Results 1 to 26 of 26
    Reputation: dcc1234's Avatar
    Nov 2008
    what the heck is this-- Seatpost
    Just got an extra long carbon seatpost in the mail with a bit of setback. Its probably me but-- this seatpost doesn't seem to have the normal bits for attaching a seat to it.
    What is this called and how do I install it? TIA for any light you can shed.
    Attached Thumbnails Attached Thumbnails what the heck is this-- Seatpost-seatpost.jpg
    lamer
    Reputation: llamma's Avatar
    monolink clone? MONOLINK SET-UP - YouTube
    It might just be a side-clamp design, but it's a little hard to tell from the photo
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Take a seat ... in your hand. And see what happens when you try to mate it with the top end of the post.
    Or contact the people who make/sell it.
    FLYXI
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Uhmmmmmm, Got any kids? They are usually pretty good at fingering out complicated stuff.
    The rails get clamped by the tangs on the silver endcaps. Loosen the screw, insert the seat rails as shown below, then tighten the screw.
    Attached Thumbnails Attached Thumbnails what the heck is this-- Seatpost-seatpost-copy.jpg
    Is it me, or...really!?!?
    Reputation: Magilla_Guerrilla's Avatar
    Jun 2010
    Nov 2008
    Thx Car_Nut, et.al
    Well, that was easy!
    Glad it worked out! Let us know how you like it.
    Nov 2008
    I love it. This type of seatpost looks simpler, lighter and easier to adjust than the 'old school' kind I am used to.
    My 19" 29er is bit small for me (6'0) so I hope my knees will prefer this seatpost's setback too.
    bt
    bt is offline
    Nov 2007
    you know where the other end goes right?
    Quote Originally Posted by bt View Post
    LOL
    @dcc1234, you obviously did not know what you bought, so here's another word of advice: These kind of posts with a rotating head have a tendency to slip if you do not put enough torque on the saddle clamp bolt. You will not be the first rider to suddenly have your saddle pointed at the sky or the ground while riding... If that happens once, the little teeth that keep the post head from rotating wear out big time and it will happen more often, requiring even more torque on the bolt to stop it.
    The bad thing is, it's hard to figure out how much torque is enough and not too much, which poses a risk of damaging the bolt or the threads.
    This is why I keep away from seat posts with this design... It's a little too late for that for you, so be sure to tighten the bolt according to the torque the manufacturer advises.
    Jun 2010
    You are also limited to saddles with small, round rails. No carbon rails or oval / rectangle type rails. Anything other than round will not get required contact to stay put.
    Reputation: ms6073's Avatar
    Quote Originally Posted by Magilla_Guerrilla View Post
    Not true, Bontrager has a seatpost with nearly identical parts and offers a replacement seatpost head for saddles with oval/carbonr rails.
    Basement Dweller
    Reputation: JosefFritzl's Avatar
    Those 29-er specific posts are a PITA!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by JeroenK View Post
    LOL
    I avoid them for the same reasons. Reminds me of the cheap-@** posts in the past that never stayed level. The foo-foo ones I have tried are no improvement
    mtbtires.com
    Nov 2008
    Thx JeroenK for safty tips-- that is huge-- I'll be having my LBS check out the torque. It sounds like this is not an improvement over traditional seatpost design.
    Jun 2010
    Quote Originally Posted by ms6073 View Post
    Well I guess if you completely change the hardware you could use a different saddle.
    Pointless, and doubtful it would work on a generic copy post, but true.
    LOL
    @dcc1234, you obviously did not know what you bought, so here's another word of advice: These kind of posts with a rotating head have a tendency to slip if you do not put enough torque on the saddle clamp bolt. You will not be the first rider to suddenly have your saddle pointed at the sky or the ground while riding... If that happens once, the little teeth that keep the post head from rotating wear out big time and it will happen more often, requiring even more torque on the bolt to stop it.The bad thing is, it's hard to figure out how much torque is enough and not too much, which poses a risk of damaging the bolt or the threads.
    It looks to me like there are no little teeth to stop the rotation. It must just be a friction hold; as you tighten the (single) bolt the wedged end pieces push tighter into the barrel at the top of the post?
    Actually while the default image in that link on the Bontrager site is of the entire clamp assembly, Bontrager also sells just the clamps. I know this first hand as I had to replace the clamps on the seat post clamp on my open mold time trial frame in order to mount a Fizik saddle with braided carbon rails.
    Quote Originally Posted by smilinsteve View Post
    Yes, and once torqued (typically 5nm is adequate), unless you add a spring as in the image on the Bontrager site on the bolt between the two clamp/wedges, it will take something like a rubber mallet to get the apart. While I have had no issues on the road, I would be hesitant to use a seat post with that clamp design for off-road use for the reasons already mentioned.
    Hard to see, but if that is the case, it's indeed a slightly less vulnerable construction. That said, it's probably still a case of torqueing (that's probably spelled wrong..?) the hell out of it. A friend of mine has a way of tightening bolts carefully. You know, "tight is tight enough". His Specialized Command post (same mechanism) did enduce a lot of cursing...
    Nov 2008
    op here-- FWIW, the seat post I bought has springs inside like the Bontrager, uses a 6mm allen wrench and the torque spec is 16NM.
    May 2012
    Quote Originally Posted by dcc1234 View Post
    Same? match saddle with round joint.
    Attached Thumbnails Attached Thumbnails what the heck is this-- Seatpost-sp4-1-09-05-16-39-59-.jpg
    My butt hurts just looking at that saddle.
    local trails rider
    Aug 2005
    You sit too much
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    I like the look of that saddle, padding being a two edged sword IMO.
    The D model (mtb) weighs a little more, 175g versus 135g.
    TIOGA USA
    I ride with the best dogs.
