Results 1 to 8 of 8
    Jul 2013
    New question here. Upgrade from Suntour XCR
    Hi I am new to the forum and I recently got back into Mountain biking. I am curently riding a Scott Aspect 920 and I want to replace my Suntour xcr fork for around $300 dollars. I am a noob so I have no idea where to start. I don't ride Downhill and I'm not flying off any jumps. I'm looking for something well rounded and the biggest ban for your buck. Like I say I am a noob, but I am trying to learn as much as I can about Mountain biking as I can. Any help would be greatly appreciated. Thanks and can't wait to read responses.
    Reputation: hankscorpio's Avatar
    Jun 2012
    I'm going to upgrade my Suntour XCM to a Manitou Tower Expert soon. I should be able to get it for 300-320
    What you can end up with is a much better handling and capable bike, One that will be safe and fun to ride on difficult/fun trails and quickly let you improve your skill level..
    To get there you should improve the fork, wheel and tire.
    The Raidon from Suntour is 5lbs. for 200.
    A lighter fork that works will make the most difference. A 3lb fork like a 2011 or 2012 Rockshox Reba dual air or Manitou Tower Pro off ebay. These are the most tuneable for small bump compliance. This takes 2lbs off the front of your bike for faster climbing over bumps and quicker steering. They come with 9mm dropouts or 15mm thru-axle. 15mm is stiffer and cuts down on fork flex. A 9mm thru-bolt Dt Swiss RWS works with 9mm dropouts as something better than quick release but less than 15mm.
    Save 1-1.5lbs with a new wheel. It will also be stiffer and stronger and have end caps you can change to fit 15 or 9mm forks now or in the future.
    An ArchEX or FlowEX if you weigh over 200 or so is about the cheapest like this for $151.
    wiggle.com | Hope Hoops Pro2 Evo MTB Front Wheel | MTB Wheels
    The drop down shows Arch or Flow but EX is what you get.
    You can lace your own and save a little money and more weight with a Novatec D711 hub, Supercomp spokes/brass nips. Easy with a Park TM-1 tensionmeter.
    You already have a 570g pretty grippy tire. A Nobby Nic Performance could give you a little more grip. 37 from ebike.
    Jun 2012
    This is a stupid question so I apologize in advance. When it says wheelset does that imply front and rear wheels? Or is it one wheel and "set" means it has the spokes and hubs and is not just a rim?
    Quote Originally Posted by hankscorpio View Post
    Wheelset means both. The front makes the most difference to the handling, climbing and turning of the bike.
    Jun 2012
    Thanks does it also come with hubs?
    Yes and changeable end caps for different forks.
  1. If you want to upgrade your Suntour fork
    By wmac in forum Beginner's Corner
    Last Post: 10-09-2017, 04:38 PM
  2. Fork upgrade. SR suntour raidon vs epicon
    By cdeno0001 in forum Beginner's Corner
    Last Post: 06-26-2013, 04:24 PM
  3. Suntour Chainring Upgrade
    By Mirkin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-28-2012, 06:24 PM
  4. Upgrade from suntour fork 29er On Giant Talon1
    By endo2413 in forum 29er Bikes
    Last Post: 08-23-2012, 10:01 PM
  5. Fork Upgrade- From 29" SR Suntour XCR LO
    By MechMan314 in forum Shocks and Suspension
    Last Post: 05-14-2012, 06:51 PM
