Results 1 to 8 of 8
    Trimming Handlebars
    I'm in the process of a new build and was wondering what's the best, and cleanest way to trim my new handlebar? I have an Easton Haven on my Niner Jet 9 which is 711mm wide. I like the width of it so I want to keep the new one around that mark. My new bar is a Blackspire 768, which is 760mm wide. There are markings on each end which I assume are for the purpose of cutting it down. Any recommendations for making the necessary cuts?
    *2018 Pivot Mach 5.5 Custom Build*
    *2018 Orange Alpine 6 Custom Build*
    *2017 Knolly Warden Custom Build*
    Terrain Sculptor
    Reputation: Trail Ninja's Avatar
    A pipe cutter. Get one at your local hardware store. You'll find a ton of uses for it even if you never cut a set of bars again.
    Go slowly, don't force it.
    Quote Originally Posted by Trail Ninja's Son
    You may be happy to hear that my dad has kicked cancer's ass. Now he's looking for whoever sent it.
    Reputation: djcweed's Avatar
    I have used a hack saw and a miter box with pretty good success. Make sure your wear a mask of some kind as you don't want to be breathing in carbon fiber.
    Reputation: Schott's Avatar
    Nov 2012
    I second the pipe cutter.
    Terrain Sculptor
    Is it carbon fiber? I thought it was aluminum. I don't know if a pipe cutter will work well on carbon fiber.
    Edit: I found this.
    Blackspire 768 Riser Handlebar | Buy Online | ChainReactionCycles.com
    If that's your bar, a pipe cutter will work great.
    Quote Originally Posted by Trail Ninja View Post
    Edit: I found this.
    The Haven is aluminum, as is the Blackspire.
    Nov 2012
    Correct, I don't think I would use it on carbon, and you would be well advised to get the proper blade for a hacksaw to cut carbon as well.
    Thanks for all the help guys. Looks like I'll be heading to the hardware store tomorrow.
