Page 2 of 2 FirstFirst 1 2
Results 26 to 42 of 42
Thread: Wide 29er rims
  1. #26
    Reputation: azjonboy's Avatar
    I just got some P35's. Plan on building a front wheel with a Knard for my Black Sheep.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
  2. #27
    Reputation: thickfog's Avatar
    Oct 2010
    You haven't experienced awesome until you've tried. 2.4 or wider on. A 35mm or wider rim.
    CRAMBA Chairman
  3. #28
    Mr.650b - Mr.27-5
    Reputation: Kirk Pacenti's Avatar
    Quote Originally Posted by Salomo View Post
    I'm not sure what is wide enough for me either.. Basically I haven't ridden wider than 28mm so far but I would like to try out a rim wide enough to make actually a difference. I suppose you would be the best person to tell how much difference is there going from 28mm to 31mm and to 35mm and the difference between dl31 and p35 in real life :-). I guess that Knard would work better on p35 but I suppose it would be ok on dl31 as well. Eylets are of course nice which p35 doesn't have.
    Fwiw, when I initially designed the P35 it was going to be a 32mm wide rim. But Velocity felt they needed to go to 35mm to compete with the 35mm Salsa rim.
    The P35 rim makes a big difference in the tire profile and the way it handles. It creates a much larger contact patch, and offers a huge amount of grip. So much so that I had to change my riding style... I was almost (for me) impossible to get the tire to break loose, so rather than drifting through turns, you have to push it harder, lots of body english and counter steering required to get the most from it.
    Ultimately, I found a slightly narrrower rim (31-32mm) was more fun to ride. You get a lot of the advantages of the wider rim, great traction, higher volume, lower tire pressure, etc. But you can more easily roll the bike over and drift through turns more easily. Hope that helps.
    Cheers,
    KP
    If you like my products and services tell everyone. If you don't, tell me - kirk(at)pacenticycledesign.com
  4. #29
    Feb 2012
    Ok, that does help, thanks! I think that for me however the P35 might suit better, sinse it's actually the grip, or traction that I'm looking for. Trails that I mainly ride during the summer are quite narrow with lots of rocks and roots, very technical and quite low speed in general. Not a personal preference, it's just the way the trails are around here. Accents and decents are steep and short, so no high speed carving and/or drifting anyway, unfortunately.
    I'm also planning to try out fully rigid set up, so anything that makes the tyre bigger is good. Of course living in Finland there's tons of snow out there right now, so a larger footprint would be an advantage also, at least that's my guess.
    DL31 would be a very interesting option for my Tracer VP though when the wheelset needs updating.
    Thank for the reply, I really appreciate it!
  5. #30
    Oct 2010
    Quote Originally Posted by Kirk Pacenti View Post
    Cheers,
    KP
    That's a very interesting take on it. Interesting.
    Btw, thanks for the p35! I'd like to try the tl28 soon.
    CRAMBA Chairman
  6. #31
    turtles make me hot
    Reputation: NYrr496's Avatar
    I like turtles
  7. #32
    Feb 2012
    I don't think that's a 29er rim. At least I haven't seen other than 26" versions anywhere. Quite heavy also. Would be nice if Mavic came up with a wide 29er rim though.
  8. #33
    Unfortunately, the EX 729 rims only come in 26" size. Oddly, Mavic doesn't seem to make a 29er rim wider than 24mm.
  9. #34
    turtles make me hot
    OOps...
    I like turtles
  10. #35
    Oct 2010
    Re: Wide 29er rims
    Quote Originally Posted by sbruton7 View Post
    I called Speedway today, and they are no longer making the 29er Uma. They laced up their last few pairs of new old stock rims earlier this year.
    This is unfortunate. The way umas hold a bead on tubless is incredible.
    CRAMBA Chairman
  11. #36
    um... yeah
    Quote Originally Posted by Slow Danger View Post
    Might I add that Dirtrag had an article some time back that claimed Syntace was to be making these wheels in 40mm 29er. I think that article is probably wrong because nothing has shown up on the website. And the 35mm Syntace 29er wheels are not yet available, though the price plus cost to get them in the US might make them tough to find stateside.
    They're still not listed on the Syntace website but these wheels do exist. I've held them in my hand. They are HUGE.
  12. #37
    Jan 2014
    Based on OUTER width:
    Syntace as Wheelset w/cx ray spokes
    -W35
    -W40
    Velocity
    -Blunt 35mm
    -Dually 45mm
    Just a couple that come to mind within a wheel system. There are more. The Syntace wheelsets look glorious. Bor is another german company you don't hear much about in North America, but are fantastic, as are AX lightness. They both make light, wide, fast wheels. Always consider application of weight over number of spoke holes though; for example I tour alot and weigh 165lbs, plus generally carry 15lbs on trips, so will get a rim engineered for 200lbs+ with 28 spokes in front and 32 in the rear, or 28/28. If I were racing I woud go minimum 24 front and 28 rear, or more if my rim was relatively wimpy/light. But I also torque the rear wheel like hell. Spokes would be aero cx-rays for racing and d'lites or DT 2.0 straight butted/Comp/Champion for touring or rough recreational riding. It's not fully usefull to spout off rims alone. We must also consider application in terms of terrain/desired durability/riding beahviour and the wheel as a whole system.
  13. #38
    Reputation: Bike Whisperer's Avatar
    Can add a couple carbon rims:
    Derby 35mm
    Nextie 35mm
  14. #39
    Reputation: Velobike's Avatar
    Any new rims to add to this. I'm looking for a minimum of 35mm. Not carbon (price )
    Latitude: 57º36' Highlands, Scotland
  15. #40
    turtles make me hot
    Velocity makes the Blunt at 35mm and the Dually at 45.
    I think I was able to score a pair of 35mm Blunts for around 90 dollars each.
    I like turtles
  16. #41
    Quote Originally Posted by Velobike View Post
    Any new info is going to be easier to find in the 29+ section than in a three year old thread.
  17. #42
    The new Stans Flow MK3 seems like a decent option, though not labeled as a Plus rim/wheel.
    Rim Internal Width: 29.0mm
    Rim External Width: 32.3mm
    Rim Depth: 16.0mm
    Spokes: Sapim Force Black 2.0/1.7/1.8mm
    Nipples: Sapim Secure Lock Alloy Black
    Hub: Neo
    Hole Count: 32-hole
    Drilling Style: Symmetrical
    Color: Black
    Material: 6069 Aluminum Alloy
    Brakes: Disc only
    Wheelset Weight: 1807g (27.5") / 1918g (29")
    Rim Weight: 459g (26") / 480g (27.5") / 527g (29")
    ERD: 542mm (26") / 567mm (27.5") / 605mm (29")
    ETRTO: 559x29.0 (26") / 584x29.0 (27.5") / 622x29.0 (29")
    Color: Black
    ISO: 26"x32.3mm / 27.5"x32.3mm / 29"x32.3mm
    Tape: 30mm
    Valve: 35mm Presta
    Spoke Tension: 125kgf (1225N)
    Max Rider Weight: 250lbs (113 kilo)
    Max Pressure with 2.35" Tire: 37psi
    Max Pressure with 2.8" Tire: 26psi
