Results 1 to 10 of 10
    bt
    bt is offline
    Nov 2007
    where can I buy this exact....
    tire?
    "The WTB Nano Race 29er 2.1″ tire features an Aramid bead, DNA rubber, and a lightweight casing. The Aramid bead and lightweight casing definitely help drop weight, and at only 560 grams this tire is light and fast and definitely intended for use as an XC tire."
    max_29
    Reputation: max_29's Avatar
    Oct 2007
    your safest bet would be probably wtb web store
    Wilderness Trail Bikes - Nano 2.1 29" Race Tire
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by max_29 View Post
    cool, just not sure if it's the same exact tire.
    Nov 2007
    Are you just looking for the side wall look?
    Because the nano hasn't changed much since it's inception. Its pretty much the same tires its always been.
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by Renovatio View Post
    i believe this is a different model nano, it differs from my other nanos.
    it may be superceeded by now, not sure.
    I have one and i want another just like it if they are still made.
    bt
    bt is offline
    Nov 2007
    seems narrower and lighter than the regular nano.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bt View Post
    WTB switched suppliers a few years ago. May have changed the tire dimensions a bit.
    Tires also expand a bit with use, so a newly mounted tire usually look smaller than a well used tire of the same model/size.
    mtbtires.com
    bt
    bt is offline
    Nov 2007
    found this so far....looks like three models
    SIZE GMS LEVEL WEIGHT DETAILS
    2.1 52/47 TCS 590g Dual DNA Compound, 120 tpi casing, UST Aramid Bead
    2.1 52/47 RACE 560g aramid bead | dna rubber | lightweight casing
    2.1 52/47 COMP 705g wire bead | dna rubber | lightweight casing
    Dec 1998
    Sure, that is straight off the WTB web site and for the current production versions.
    The tires in your pics were made several years apart and in different factories.
    The one with the blue label is the older version. No longer made. Not available.
    mtbtires.com
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by shiggy View Post
    cool, thx
