Results 1 to 6 of 6
    Tool to remove bottom bracket on stumpjumper comp 29er HT
    trying to change my bottom bracket and i need the tool to remove the non drive side. The nut appears to be that like a spanner nut. I am not sure of the exact tool number i need to purchase. Any help would be appreciated.
    What crank? You want the tool to remove the non-drive side crank arm or bottom bracket?
    Trying to remove the bottom bracket. It is a press fit type bottom bracket. The bike is a bb30 set-up. I have found a few press kits, but want to make sure i find the right one before buying.
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Here are the tools you need to remove and install Press Fit bottom bracket (PF30): Park Tool Co. » BBT-90.3 : PressFit Bottom Bracket Bearing Tool Set : Bottom Bracket
    Very similar to the tools used to install and remove headset cups... and in fact you need a headset press along with the cups in this kit to do the install.
    The removal tool looks like the same one so if you have access to a headset cup removal tool it might work.
    Feb 2007
    This is exactly why as consumers we should not purchasing bikes from manufacturers using press fit
    bikesonburke
    Quote Originally Posted by pete weber View Post
    Every bottom bracket standard requires specialized tools, so I don't think PF30 is that much worse than the others. I personally had to purchase tools for square taper and external BBs, but for press-fit I was able to make do with bearing cups and a headset press I already had so it was actually the cheapest one for me.
  1. which bottom bracket tool do I need for this?
    By canker in forum Beginner's Corner
    Last Post: 06-03-2012, 10:59 PM
  2. Replies: 5
    Last Post: 05-29-2012, 01:35 PM
  3. 2011 Epic comp 29er bottom bracket question
    By schwendy2 in forum Specialized
    Last Post: 02-04-2012, 06:27 PM
  4. Bottom bracket tool
    By moldau94 in forum Tooltime
    Last Post: 11-23-2011, 11:42 AM
  5. Bottom Bracket tool and crank tool questions
    By RBikerSD in forum Tooltime
    Last Post: 01-10-2011, 04:36 PM
