Results 1 to 5 of 5
    Reputation: Putt4Dough's Avatar
    Feb 2013
    Tubeless pressure for XC mountain riding.
    While I am waiting for my new tubeless wheel set, impatiently might I say, I was wondering what tire pressure is more adequate for eastern mountain XC riding? My riding type is lots of climbing in rocks, roots and dirt in technical and fast up and down runs on dirt.
    What tire pressure are your tires set at and what type of trails do you ride?
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    Me: 195lbs
    Bike: 30lbs
    Front: 2.3@20psi
    Rear: 2.1@25psi
    The leg bone's connected to the Cash Bone!
    Feb 2013
    What type of riding and terrain?
    Perpetual n00b
    XC on varied terrain. Locally it's mostly hardpack with roots and logs but no naturally occurring rocks. An hour or two north or south and there are more rocks(quarries), roots, and sand. I leave the psi the same for everything.
    Sep 2012
    Depends on rider weight, terrain, riding style, tire size and wheel width.
    205lbs, hard pack, rooty, rocky, loose, XC smallish drop offs, I ride pretty much everything. 2.25 Nic front, 2.25 Ardent rear on a 17mm internal width wheel.
    I can't go under 27psi upfront or I feel the sidewalls rolling under. Rear under 28psi = burping under hard cornering with a touch of brake, so I usually run 29-30psi.
    You want to ideally run as low as possible without sidewalls rolling, burping or bending wheels. You will need to experiment! That's half the fun IMO.
  1. Tubeless Air Pressure Changes?
    By SCR818 in forum Wheels and Tires
    Last Post: 04-04-2012, 10:29 AM
  2. Tubeless Kids Pressure.
    By Metamorphic in forum Wheels and Tires
    Last Post: 09-17-2011, 04:06 PM
  3. Tubeless tire pressure
    By tommyturbo in forum Specialized
    Last Post: 08-23-2011, 01:49 PM
  4. Dialing In Tubeless Air Pressure
    By RagerXS in forum Wheels and Tires
    Last Post: 08-13-2011, 10:34 AM
  5. Checking tubeless air pressure ?
    By keen in forum Wheels and Tires
    Last Post: 08-06-2011, 08:53 AM
