Results 1 to 29 of 29
    What's a great all mountain wheel build?
    I'm replacing current wheels with a custom build. I'm not concerned with weight- want bullet proof all mountain with awesome hubs- thinking Chis King. What else should I be considering? Budget between 1-2k.
    Reputation: Nater's Avatar
    weight, terrain, riding style, bike setup?
    I'm Slow
    Reputation: paulrb02's Avatar
    Stans Flow EX for the rims. CK or i9 for the hubs. and DT for the spokes.
    RideSAMBA.com Mountain Biking in South Alabama.
    I'm 195- aggressive, usually ride uphill 1,500 vert then bomb down. Mainly single track. Bike is Yet SB95 with 34 talas.
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    Mavic 819 with Hope Pro II hubs.
    Edit: Doh, forgot I was in the 29er forum. Maybe Flow/Pro II then.
    Ocala Mountain Bike Association - www.omba.org
    I recently purchased a flow EX with a rear Hpoe EVO hub (silver) 14ga silver spokes with blue nipples.
    Colorado Cyclist did the build.
    I'm 6'4" pushing 220lbs.
    Reputation: mitzikatzi's Avatar
    Hubs. King, Hadley, I9, White industries, Hope (can have soft freebody, Al). Nothing wrong with Shimano XT.
    Rims lots of choice. Talk to your wheel builder. No Tubes (Stans) rims seem popular
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Aug 2010
    rim: Pacenti DL31
    hub: Chris King ISO
    spoke: Sapim D-Light or DT Swiss Competition
    Nowadays you have to choose your tire first and then pick your rims.
    UST: WTB Frequency i23
    Non-UST/ghetto tubeless: Flow EX
    turtles make me hot
    Reputation: NYrr496's Avatar
    Hadleys and Flow EX... That's bombproof at my weight (255). With you, it'll be nuke proof.
    I like turtles
    I have a set of Stans Flow with Hope Evo2's front and back laced with DT Double butt spokes. Work great for me. I'm 6'00 and 220 geared up ride single track stuff in michigan
    J-
    Happy Trails
    Specialized Carbon Rovals
    Have you considered the Rovals from Specialized Carbon Wheels. Haven't ridden them myself but heard they're a game changer, super stiff. cost some $$$$ but lifetime guarantee I believe.
    I am ridding flows with ZTR Hubs for around 2 years now and they have held up well. I hope they last until I can get the cash saved to get the above. 6' 195 before gear. Was heaver before and the flows havetaken abeating and keep rolling
    Singletrack, Microbrews and Pigskins...Almost Heaven
    I'm very happy with my Stans/i9 combo.
    Red Rock Roller
    Chris King w/fun bolt option, DT Swiss Alpine 3 spokes, DT Swiss pro-loc 2.0 nipples, Stans Flow EX rim all wrapped with a tubeless Hans Damph!
    This is a rear wheel I'm having built, 235lb aggressive Clydesdale, that has broken the rest and now needs the best!
    BTW my wheelsmith said the fit and finish of the new Flow EX is top notch stuff. So just a quick shout out to Stan's for making an already great product even better! When this wheel is finnaly mounted to my AM steed I will definately put it to the test!
    Lots to think about.
    [QUOTE: Mavic 819 with Hope Pro II hubs.]
    Avoid the Mavic 819, Great rim but to narrow for best performance. Mavic sells wider rims. The "19" of 819 means 19 mm of width inside the rim. Get a minimum 21mm. With all mountain a wider rim gives you a rounder tire on 2.2 in and wider tires.
    The Hadley rear hub gives you a maximum of performance, durability and versatility. You can adapt it to any rear wheel dropout configuration that you are likely to use. It is easy to maintain (with the proper tools) and it has proved to be very durable.
    I like 32 spoke 3 cross DT double butted with brass nipples. They last a long time with minimal maintenance.
    They are a little less expensive than Chris King and if you are sensitive to noise, they can be lubed to very quiet. The engagment is very quick!
    Thanks for all the input! This helps a lot.
    After many hours of research I concluded Chris King/Flow EX it a pretty sweet combo. I only have a few rides in, but 6'2" 270lbs giving it hell on some singletrack.
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    Enve AM's on DT240's
    Really cannot go wrong with Flow/FlowEx on Hope Pro II or King. I am 6'6" and weight 225 and have weighed as much as 255 and have had every rim out there go out of true until I went to Flows. They are cheap enough that I don't go around anything thinking about my rim and strong enough that I haven't even put one out of true in the last 4 bikes
    Banned
    If you don't care about weight, then I wouldn't be asking for AM wheels. Any wheel considered AM is not about to be bombproof if you ride some of the aggressive AM that's out there. It might hold up for a while, but if I couldn't bust it riding AM then I know some guys who would.
    Reputation: Shalom's Avatar
    Nov 2008
    My recommendation is Hope Pro 2 EVOs laced to either WTB Frequency i23s or Stans Flows/Flow EXs. Spokes, whatever floats your boat - they are all pretty good, be they DT, Wheelsmith, Sapim.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    I dig my flows with kings ...
    SPP
    Rigid.
    Reputation: carpe_deez's Avatar
    Is there a place to see complete wheel builds? I'm about to pull the trigger on a nice set: Flow Ex w Kings. Just need ideas on color combos and such. I have a dark blue TallboyC and am torn between white rims w dark hubs or black rims and light hubs.
    Reputation: Feldybikes's Avatar
    Quote Originally Posted by mitzikatzi View Post
    Hubs. ... Nothing wrong with Shimano XT.
    Well, except for the freehub blowing up. I just went through my third one.
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    No reason to do a custom wheel build with Shimano parts imo...
    I second the flow rims and Im loving my I9 hubs. Im not having any delusions about being easy on hubs, I put a LOT of torque down on my rear and so far the I9 hasn't had so much as chirp...
    I do all my own stunts, but never intentionally...
    Jun 2012
    sweet
    Well I was just going to ask this question as I am geting a new wheel set over the winter and from doing some research and what I see here Stans is my choice for rims but unsure of hubs at this point CK or I9 seems to be what everyone is going for. Anyone out there who has beat either one. My terrain here is roots,rocks, dust.mud you name it we got it and the hills are short and steep, hill climbs are very short but all you got to climb it, I am 6' 215.
    I'd go with a Hope/Stans combo.
    Nicolai Helius AFR frame size L for sale.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by fahza29er View Post
    Your terrain sounds like mine, not a lot of long slow climbs in FL BUT whats not long is made up for as steep and technical
    Anyway, Im really liking the I9 rear as I said before, but CK and nice hubs and Hadley. I dont think you will loose with anyone of those 3. What I did was just choose the one that was available for my wheelbuild and was on sale, all 3 are great. If I were doing a wheelbuild today and all were available Id like to try the hadley next.
    Quote Originally Posted by saul View Post
    I did Hope/Mavic on my 26 and they were very strong and looked nice. The only thing I didn't like was the noise. People rave about Hope and they did the job for me, but they are somewhat, annoyingly loud on the trail compared to others.
    Not hating, just stating
    Now I'm in the market for my 29er and I'm looking at the Kings bc they are strong and have smoother, quieter sound when rolling.
