Results 1 to 23 of 23
    Oct 2013
    Twist or thumb shifters??
    Id like some opinions on both finger shifters and higher end twist shifters. Which do you like and why?
    my own opinion..
    having own the XTR / XT and SRAM XX/X0 grip shifter 2x10 series.
    I like the fact that XTR allow me to use either my thumb or finger to go up or down the gear, the rapid rise works but I think XTR allow 4 rear shift at one go. and 2 upshift at one go.. the shifters was upgrade to an ISPEC which allow me to remove he clamp. this also allow me to unclutter my cockpit area. XTR also feel more robust that my SRAM
    SRAM Grip shifter, very diff feeling. initially with the stock grip and the grip shift, I couldn't use my existing XTR brakes as the lever was too short. once I got that sorted out and use a foam grip and shorten it to my liking. it felt good.. shifting is very fast.. u can just shift all the way up and all the way down. depending on how much travel your wrist can go .... crisp shifting.. coming from thumb shifter. It took me a while to be able to shift the grip when ensuring that my grip on the bar isn't compromise. once that is solve.. it become 2nd nature. you might want to take note is that for grip shift. you might forget which gear you are in as the shifting can be quick fast ...
    what worry me now is that if I do wear off the rubber grip of the grip shift, I am not too sure where I can get the replacement parts.
    Reputation: ghettocop's Avatar
    High end GripShift......XO or better for me. Used them first in 96' (X-Rays) and have never gone back to trigger. Faster, lighter, far less prone to crash damage, can dump an entire cassette in one turn, and for me the most important...... when I am tired, gassed, bonked, whatever...manipulating fine motor skills like thumbs and forefingers is far more difficult than just grabbing and twisting with your entire hand. Think they look a lot cleaner too.
    Just my opinion though.......most prefer and use trigger.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by Jack Jack View Post
    Replacement rubber for grip shifts are easily found all over the internet.
    Reputation: Flash29r's Avatar
    May 2013
    I have used both and like both. They each have their pros and cons. Hell, I even have used the old XT top mount thumb shifters ages ago. Currently have XT shifters on my '12 Flash Carbon 29r. I have had no issues with them and I have noticed no fatigue problems either.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by ghettocop View Post
    +1 what he said.
    I'm using X-7 thumb shifters now and I miss my grip shifters.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Feb 2012
    Another vote for X0 or XX Grip Shift. I tried the X0 on my 1x10 to see what they were about and ended up really liking them. I like the fact that I can dump the whole cassette in one down twist, and skip multiple cogs on the up shift. I just picked up a front and back set for my 2x10.
    Another plus is bar cleanup, espcially if your running non-SRAM brakes (no need for problem solvers, matchmakers etc...).
    As mentioned about, I'm running mine with foam grips where allows easy customization of shifter placement.
    2012 Diamondback Podium 3
    2013 Specialized Stumpjumper EVO 29 - MIA
    2013 Giant Anthem X Advanced 2
    Reputation: skiahh's Avatar
    I'll start the apparent dissenting vote. I prefer the trigger shifters. Just never could get used to the grip shifters.
    I've never had any crash issues and the argument about cleaning up the bars doesn't carry much weight with me since I'm a function over form guy and, for me at least, the triggers give me better function.
    Quote Originally Posted by BruceBrown View Post
    i ask my local Distro that bring in SRAM.. guess what they told me.. worn out? just buy a new set........ same for the local shop. all tell me if the local dist don't bring me. they cant get it.. ..
    would you by any chance have the link to get them online?
    RAKC
    Reputation: tigris99's Avatar
    Im a shimano trigger person as well, I run slx (same as xt just tad heavier) and never one complaint. Sram triggers I dont like could never get them comfortable. Grip shift I tried on a test ride and dont like them. Matter of preference but fatigue sets in fast for me with grips where as no matter how tired i am never had an issue using my triggers, especially when just trying to fight enough energy out to make it the last bit to the trailhead shifting constantly. The only thing I like about grips over triggers is clring a whole cassette in one good twist of the wrist (though moving several gears on rough ground I always got unstable handling during the shift and/or missing my desired gear).
    To each their own, one is no better than other, just personal preference, go ride them both and let us know what works best for you and why.
    The problem I had with the Sram x7 triggers is once they were adjusted for comfort, I would occasionally bump the shifter. Now riding XO gripshift, just like riding a motorcycle, twist to go faster.
    2015 FAT BOY
    2016 SPECIALIZED DIVERGE EXPERT di2
    Oct 2013
    I like them both. After a race my left thumb was really sore. I might set up a twist shifter for my front and a thumb shifter for the rear.
    Reputation: lancelot's Avatar
    Shimano triggers and Sram Gripshift. Not into Sram triggers.
    The LPG
    Reputation: hey_poolboy's Avatar
    I prefer Shimano triggers. Mine are currently xt. Due to an old right wrist injury I just can't do grip shifters.
    ballbuster
    Reputation: pimpbot's Avatar
    Just don't get dual control. I have enough competition when trying to hoard them for myself.
    Pic I stole from the interwebzones:
    Feb 2012
    Quote Originally Posted by pimpbot View Post
    Best avatar image! Is that the Thomas Flare?
    ballbuster
    Quote Originally Posted by stop619 View Post
    No, that's breakdancing Jesus. It didn't res down very well.
    Always Learning
    A couple of examples...
    SRAM X0 Right 9spd Grip Assembly Black - AEBike.com
    SRAM X0 Left Grip Assembly Black - AEBike.com
    Sram Drehteil mit Griffstck fr X.0 3-fach mit Micro Rasterung - Bike-Components
    BikePedia, Shifter grip kit, SRAM 00.0000.200.597 "twist shifter/grip" - Full Item Description
    Sram Rocket Grip Assy Left 3pcs X9 00.0000.200.569
    Part numbers for the various models to get the replacement grips are listed here:
    <a href="http://www.flickr.com/photos/7166535@N05/10939217525/" title="TwistSRAMparts by BBcamerata, on Flickr"><img src="http://farm4.staticflickr.com/3773/10939217525_0f357f3669.jpg" width="460" height="283" alt="TwistSRAMparts"></a>
    Bicyclochondriac.
    I hope SRAM supports the newer gripshift models in this regard better than the older ones.
    My experience with the older style 5.0/7.0/9.0/9.0SL shifters is that the shifters themselves last forever (as in 12 years and going strong), but the grips don't, and were very hard to come by just a few years after they stopped making those models. In particular the slimmer grips were a no-go as soon as they stopped making the shifters. I had to look for NOS of complete shifters just to get new grips. I'm on my last set now, not sure what to do after this.
    If I ever get a newer set of GS, I'm going to buy at least one set of replacement grips while I am at it. These are way too expensive to be buying NOS just to get the grips in the event that SRAM decides to try to kill GS again.
    Nov 2012
    I haven't used anything but grip shift for over 15 years. Now have the XO...
    My only caveat is mating them with brakes. Due to their design, I wound up getting Hope brakes, since the Avids that were on my bike would not snug up to the grip shift. The Hopes fit very well.
    I really like the grip shift, and i have grips that are designed to be used with them - which also helps...
    Always Learning
    Quote Originally Posted by kapusta View Post
    I hear you on the longevity. I have the original X.0 9 speed shifters that I bought in 2003 and they still work great at the end of their 11th season. I lost one of the gear indicator windows last year and both of the rubber grips are pretty much sticky mush at this point. I find it hard to complain that I got 11 full seasons out of the original rubber grips.
    I know the replacement grips and window are available, and I found them online to purchase last month. However, before I ordered I found a slightly used pair of newer X0 9 speed shifters for $35 that I bought from a local rider. That was cheaper than I could get the replacement rubber grips and window. I may still purchase parts online so I have a refurbished set in my parts bin. I also consider that during the current lifespan of my X0 twisters the industry has moved from 9 speed to 10 speed, and now on to 11 speed. So who's to say what will be available a decade from now and whether or not SRAM owes users of older gear more than a decade of supplying replacement parts?
    Also, how old are the replacement grips that have been sitting around awaiting purchase? I wonder if some of them that are available have been warehoused for a nearly a decade and how long will that rubber actually last once mounted and put into use?
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    ^^wear did you find the windows? I'm missing 2. I've had grip shift since the 90's, but the last couple of years I've bought 2 shimano triggers as I got tired of porly fitting brake levers.
    ballbuster
    I'm still a fan of Shimano shifters. I've never had one fail on me, I like the light touch. Every SRAM equipped bike I've ever tried, the shifting feels heavy. Couple that with some of my friends bragging that they rode for 4 whole hours, and they rode so hard their thumbs hurt from shifting so much! I've never had that happen to me, even after all day epics or 24 hour races.
  1. Replies: 24
    Last Post: 09-11-2012, 07:24 AM
  2. Twist Shifters to Tigger Shifters?
    By coopdad in forum Families and Riding with Kids
    Last Post: 02-10-2012, 09:32 PM
  3. Thumb-shifters
    By Neuner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-21-2011, 10:53 PM
  4. 2x9 with X0 twist shifters
    By frenk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2011, 08:46 AM
  5. X-9 Grip shifter vs. X-9 thumb shifters
    By 22GILBERT22 in forum Arizona
    Last Post: 04-09-2011, 01:19 PM
