Results 1 to 6 of 6
    Wheel Question...
    Been riding quite awhile but have a noob question here...
    Looking at buying a new 29" wheelset. What is the difference between 9 x 100 and 15 x 100? What does that mean?
    Fat-tired Roadie
    Nov 2007
    Re: Wheel Question...
    It's two different axle standards, confusingly stated.
    The traditional front hub is 100 mm wide over the lock nuts. The axle is wider, and has a 9 mm diameter. It fits into open dropouts and the hub is secured with a quick release skewer. The axle is part of the hub assembly pretty much full-time.
    There are also a couple of through-axle standards. In those standards, the hub doesn't include the axle, but is sized for a specific one. The axle slips through bores in the fork and through the bearings in the hub. How, exactly, they're secured varies. Some, including mine and a lot of XC-oriented through-axles, have a 15 mm diameter. The part of the hub that presses against the inside faces of the fork where it mounts is still 100 mm wide.
    Give us a little more background - what does your front wheel have now? What fork do you have? Post some pics of your front end. Get up close and personal around the front hub.
    A wheelset can come with changeable endcaps. So you can use them with different setups. And you can use a good wheelset on your next bike which will probably have a 15mm fork and 142 rear.
    Reputation: SpeshulEd's Avatar
    Oct 2013
    Don't forget 20x110!
    Cuz if you're like me, you read the specs for your bike without actually measuring and bought a 15x100 wheelset and then received the wheelset and the bike and realized the specs were wrong.
    Hey guys, lets go play bieks!
    Here are some pics. I was thinking it was the 9 x 100 due to the QR/dropout design. Not getting a new fork just new rims. Wheel Question...-front-1.jpgWheel Question...-front-2.jpg
    Thanks for the previous help and that to come!
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Yes, that's 9mm QR.
    Death from Below.
  1. TBc to LTc wheel question...
    By k2rider1964 in forum Santa Cruz
    Last Post: 10-15-2012, 07:28 PM
  2. Another wheel question
    By vitale232 in forum All Mountain
    Last Post: 07-19-2012, 02:42 PM
  3. SS wheel question
    By finger51 in forum Singlespeed
    Last Post: 12-14-2011, 07:05 PM
  4. Wheel Question
    By Lost Biker in forum Singlespeed
    Last Post: 12-13-2011, 12:10 PM
  5. wheel question
    By yourideit in forum Cyclocross
    Last Post: 10-01-2011, 09:43 AM
