Results 1 to 3 of 3
    Reputation: Burt4x4's Avatar
    Feb 2013
    Upgrade Handelbars & Stem or?
    Hello All ~ newBee on upgrades, I have a '13 Hardrock Sport 29er. I have about 300miles on it now and I want to raise my bars up. I feel ALOT of pressure On my palms and too me if I wasn't leaning so hard on my grips I could alivieate some of this palm pressure = raise my bars by swapping in a raised bar, yes/no?
    Here is what Specialized says is on my bike:
    Stem = Alloy , 4bolt clamp, 10deg rise, 25.4mm
    Handlebars = Specilaized Flat Bar, alloy, 660mm wide, 8deg backsweep, 4deg upsweep, 25.4mm
    So I would like ot swap out the "flat bar" for a raised one.
    Any input on this would be great!
    I plan to swap the XCT fork out for "air shock" but not quite yet. Stock is 80mm if I put in a 100mm shock will this "raise" my front geometry?
    Speak to me ole' wise MTBers :-)
    Upgrade Handelbars & Stem or?-784360d1364227099-13-hardrock-sport-29er-102_3727.jpg
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Feb 2013
    OK so reading reading reading...
    20mm rise or 30mm rise?
    Looks like some bars aree 31.8mm wich means I would need a new stem to run that size...so I think at first I'll stick with 25.4mm...
    I assume if you need to know if you want 20mm or 30mm rise would be trial and error... and stick with what fits?
    What brand handelbar should I get? I think I'll just stick with Alum Alloy...no carbon needed..
    Feb 2013
    Is "oversized" 31.8mm a good upgrade from 25.4mm, for the stem?
    I'm a recreational rider with wanna be attitiude :-)
    Were is all the handelbar opinions?
  1. Stem upgrade suggestions
    By cnitram in forum 29er Components
    Last Post: 07-08-2013, 07:50 AM
  2. stem upgrade
    By Vitamin G in forum General Discussion
    Last Post: 08-27-2011, 07:32 AM
  3. need help stem upgrade
    By Ginbraiba in forum Cannondale
    Last Post: 08-14-2011, 08:12 AM
  4. Easton Handelbars on my epic Comp Carbon
    By UCLA ANDY in forum Specialized
    Last Post: 08-12-2011, 12:18 PM
  5. Stem and/or bar upgrade
    By TMLGN in forum All Mountain
    Last Post: 07-30-2011, 04:29 AM
