Results 1 to 5 of 5
    May 2013
    Trek Cobia Trainer Tires
    Hi all,
    I am looking for tires for my 29er Trek Cobia to use with the trainer that I just purchased for the winter, but I have no idea what sort of tire I should get for the trainer! Help?
    just get an inexpensive 700c touring tire. Something 32mm or wider ought to fit just fine on your rim.
    RAKC
    Reputation: tigris99's Avatar
    Im doing the same for this winter, your trek shop has cheap wider road tires that do perfect. Like $20ish for one, only need the one on the rear. harder compound so I figure it should last a few winters for me. And thankfully its easy enough to swap tires back and forth so I can ride outside when weather permits.
    May 2013
    Thanks for the advice.
    I went to the local Trek Shop and they tried to sell me a $60 trainer tire.
    They had no 700c x 32+ in stock :\
    Here you are: Amazon.com: Kenda 700X32 Kwest Blk/Bskn K193,, 60 Tpi, 50-85 Psi: Sports & Outdoors
    There are plenty of 32mm or larger options out there for less than $15. The less tread/texture on the tire, the quieter it will be on the trainer. You will also want a road/touring tire sized tube, because your 29er tube will be very difficult to fit into a skinny tire.
    Amazon.com: Sunlite Bicycle Tube, 700 x 28-35 32mm PRESTA Valve: Sports & Outdoors
  1. Replies: 4
    Last Post: 04-22-2013, 10:35 AM
  2. Trek Cobia, Giant XTC 2 or Trek Superfly?
    By trek7100 in forum 29er Bikes
    Last Post: 12-10-2012, 09:47 AM
  3. 2012 Trek X-Caliber OR 2013 Trek Cobia?
    By gofastgt in forum Trek
    Last Post: 11-21-2012, 09:53 PM
  4. 2012 Trek X-Caliber OR 2013 Trek Cobia?
    By gofastgt in forum Beginner's Corner
    Last Post: 11-14-2012, 04:34 PM
  5. '12 Trek Cobia wheelset/tires
    By kray in forum Wheels and Tires
    Last Post: 01-28-2012, 09:02 PM
