Results 1 to 8 of 8
    Mar 2013
    Tire out of alignment
    So I just got a rigid single speed, and my front tire keeps shifting to the left. I'm not sure if the brake is pulling it there, but it makes it to where my break is constantly engaged.
    Is it my skewer? Or something else?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Is your skewer tight enough?
    Nov 2008
    Doesit the rotor rub when you spin the wheel on a stand? Might be one of several issues. Either the skewer is not clamped with enough force straight in the drop out or a bent skewer. Also, have you tried loosening the brake caliper, spinning the wheel, grabbing the brake lever, then tightening the caliper bolts? This usually lines up the pads with the rotors.
    Can you provide a picture or explain in a little more detail?
    Mar 2013
    I tried adjusting the brake to the wheel (they were actually set up by a bike shop). The main problem happens on downhill sections, I ride until it moves over, I stop and either knock it back over, or loosen the skewer and re-tighten it.
    It spins fine on a stand, and the skewer is tight. I'm thinking I need a better skewer.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Quote Originally Posted by Bret Ward View Post
    Go with Shimano XT or XTR ... can't go wrong!
    SPP
    Rigid.
    1*14*29*2.1 & 1*1*29*2.4
    you talking rim brake or disc?
    Mar 2013
    Disc
    Do you have avid brakes? Possibly you have a sticky piston, and the other side keeps moving over to compensate. Avids are notorious for needing realignment constantly to stop light disc rubbing, if that is what you are talking about. Otherwise I like them. If it is the brakes it may need a service, or the easy fix is to replace with shimano which are much more reliable in this respect.
  1. Handlebar Alignment Off?
    By s4one in forum Specialized
    Last Post: 04-12-2013, 08:34 AM
  2. Caliper Alignment
    By larsd in forum General Discussion
    Last Post: 12-30-2012, 08:01 AM
  3. KM Dropout Alignment
    By LBIkid in forum Surly
    Last Post: 05-09-2012, 07:41 AM
  4. Frame Alignment?
    By Canadmos in forum Banshee Bikes
    Last Post: 11-17-2011, 10:09 AM
  5. What is good alignment?
    By markfarnsworth in forum Frame Building
    Last Post: 01-19-2011, 06:31 AM
