 10mm.
    Death from Below.
    That's a good options as I've had Syntace bars before, but I should have qualified my in my OP that I am looking for a carbon bar. I believe this syntace bar is aluminum
    Formerly of Kent
    Negative. Syntace Vector Carbon High 5, Low 5, High 10, Low 10.
    Death from Below.
    meow meow
    Reputation: b-kul's Avatar
    race face next. 720mm flat bar, carbon.
    Big Boy
    Reputation: texasnavy05's Avatar
    3T makes one, and Enve composites
    -It's time to shred some mild to moderate gnar!!
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Niner make a carbon 780mm flat bar.
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
    Big Boy
    Quote Originally Posted by muzzanic View Post
    This must be fairly new. I just checked out the niner site, and that bar looks really nice. Pricey....but nice. I ordered a Thomson 2 days ago, and now I'm second guessing that decision.
    Aug 2014
    Could you use the Syntace Vector carbon high5/low5 and raceface next flatbar (w 1/4" rise) like the ritchey 2X handlebars. That is, turn them around and get either 5mm drop or rise? Or does the next for instance have some upwards bend?
    Have had a Ritchey 2x aluminum bar and I think it was great but for my dream build I will go to carbon and ritchey does not offer anything like this in carbon over 710mm.
    Oct 2010
    I have the thomson waiting to be installed and ridden. Seems like really solid construction and I like the less aggressive back sweep of 6˚ vs 9˚ for the Niner. 730mm is probably a good width for me coming from the 710mm Niner alloy. 780 is too much and so is $200 a pop. Got the Thomson for $120 from Wiggle UK.
    The thomson also has the +/- 5mm drop option.
    I don't ride enough!
    Oct 2007
    Quote Originally Posted by _tarzan View Post
    The Niner carbon bar has the same flip-able design.
    I like the carbon pattern in my Niner bar over the cosmetic carbon weave on my old Race Face Next bar.
  1. Best Wide Flat Carbon Bars?
    By Ace5high in forum Weight Weenies
    Last Post: 10-29-2013, 04:57 PM
  2. Wide, flat, hard saddles?
    By aBicycle in forum General Discussion
    Last Post: 06-16-2013, 11:21 PM
  3. Wide flat bar with a bit of flex?....
    By dirtrider7 in forum 29er Bikes
    Last Post: 05-12-2011, 01:20 PM
  4. Replies: 27
    Last Post: 04-07-2011, 01:49 PM
  5. Flat + Wide + 31.8 + 9 degrees + Carbon = ?
    By Earthpig in forum 29er Bikes
    Last Post: 01-19-2011, 08:59 AM
