Results 1 to 17 of 17
    May 2013
    Which upgrade would you do first
    Trying to decide which upgrade I want to do first. Going from stock non-tubeless wheels lighter stiffer tubeless ready wheelset or going from a X5 3x10 drivetrain to an XT 2 x 10. Use the bike mostly for cross country riding and racing. Ive priced it out and each upgrade would cost about the same. Thoughts?
    Reputation: kragu's Avatar
    Wheels! What set are you looking at?
    Especially if you're racing, getting rid of rotational weight is helpful.
    Sent from my iPhone using Tapatalk 2
    ready to ride
    Reputation: mattnmtns's Avatar
    Even though I just upgraded my part of my drivetrain before getting new wheels I would go new wheels first. My BB and chain were toast and got a whole SLX crankset $99 including the BB. The SLX is only a few grams heavier than the XT. The SLX is a 3x10 but I just took off the large ring and put on a BBG bashgaurd then set the high limit in the front derailleur so I can't shift past the middle chainring. Also you don't mention it but I assume you know you would need new shifters going from SRAM to Shimano?
    I would upgrade the wheels and ride your drive train until its worn out then replace. That was my intention, a year went by before I knew it and I wore my drive train out first. All good though, about to order some WTB i23s laced to some hopes. Actually might get the i19 for the back and save a 1/4 pound.
    Sent via my heady vibes from the heart of Pisgahstan
    Reputation: TheMaz14's Avatar
    Jul 2013
    Wheels for sure.
    Definitely wheels first, without question. Light wheels, tubeless, light cassette and rotors will make your bike feel amazing!
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Wheels for sure.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Reputation: mnyquist's Avatar
    Agree...wheels
    WillWorkForTrail
    Jun 2012
    Yep. You're always going to get the most bang for your upgrade buck/weight decrease benefit from the wheels. Changing the drive train will give you a different drive train. Changing the wheels will make it feel like you've got a new bike.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Wheels and new tires.
    You won't believe the difference these two things can make on your bike. A new set of wheels turned my bike from a sluggish porkster where I struggled up the hills on into a bike that I can climb very well with. Get the lightest most durable set you can afford that doesn't include proprietary spokes.
    There is not much choice between rotten apples.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Yep...wheels. First thing I changed on my first bike a few years ago an the difference was instant.
    Let's make like a Bike and get the Huck outta here...
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    I'm in the same boat I have decided to do a set of Stan's Arch EX with either Hope 2 EVO hub's or Chris King hub's.
    I'm not 100% sure if I wan't to dump the extra Money for Chris King hub's even thou they are 72 Pt. instead of 24 Pt. of engagement.
    Going on a 2013 Stump Jumper Comp 29'er
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Reputation: pitworkz's Avatar
    Jun 2013
    Wheelset for me. Big weight loss
    Jul 2013
    Quote Originally Posted by PauLCa916 View Post
    I just had a set of Arch EX / Hope Pro 2 Evos built for my Jet-9 build. I'm not finished with the build process (where does the time go?), but really looking forward to the ride. I couldn't justify the extra cost for the King hubs since I was busting the budget anyway.
    Reputation: docter_zab's Avatar
    Jun 2013
    I did all the above (drivetrain/brakes, then wheels) I agree with others that wheels made much more of a difference (went from stock Bontragers to I9s on Stans)! But brakes is an awesome upgrade as well. Esp if you go from Avid to Shimano!!!
    ​mountain biking is fun.
    Jul 2013
    can anyone recommend decent wheels that are affordable? thanks
    Depending on your weight, Stan's Arch EX or Flow EX can be had easily for under $450
    Jun 2013
    Stans...good rims...good price
  1. Why does every upgrade...............
    By rufus in forum Specialized
    Last Post: 01-30-2013, 09:03 PM
  2. Replies: 11
    Last Post: 06-06-2012, 01:41 PM
  3. Tora 318 fork upgrade.. What to upgrade to?
    By chadalex78 in forum General Discussion
    Last Post: 02-08-2012, 08:42 PM
  4. i want to upgrade.
    By pacet004 in forum Shocks and Suspension
    Last Post: 03-03-2011, 02:05 PM
