Results 1 to 6 of 6
Thread: Token Hubs
    Reputation: Johnny Sin's Avatar
    May 2010
    Token Hubs
    I have a set of XC Token hubs, model number TK4915. The bearings have developed a bit of play in them, so I want to change them out. Only problems is I can’t get the freewheel body off. I have emailed Token and they sent me an instruction manual, but it’s next to useless, it just says “remove freewheel body”. I've tried pulling it, twisting while pulling, but I’m out of ideas.
    Does anyone have any experience with Token hubs? Or have any suggestions on how to remove the freewheel body…
    I'be taken apart a few. After removing the axle the freehub just pulled off. It took a pretty good tug.
    OB1 Kielbasa
    One is good!
    May 2010
    Do you have to remove the axle as well? I've removed the QR adapters, but didn't think I'd have to remove too much more than that. Thought I was pulling pretty hard, maybe I'll just pull harder.
    Yes the axle must be removed.
    OB1 Kielbasa
    One is good!
    It depends if they are 29er specific hubs though, surely..?
    May 2010
    Got it off, turns out I just wasn't pulling it hard enough.
