Results 1 to 5 of 5
    May 2012
    Tire / tube question.
    Would it be ok to use a 700x47 tube with a 29x1.9 tire ?
    Reputation: J.B. Weld's Avatar
    yes.
    Reputation: Bike Whisperer's Avatar
    Yes it would, you can also use 26" mtb tires in 29" tires. They stretch around the rim just fine.
    May 2012
    Ok .. thanks very much for the confirmation.
    How far up can I go with a 700x47 tube ?
    I also have tires that are 29x2.0 and 29x2.1 ... I wonder if the tube is fit for those sizes ?
    Thing is that I cant find any specific lightweight 29" tubes but I have seen some very lightweight 700 and 26" tubes that might work.
    I already have 700x47 that weigh 95 gr.
    I have also seen some lightweight 26" latex tube that migth work.
    You could use those tubes on wider tires, probably up to a 2.5 but I wouldn't recommend it- nor would I use a 26 inch tube unless you enjoy getting more flats.
    Ideally a tube inflated just enough to give it shape will completely fill the tire. A skinny tube has to be overinflated quite a bit before it will even contact the inside of the tire. Think of a balloon inflated real tight. Touch it with a pin and it will explode. The same balloon barely inflated has to be pushed much harder with the pin to pop it.
