Results 1 to 20 of 20
    May 2013
    Trek Marlin upgrades
    Been enjoying my Trek Marlin for a couple of years now and am ready to make a few upgrades. I've recently purchased new grips and pedals. Now I want to lighten the bike. Any suggestions?
    Tires, wheels and fork.
    RAKC
    Reputation: tigris99's Avatar
    Fork is the big one, stock fork is heavy as hell. Tires next. Wheels arent bad but could use an upgrade at some point.
    Not going to fully repeat what I did to my 2012 marlin, but only thing stock is seat post and weight is right about 29-30 lbs atm (roughly 4-5lbs lighter than stock). And thats only with slight upgrade to Rock ShoxXC 32Tk forks which was 1.5-2 lbs savings right there. Spending money on the Rebas (which Im going either those or Manitou Tower Pro forks) will shed off close to another lb and improve handling alot.
    Reputation: Giancarlo's Avatar
    Sep 2013
    I have a Marlin 2012 model, what fork and tyres you suggest, I use my bike only as a city bike.
    Cheers
    The upgrade recommendations were aimed toward trail riding. They aren't needed for road. Schwalbe Big Apple tires are one option.
    I would do a continuous housing/cable run with lined housing and slick coated stainless cable. You have to drill the stops enough for the housing to go through at the mid points.
    Fat-tired Roadie
    Nov 2007
    For city riding, as long as it goes, stops and shifts, the rest doesn't matter. You're slow because there are lots of stop signs and intersections.
    If you have to replace your fork and tires anyway, go for a rigid fork and slick tires. I'm fond of my Continental Grand Prix 4000s; you probably would want to choose the widest available size for less weirdness putting them on MTB wheels. The Marlin's a 29er, isn't it?
    Village Newbie
    Reputation: SlickWilly8019's Avatar
    Sep 2012
    I have a 2012 Marlin, the first thing I would do is ditch the crappy stock tires, if you are still on them.
    Lots of forks to pick from, Manitou Tower pro is widely liked by people here, as are Rock Shox forks. Suntour upgrade program, but to get the better Epicon you gotta buy a 15mm wheel, its an added expense but you can pick a better wheel(s) than the crappy wheels that the bike came with. Lose the boat anchor fork & you will lighten the bike dramatically. Mine came with a 2590gram XCMv3 fork, I replaced it with a 1776gram Recon Gold TK.
    Some people will say is you lose the turning radius, steering of G2 offset unless you pony up the extra $ to get a fork with it, many other riders who have posted here haven't noticed it, that's why I wasn't really concerned.
    I want to get a carbon bar for mine someday and at least one good brake that modulates better than tektro Alivios do, the 2 position (on & off) braking sucks.
    Reputation: hankscorpio's Avatar
    Jun 2012
    What are you riding? Trails or Pavement or both?
    If you have been riding for a few years on it I hope you've gotten better tires but if not that is where I would start.
    I have a 2012 with a Manitou Tower Expert (1/2 lb heavier then the pro) and its made a HUGE difference in the bike. The next place to lose weight are the wheels but that wont be cheap. I'm going to a 1x10 in the near future which will help a little with weight.
    Sep 2013
    Which tyres would you suggest, considering that I ride 75% on bitumen and the rest on dirt roads.
    Cheers
    Fat-tired Roadie
    Nov 2007
    Second-tier XC low-knob tires. For example, the middle-priced version of the Schwalbe Racing Ralph. The expensive ones have a soft compound you'll kill really fast. And life is too short for the cheapest tires. For disclosure, my team jersey says "Schwalbe" on it somewhere. Another brand's competitor would probably be fine too.
    The idea is to keep the noise and rolling resistance down on asphalt and use volume (so go with a 2.1" or larger) to retain some grip off-road.
    Sep 2013
    Trek marlin 2012 upgrades
    Quote Originally Posted by AndrwSwitch View Post
    Would be possible to replace with 26" wheels and tires instead of 29" that I have now, without changing anything?
    Cheer
    Fat-tired Roadie
    Nov 2007
    All things possible with enough tinkering. If you have disc brakes, 26" wheels should drop right in. They might make the handling weird. I've thought 29ers are cool since the first time I demoed a hardtail with that wheel size. So I can't help wondering why you'd want to make the swap.
    Jun 2012
    especially for city riding....i would think the 29er rolling wheels would be better
    Black Horse
    Nov 2016
    I wanted to do a rigid fork on my 2017 marlin 5 but the guy at trek said I shouldn't do it cause of the g2 I am no expert but I really hate this fork and don't want suspension cause if I am out in wilderness the fork breaks I am in trouble I am going to upgrade brakes wheels and use it for backpacking or survival mtb
    Quote Originally Posted by Black Horse View Post
    Starting on Friday is the Arizona Trail Race 750/300 border to border- Mexico to Utah. The racers include many suspension fork equipped bikes. Your bike has a bottom level fork designed for bike paths. Quality forks are dependable. Once you have experience with one you'll be able to make a knowledgeable choice. Don't paint all equipment based on stuff that is of the lowest quality level.
    Watch this vid of the race
    Black Horse
    Nov 2016
    yes sir I agree but I am just wanting to do roads and lt trais ,backpacking loaded racks gear ect I am no expert I admit but I could get a rockshock recon 30 silver but I am 57 years old and cant afford a real good fork
    Get an Epixon off ebay and install it yourself. It uses a sealed damper like a car shock so no maintenance.
    Suntour Epixon Epicon XC Fork 26"/27.5"/29" MTB Air Fork Remote/Manual Lock | eBay
    Black Horse
    Nov 2016
    thank you for your help
    Black Horse
    Nov 2016
    again I want to thank you so much I was looking for something like this that wouldn't be a lot of money thanks to you all for helping me see the right way to go
    Black Horse
    Nov 2016
    cant use ridged there none made for 51 offset this bike is junk I have had 3 treks from a greedy lying lbs and I am done with trek giants all of them gready rats they never tell you till after you have the bike its not very good ,I am buying an used Dawes haymaker 1000 n26 for 225 well then I know what I got my shock says don't ride on trails yet trek says trail ready liars
  1. 2012 Trek Marlin Upgrades
    By jpr99 in forum 29er Components
    Last Post: 08-05-2013, 08:10 AM
  2. 2012 Trek Marlin Upgrades
    By jpr99 in forum Clydesdales/Tall Riders
    Last Post: 05-20-2013, 10:32 AM
  3. Replies: 3
    Last Post: 11-16-2012, 11:01 AM
  4. Few upgrades for my Trek Marlin
    Last Post: 07-14-2012, 04:54 PM
  5. Trek Marlin '11 29er or GF Marlin '10 26er
    By Lazlo0715 in forum Beginner's Corner
    Last Post: 08-24-2011, 07:04 PM
