Results 1 to 29 of 29
    Jun 2005
    Velocity P35: max spoke tension?
    I'm building a new wheel pair for my new single speed rigid 29er project.
    Does anyone know the maximum recommended spoke tension for the Velocity P35 rims?
    I can't find any information on the Velocity web site.
    Specs.
    Rims: Velocity P35 (36 hole, 3 cross)
    Rear hub: Hope Pro2 Evo SS/Trials
    Front hub: DMR Revolver front disc
    Spokes rear: DT SuperComp
    Spoke front: DT Revolution right, DT SuperComp left
    Nipples: DT brass
    Washers: DT brass
    /K
    Wheel brewer
    "For I am a Bear of very little Brain, and long words bother me"
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by gandhi View Post
    Specs.
    Nipples: DT brass
    Washers: DT brass
    /K
    You're safe to run 115+/- kgf with P35's.
    Washers? Why?
    Jun 2005
    Thanks, I took them up to about 115 and that was a walk in the park. The wheels are now straight and even tensioned
    Now It's just a matter of getting the rest of the bike assembled
    I use the washers mostly for looks, like a "hand built wheel trade mark". Apart from looks they reduce play between the hub flange and spokes which gives a stronger wheel.
    /K
    Quote Originally Posted by mikesee View Post
    Washers? Why?
    Wheel brewer
    Reputation: newfangled's Avatar
    So I figured I'd use this thread to mention that my rear 32 hole P35 has started to get hairline cracks at about 6 of the driveside spoke holes. I just cleaned my rim, which is why I noticed. I'm not really sure if the cracks are just in the paint or are in the rim.
    I just put the park tension meter on, and it was a pretty uniform 107kgf across the whole wheel. The wheels are only a year and a half old, so I'm a little disappointed.
    miwuksurfer
    Guest
    Bummer.
    I just took mine out for a ride this weekend and am super stoked on that rim with at 2.4" tire on the front, rigid.
    Hope mine hold up alright.
    I heard from Velocity's warranty department, and it sounds like they might be able to help me out. They said that they build their wheels to 120kgf, so I shouldn't be having any problems.
    (for me the real question will be how easy an RMA is, since this is my commuter. Spending a weekend relacing a new rim would be fine, but I can't have the bike out of commission for weeks or months to ship rims back and forth)
    Just an update - I sent photos of the cracking rim to velocity, and about 2 weeks later a set of replacement rims arrived at my door here in canada. I had to relace them of course, but that wasn't too bad.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    ya.. velocity is damn good... about my only complain about my P-35's is the paint is really bad, just peeling off everywhere around the edge of the rim and around the spoke holes...
    Kinda beaten the crap out of them thou so it matches all the scratches
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    May 2012
    Quote Originally Posted by newfangled View Post
    Not a P35, but Velocity replaced a 26" Cliffhanger that cracked internally (after being ridden from Banff to Costa Rica off-road) - the first rim they sent didn't make it through customs at San Jose/Costa Rica, so they sent another to Bogotá.
    V. good service.
    Quote Originally Posted by thomllama View Post
    Doh. I tossed my old rim in the garbage already, but I had intended to check if it was actually the rim cracking or if it was just the paint, but then I totally forgot.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    I have two sets of p35's and my only complaint is how many more burps I get compared to other tubeless set ups I run or have run.
    Oct 2007
    Quote Originally Posted by elwoodturner View Post
    ya have to run slightly higher pressures... with the ultra wide rim, the bead is kinda "rolled" in a bit so it doesn't lock to the face of the rim lip the same.. you need the tire side wall out bubbling a tad to keep the bead seated the way it's designed..
    It would be nice if the rolled in the bead lock/lip a tad to compensate.
    also ditch the Stan's and get Caffe Latex... it kinda skins the inside of the tire and after a month or so builds a super -ultra light tube like layer which helps prevent burping. ya.. some people get all whiny about the skinning... really don't get why... it doesn't weigh anything.. and I'll take that over the Stan's classic Latex Ameba any day!! it doesn't weight anything (after a yr I scraped it all out and it weighed less than a gram)
    but we're getting off topic here...
    B.Ike
    Mar 2011
    ^^The burping that happens with a relatively big hit isn't really a problem as it doesn't really change your psi too much and doesn't happen too often. The difference between the p35 and my other/older wheels is how low a psi I can gingerly limp back to the parking lot with.
    After experimenting w/ various versions of the "best tubeless brew" I'm sold on version 1 of WSS. It out performs stans in my opinion and my last batch came to 17 cents an ounce. A big plus is that it works great in the kids tubes.
    Since we're off topic anyway, what have people been using for tubeless rim tape with their P35s?
    I've been using 1" wide Gorilla tape, which works well at first. But it's thick enough that it catches on the tires when unseating them, so over time (and a few tire swaps) the tape has gotten pretty beaten up, and it starts to lift up from the rim.
    I was wondering if something thinner like stan's tape or the velocity stuff would work better?
    Jun 2005
    Well, I purchased the Velocity P35 specific rim tape http://www.velocitywheels.com/store/...pID=240&cID=78 It came as a kit with valves and tape for two rims. Perfect!
    /K
    Wheel brewer
    Oct 2007
    /K
    UGGG I hated it.. the tape didn't hold well and if you use tight tires the bead could often roll the edge of the tape back... Then the stem's base didn't really seal well against the web of the rim, found Stan's or Caffe latex stems to work better, Been using the new American Classic stems lately and they are friggin smashing!!! plus their kit is kinda WAY over priced. Have found gorilla tape and pretty much any stem to work better and cost WAY less!!!
    but hey, if it works for you... friggin awesome~~~!!! tubeless is the way to go no matter what
    B.Ike
    Mar 2011
    +1 on the gorilla tape, but I don't change tires often.
    That's what I've had happen with the gorilla tape, but if the same thing happens with the thinner tape then I'll stick with gorilla.
    Oct 2007
    wow, must really be tight to roll gorilla tape back!! stuff is rather sticky!!! I also always install a tube and inflate to "seat" the tape, either type.. also sets the bead so if you just break one side to remove the tube and install the stem you only have to fight one side to get seated...
    B.Ike
    Mar 2011
    I was going to add the part about the tube first as well. Seems to set the tape a little better.
    I think I've gone through about 6 tireswaps, so the tape was just getting old and soggy.
    B.Ike
    Mar 2011
    The main negative about the gorilla tape is how much sticky residue is left when you do have to change the tape.
    Oct 2007
    just rub down with some Orange cleaner or "goo Off" type stuff.. comes clean easy. Honestly thou, only changed mine once in like 4 yrs... did tear all the paint off the web of the rim thou...
    miwuksurfer
    Guest
    Glad it worked out well for you.
    couple of quick questions about the 35 rims guys. a) are they all that? make the best of a big tire? good and stiff? b) are they as cool looking as on the net? quite a unique looking rim. i thought they were anodizing them by now...
    Oct 2007
    Quote Originally Posted by cunningstunts View Post
    I wouldn't say there are "all that" but there is a definitely noticeable increase on contact patch to the ground. Also makes what I like the call the "water balloon wobble" from lower pressures a boast load less. ..
    they aren't all that heavy compared to similar types of upgrades, they are actually less weight added than a tire increase is...
    yes they are cool looking, esp if you like all the colors
    couple of quick questions about the 35 rims guys...
    I got my p35s because I use my 29er in the winter, and wanted lots of width. My bike isn't quite a Krampus, but it's worked really well.
    I was looking through my photos, and I don't have any real glamour shots of the rims, but they do look pretty snazzy:
    They're pretty infamous for dings though, if you haven't heard. I think I could comfortably run mine tubeless down to 16~18psi, but one day a giant dent mysteriously appeared, and ever since then I've tried to keep them above ~22psi.
    maybe i'm in a weird minority or something, but it would never occur to me to run my tires that low. i'm usually somewhere around the 26+ at the lowest. i run tubes, not intending to go tubeless, and just don't see the need. i don't have lack of traction issues, or any downside that i'm aware of.
    ^ honestly, I only ran them that low because I wasn't paying attention. I'm used to tires feeling squirrelly when the pressures are low, but with the P35s and some big Ardents that didn't happen. So I went weeks or months without adding air, and when I finally stuck a pump on I was surprised how low they'd gotten.
